Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-14-2010, 03:33 PM   #161
Just to pipe in on this to clarify something that screwed me up when I did mine the first time: the tensioner nut (or "Strut Nut", as pointed out in the picture in Post #138 in this thread) must be turned to the LEFT to loosen the belt. If you take it apart, you will see that it is actually reverse-threaded, in order to loosen the belt to the left.
When my tensioner bolt broke (rusted tight, but it probably didn't help that I was trying to turn it to the right to loosen it - which would be the correct direction if it wasn't reverse-threaded), I found another one at a pick-a-part yard. They wouldn't sell me just the bolt and nut - they sold me the whole shebang including the pulley. I got it for 6 bucks, and they gave a 60 or 90 day warranty on the part. The tensioner is the same part for 1995 through at least 2003 Maximas/I-30/I-35'S, and it may very well be the same part on 6th-gen Maximas also - no experience to be able to tell you.
Good thread!
vinco is offline   Reply With Quote
Old 07-31-2010, 09:04 PM   #162
Send a message via AIM to PadawanKnight Send a message via Yahoo to PadawanKnight
Quote:
Originally Posted by ATX02SE6spd View Post
Okay, now I've done it. I've stripped the tensioner pulley nut and can't figure out how to get it off. The nut removers I have won't fit in that space. I don't think a nutcracker will work because of the washer part of the nut (or will it?). I'm at a loss. Any ideas. I stripped it with a box-end, by the way. After applying a bunch of Blaster. That guy won't budge...
Need same advice. I have a nut that is starting to get rounded from my attempts to remove it. It's my own fault that it started to get rounded in the first place. I was working from driver's side of car facing passenger's side and didn't "switch" directions in my head. When I was attempting to turn the nut to the left from my view point, I didn't realize it was turning it to the right until it was too late.
Even vice grips haven't had any luck getting the nut to turn. Is a nut splitter my best option? I need to get the alt replaced tomorrow so that I can make it to work on Monday. Alt was putting out "0" when I got it tested.
__________________
Always Give 100% at Work
12% on Monday
23% on Tuesday
40% on Wednesday
20% on Thursday
5% on Friday
PadawanKnight is offline   Reply With Quote
Old 08-02-2010, 08:06 AM   #163
Good thread!
Kudos to the OP and subsequent contributors.
__________________
2K Max GLE AT Lustre Gray, SE Titanium Rims...pushing 170k...
mandyfig is offline   Reply With Quote
Old 08-04-2010, 03:39 PM   #164
Did you notice the alternator ever making a whining sound?
joedzz is offline   Reply With Quote
Old 08-04-2010, 06:14 PM   #165
Quote:
The alternator does make a whining noise. At least that was the case with my car. I had to replace it when it died a couple of months ago and the whining I was hearing, that went along with the RPM's, is gone for good.
__________________
Nelsito65 is offline   Reply With Quote
Old 08-05-2010, 05:22 AM   #166
No whining. I mean no whining from alt.
__________________
Old 08-27-2010, 12:50 AM   #167
Got the two lights of horror yesterday coming from home, replaced the battery today with a new one and no changes, going to check the connections tomorrow. This will be the second time im changing the Alt within 2 years, so I just read the entire thread to brush up on my knowledge and technique. One thing i can vividly remember is that when i did it previously, i found when the A/C compressor was dropped, I had the HARDEST time getting the alternator out. There just was not enough space for it to slip out and I eventually had to seriously and forcefully yank it out. Any suggestions to possibly omitting this ??? I believe it was completetly lowered to its full extent. Thanks everyone !
__________________
01 -- I30t , 158hp, 185tq
pattyt is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Maxima Forums - Archive -
Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
