Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 11-27-2007, 07:59 AM   #1
Big East CHAMPS!
Colonel's Avatar
Send a message via MSN to Colonel
Replacing Alternator
I got the lucky chore of at least attempting this task this weekend. I thought I might share a few "lessons learned".
There are tons of threads asking about the lights and smart aleck answers but nothing to address the fairly simple task of R/R, so I put this together to help address areas of possible confusion. This should be a very simple task for anybody that can change their own oil.
  • Prior to unbolting anything to replace:
    • Disconnect the battery. Clean the outside of the battery terminals and the inside of the cables lightly with steel wool or sand paper of 200 grit or higher.
    • Disconnect the Alternator ground (12mm). I used an extention with a socket to get at it.
    • Disconnect the Alternator harness. Its stubborn but DONT yank on the wires of the harness.
    Inspect all three connections for oxidation or broken parts and then reconnect to see if your symptom still exists. If they do, then pull the battery and alternator and have them both bench tested THEN replace faulty part.
  • They have revamped the idler tension bolt on the pulley face assembly (mine is an 01). Its no longer a wimpy little un-flanged brass nut anymore that can be easily stripped. Its now a big beefy nut(they took it off an idler assembly in stock). Make sure to get a better bolt to replace the piece of trash bolt that came with the car.
  • Because you need to loosen this bolt FIRST as well as the top bolt (both 14mm), make sure you use a GOOD 6p point wrench or you'll strip it like I did.
  • A total of eight bolts: 4 for the AC compressor, 2 for the Idler pulley, and two for the alternator. DO the Idler pulley first. If you have issues with either bolt on the idler pulley there is no reason to pull the compressor as you will not get it easily lined back up because the belt will be to tight. Ask me how I know this.
  • The "check the alternator through the battery test" isn’t worth doggy do do. I also found this out the hard way. I would have thought they would hook up the alternator to some gizmo to test it, as they said they can test it on the car. When the Oil light and Brake light lit up, I knew what the basic cause was. I had it "tested" on the car and they said the alt was bad, which I suspected.
    I had disconnected the battery and unclipped the alternator harness and alternator ground prior to attempting to uninstall the alternator and finding the stripped bolt. Once I stripped it (well, very close to being stripped) and had put on penetrate for about 24 hours with no success, I put the whole thing back together to take it to a shop to have the bolt removed. I reassembled and low and behold, no warning lights lit up. The bolt to the ground was tight; the harness was also tight prior to uninstalling. The only thing I can think of is that some oxidation happened somewhere and by "removing" the connections scraped it off enough to make it work.
All in all, if I had not run into the stripped bolt, it would have taken about one hour to do a R/R. In hind sight, even though I spent tons of time on the bolt it DID save me 200 bucks for a new alternator.
I read some threads from a while ago stating you can get an alternator for about 80 - 100 dollars. The cheapest I could find was 180 dollars, but it was a no-name 90 day warranty alternator which I would not put in my car. Most averaged between 225 and 250.
MotorVate has a really helpful website (Pointed out by Lontar1) with pictures to give more detailed information. While the guide is for a Fourth Gen, the principal and components are the same.
MotorVates Alternator Replacement Guide
Yet more testimony to make sure to make sure to loosen the idler pulley bolts FIRST.
Quote:
Originally Posted by Love_00_Max View Post
To keep folks updated on the tensioner pulley bolt -- the replacement bolt would be strut hat bolt (14mm).
The OEM bolt is butter and a socket cannot access it, so with a wrench the probability of rounding it off is definetly a possibilty (as it happened to me and others).
Quote:
Originally Posted by djfrestyl View Post
I just replaced the alternator on my 5.0 gen. Took me roughly 3 hours, including a quick search on the forum and finding a replacement nut for the stripped tensioner pulley nut. The OEM one is butter soft.
I didn't touch the fan shroud or the radiator. No need for draining coolant, no need for removing the fan assembly.
The AC compressor, however, ABSOLUTELY MUST be unbolted and moved to access the long bolt at the bottom of the alternator. The alt will can come out from under the car and the new one can be inserted from under the car.
This is the easiest method, and will save some time over the motorvate write-up.
__________________
2001 Maxima SE VQ30DE-K (5 Spd)
1991 MR2 3S-GTE (Gen III, 5 Spd)
2007 Rav 4 2AZ-FE (Auto )
Colonel is offline   Reply With Quote
Old 11-27-2007, 08:23 AM   #2
Maxima.org Sponsor and Donating Maxima.org Member
Great write-up...thanks! Out of curiosity, how many miles are on the car? Both my 4th Gen Maxima and 5th Gen-equivalent I30t have in excess of 100K and I'm kind-of expecting something like this to go.
talkinghorse is offline   Reply With Quote
Old 11-27-2007, 09:04 AM   #3
Big East CHAMPS!
Colonel's Avatar
Quote:
Only 54K and change. To clarify, I didnt replace the alternator. Due to my saga above, I think I had "accidently" cleaned off some oxidation somewhere. I wonder how many people have replaced perfectly fine alternators? Because that test the performed was a joke in my book.
__________________
Old 11-27-2007, 10:42 AM   #4
This is a great thread, I'm gonna try and do some cleaning and tightening myself however I'm at 123,000 miles and had a "brake and battery" light combo come on for about a minute earlier this week. Also once in a while now, the alt. squeals REAL loud when the car is at idle and its drawing a lot of current
(like stopped at night in the rain, brake/head lights on, wipers, heater, radio, defroster and heated sea and if i put a window down the gauges dim and it squeals)
So I might be looking at a new one but we'll see first
carsarecool is offline   Reply With Quote
Old 11-27-2007, 01:31 PM   #5
Great write-up. Pics would be nice. Did you have to remove the radiator fans to get to alternator? It's a PIA to get to.
__________________
>>>Happy New Year Everyone!!!<<<
* Trans Cooler Install * Grounding Kit Install *
808MAX-SPEC is offline   Reply With Quote
Old 11-27-2007, 01:41 PM   #6
Big East CHAMPS!
Colonel's Avatar
Quote:
No, I see no reason to remove the fans. I pulled the right front wheel and spent most of my time working from under minus removing the connectors and such from the alternator. Removing the four AC compressor bolts and moving the compressor out of the way seemed pretty easy to me. That was the OEM manual way to do it and it seemed good.
Pics would be nice, but its really self evident which bolts are what. If someone wants to host them, I can do it. But I have a free webshare that I use that gets overwhelmed by high traffic.
__________________
Old 11-27-2007, 06:30 PM   #7
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Quote:
Check the belt first, make sure it isn't slipping.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 11-27-2007, 07:20 PM   #8
Puerto Rico-Maxima Lover
Lontar1's Avatar
Best write-up ever for Alternator replacement up with pics....
http://www.motorvate.ca/mvp.php/500
__________________
Powerslot, HAWK HPS, Stillen lip-Valance, HIDS, OEM side skirts, Illuminas, Maxspeed, Stillen RSB, C.M. FSTB, Viper791, Beltronics Radar (hard wired), G35c rims, 20% Tint,AE sills and pedals, Z dead pedal, Clear Sidemarkers
""AT Tranny Flush Click HERE"
Lontar1 is offline   Reply With Quote
Old 11-27-2007, 10:16 PM   #9
When I replaced my alternator, I had to get the fans out.
Overall replacing the alternator is not a fun job but I wouldn't go to the extent to say it is a very tough job. If one has tiny hands it is a big plus.
Love_00_Max is online now   Reply With Quote
Old 11-27-2007, 10:22 PM   #10
-we are your overlords-
irish44j's Avatar
this thread added to the "installation instructions/how-to" sticky...thanks.
irish44j is offline   Reply With Quote
Old 12-01-2007, 06:55 PM   #11
Send a message via AIM to djfrestyl
Bumping this thread to add my 2 cents.
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Viper / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Inquire for prices.
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Check this out!
http://forums.maxima.org/general-maxima-accessories-all-generations/357978-saggy-spare-tire-cover-solution-sale.html
djfrestyl is offline   Reply With Quote
Old 12-01-2007, 09:03 PM   #12
Old 12-02-2007, 01:30 PM   #13
Quote:
Thats the thing, I'm pretty sure it is the belt slipping because too much current is being drawn on a failing alternator. I just had the belts replaced in april with goodyear Gatorback's, and now if say I'm at idle with the wipers, heated seat and radio on and i turn on the rear defroster it'll squeal.
Old 12-03-2007, 06:15 AM   #14
I just replaced my a/c-alt belt because of squealing. I found something strange. The prior owner had a shop replace the alt in Sept he stated that the belt had been slipping since. Lastnight I replaced the belt and went to tighten it.I found that the 14mm hat nut was on the wrong side of the bracket!!!! So when you tightned the nut it just raised up. I had to take apart the puley to slide the bolt/nut combo back though the hole in the bracket where they needed to be. This is why I work on my own cars. Has anyone else ever seen this? Hope this helps others.
buellfire is offline   Reply With Quote
Old 12-17-2007, 04:56 PM   #15
Just did my alternator replacement. I was expecting it to be a PITA but it took me about 45 min. Followed the steps above, but had a FSM on hand as well. FYI, use a box end wrench on the tensioner nut and you shouldn't have an issue with strippage.
hoboscratch is offline   Reply With Quote
Old 12-18-2007, 10:23 AM   #16
Send a message via MSN to Professor
122k on my alternator, also factory belts, what are my chances something lets loose anytime soon //?
__________________
Eibach Springs|HIDs|20% Tint|Custom Stereo|Custom LED Interior|GAB|Brembo Sport Drilled Rotors|Hawk Hps pads |SE Tails|AE Headlight Coversion
SHIFT_auto rolling
Professor is offline   Reply With Quote
Old 12-18-2007, 01:11 PM   #17
Quote:
You may want to check your belts for cracks. Other than that, consider yourself lucky if you had no problems with your alternator.
__________________
Old 12-18-2007, 03:15 PM   #18
Maxima.org caught teh GAY
upstatemax's Avatar
Send a message via AIM to upstatemax
Glad to see this thread... I am about to swap out my Alt, again...
I had mine replaced last year and this weekend my car started to act strange, radio cut out, dash acting funny and would not restart. I let it sit for about 1/2 hour and it started up fine and acted fine. I stopped by Advance Auto and they tested the battery and Alt, the battery tested fine while the Alt peaked at 14.8 amps at 2k rpms.
I need to get under the car and look far crappy connections.
upstatemax is offline   Reply With Quote
Old 12-18-2007, 03:46 PM   #19
Send a message via AIM to dineth00i30
man i had my i30's alternator replaced and what a change! my headlights are brighter , my bose sub sounds totally different and the car is great now bcus, i got a new maf as well but changing the alternator was pain what i did was loosed up the ac from the bottom and took the alternator from the back.
dineth00i30 is online now   Reply With Quote
Old 07-29-2008, 11:21 PM   #20
2003 Maxi alternator
Here are a few extra hints for a 2003:
$150 for a reman alternator at autozone. Lifetime warranty but not a perfect fit. There is a sleeve in one of the mounting brackets where the long bolt goes tru. This was way too long, it would prevent the hook from catching on the long bolt, so that it would not tighten up, just spin..
Ended up tapping out the old sleeve from the original alternator and using that.
BRW the Dealer wanter $400 for the alternator,+ $200 labor.
On the 2003, I had to take off the fan assembly, the compressor and the idler pulley. (The pulley covers up one of the bolts). The idler pulley has multiple pieces to it, write down the order in which they come off...
Also the AC compressor has 2 sets of different bolts, so write down which bolt goes into which hole.
For the fan assembly, you need to drain the antifreeze.
If you detach the intake and outflow hoses, and the overflow tube, you can just lift the thing up and lay it on top of the engine. do not have to disconnect the electrical wires.
Reassembly was a pain, esp. putting in the long bolt. You can not see what you are doing, took me an hour to put it back in. Once the long bolt is in place, and the nut is on, you should put some pressure on the right end of the long bolt, ( I used a long stick) so that the hook will catch and not turn. This allows you to tighten the nut properly. This is a locking nut, takes a while and some force to snug it up.
Having a second person around for the reassembly is extremely useful. The whole process took more like 8 hours for me, so evidently YMMW.
kaeroonsnake is offline   Reply With Quote
Old 07-29-2008, 11:45 PM   #21
Scottwax's Avatar
Good luck on an Autozone alternator. Never had any luck with their parts. Hopefully you have better luck. Thanks of the tips you provided.
Old 07-30-2008, 08:44 PM   #22
I think he ended up replacing the alternator anyways a couple months later tho... So Break light and Battery light are definite signs Alt. is going bad...
__________________
MODS:
Illuminas + Eibach | Stillen FSTB | Progress Rear Swaybar | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | Stillen Y-Pipe | HKS Rear Section | InJen True-WAI | Shinjinduo Grounding Kit | Ionic Dynamics Bodykit | Ebay Projectors | Foglight HIDs |License Plate LEDs | Blacked out GRILLZ | Pioneer Avic-D3 | Interior LEDs
http://www.cardomain.com/ride/3006504
McSteve is offline   Reply With Quote
Old 08-01-2008, 12:31 AM   #23
Other than ordering name brand items thru them such as Energy Suspension, along with chemicals and the like... their parts never fit anything worth a crap, not even back in the early 80'S!
CMax03 is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
