Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-04-2007, 06:05 AM   #1
Resetting ECU
I have read that the maxima ECU is adaptive in that it changes according to driving styles. I have also read that there are a few ways to reset it. Some say you can disconnect the terminal going to the positive battery post for 1/2hour. Others say it must be disconnected overnight. I also read that it can be done using the procedure below. Some say the procedure below only resets part of the ECU ut not timing and some other things. Does anybody know what must actually be done to reset the ECU?
One procedure:
How to reset ECU in 5th and 6th Generation Maxima's
1. Turn ignition switch on and wait about 3 seconds.
Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking. (here is where i think you can get a code from this.)
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
Also, I have read that it takes 400-500 miles of driving for the ECU to complete readapting. If I drive heavy on the throttle during that time then what different signals does the ECU send? Does it adjust the timing, fuel, etc from that point forward?
Wheelie King is offline   Reply With Quote
Old 11-04-2007, 06:55 AM   #2
Send a message via AIM to choiiiiiiiiiii
for 2000 its simply disconnecting the battery, you dont need to keep it overnight, i keep it off for no more than thirty minutes. you know when its reset if you have a cd in the radio and it pops out.
for 2002+ its that process listed above.
400 miles is a little much, i believe its just a couple miles..
__________________
AMD
Atlanta Maxima Drivers
RIP maxima
now '05 altima se-r. 6 speed
Quote:
Originally Posted by queenz718 View Post
no just google it, an altima has the looks like a girls car would. thats obvious.....
a maxima is so manly on the other hand!
choiiiiiiiiiii is online now   Reply With Quote
Old 11-04-2007, 10:08 AM   #3
01 Maxima SE, 5-spd
aksansai's Avatar
Quote:
First things first - help the little guy out by running the engine at idle (if not already, warm up the engine to normal temp) for a while. The ECU can learn quite a bit from this stage since the RPMs aren't bouncing around precariously. Then go for some normal driving a few miles and let it adapt to the condition of your coil packs, plugs, O2 sensors, etc.
__________________
AksanSai
aksansai is offline   Reply With Quote
Old 11-04-2007, 11:13 AM   #4
Send a message via AIM to MaxiRacer
But for a 2000 or 2001 is it better to follow that porcedure or should we just simply disconnect battery?
MaxiRacer is offline   Reply With Quote
Old 11-04-2007, 12:01 PM   #5
I don't think that procedure works for 00-01s. Just do the battery trick.
jkayca is offline   Reply With Quote
Old 11-04-2007, 05:15 PM   #6
USF Class of 2009
flxsunxchick's Avatar
Send a message via AIM to flxsunxchick
Thanks for posting this - I've misplaced my Haynes and I needed to reset my ECU, but was getting the same conflicting results online.
__________________
flxsunxchick is offline   Reply With Quote
Old 02-22-2008, 07:11 PM   #7
Send a message via AIM to Pearltt
One procedure:
I just installed an intake in my car and wanted to reset the ecu, but not sure if I'm doing it right...I followed the procedure listed above but I am unable to see the CEL light come on or blink during the procedure...any ideas???....do I even need to reset the ecu with an intake install???
__________________
Pearltt is offline   Reply With Quote
Old 02-22-2008, 10:34 PM   #8
The timing is crucial. I use my metronome for that, never failed.
boris is offline   Reply With Quote
Old 02-22-2008, 10:47 PM   #9
bumping up the old thread.
you don't necessarily have to, but i did anyways.
__________________
AMD
RIP maxima
Old 02-24-2008, 02:32 PM   #10
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Also, the engine temp is crucial too. Make sure i's warmed up.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 03-08-2008, 10:43 AM   #11
Reprogram after new MAF install?
I just bought a new MAF for my 2000 Maxima and I am going to install it myself, but I was told I need to take it to the dealership to get reprogrammed? Does the ECU just need to be reset? Is this something I can do myself or do I actually need to take it to the dealership?
Marceljin is offline   Reply With Quote
Old 03-08-2008, 11:14 AM   #12
Resetting and reprogramming are two different things. Yes you have to reset the ECU. No you don't have to have the ECU reprogrammed or at least thats the general consensus. I drove around my max for two years after changing the maf without reprogramming with no problems. I had to get it done in the end for something else. Anyway, when you replace your maf you have to disconnect the battery. By the time your done, the ECU will have reset so you don't have much choice.
Old 03-08-2008, 11:26 AM   #13
Send a message via AIM to babyboyws6
Quote:
disconnect your battery for a few hours ... i had the same problem with my k&n air filter and i did the whole disconnecting battery and it picked up on the code in about 150 miles for me... i was happy when it turned off that **** was annoying
__________________
Bown down biatch
he's my second alarm
babyboyws6 is offline   Reply With Quote
Old 03-08-2008, 12:19 PM   #14
did it yesterday and within 10mi. of driving it came back, got codes for EGR and o2 sensor
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
Grand_hustle17 is offline   Reply With Quote
Old 03-09-2008, 10:00 PM   #15
mine went away after more miles then that and when i fired mine back up it came right back up like it was always there... but once it went away, never came back up..
im bout to get a custom cold air intake... that should be fun for the sensors =D
__________________
Bown down biatch
Old 03-09-2008, 10:15 PM   #16
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
you dont need to reset anything...after a few days, the ECU will make any needed adjustments.
SoonerFan is online now   Reply With Quote
Old 03-09-2008, 10:23 PM   #17
Send a message via MSN to chadsexington
i got an oil change today, do i need to reset my ecu?
chadsexington is offline   Reply With Quote
Old 03-09-2008, 10:53 PM   #18
tru story
SoonerFan's Avatar
Quote:
only if it was synthetic
Old 03-18-2008, 10:49 PM   #19
so when do you reprogram (flash) and when do you reset the ECM?
how are those different?
DataMan is offline   Reply With Quote
Old 03-18-2008, 11:05 PM   #20
tru story
SoonerFan's Avatar
reset - you set software values back to default factory settings so that the ECU can "relearn" a new mod such as an intake. (think - rolling back drivers)
reprogram (reflash) - there is a problem with the default software values. Nissan will have new software that needs to be loaded to correct the problem. (think - installing new drivers)
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
Old 03-18-2008, 11:11 PM   #21
I see.
So in my case that I changed the TB, ECM and maybe I add the MAF should I do a nice reflash of ECM. I got the ECM from junkyard and not sure how old that is.
Also is there any way we can do the reflash ourselves or anyone beside dealer (stealer)?
Old 03-19-2008, 12:26 AM   #22
An ECM replacement requires the dealer and the NATS security system program to reprogram all your keys. Might as well check for any required updates (reflashes) at the same time.
P. Samson is offline   Reply With Quote
Old 03-19-2008, 06:57 AM   #23
Quote:
The reseting we did ourselves I am trying to figure out if it is worth it to do the reflash. since my car is still idleing on 1700rpm
Old 09-12-2008, 09:10 AM   #24
Just to know ... Did somebody know the services number of the ECM for maxima 2001 20th aniversary. I need to buy one on ebay but i want to be sure is the good one
thank you
kjunior is offline   Reply With Quote
Old 09-12-2008, 08:24 PM   #25
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Easiest way is to make sure the engine is a full operating temperture. Turn off, disconnect the negative terminal from the battery. Step on the brake pedal, hold it down and then turn on the headlights about 10 seconds. That will clear out any remaining charge in the system.
I haven't noticed much difference in my car resetting the ECU but I noticed a huge difference when I had my 626 since the previous owner drove it so conservatively.
__________________
2002 Maxima SE, NWP block plate, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 08-08-2009, 05:10 PM   #26
Send a message via AIM to xWasX08 Send a message via Yahoo to xWasX08
For a 2000 it's the negative terminal correct?
__________________
2000 Black Nissan Maxima GLE
- Current Mods -
|Injen CAI | Bosch Platinum Spark Plugs | 20% Window Tint |
- Upcoming Mods -
| 18" DBL G 505 Black Rims | Cattman 2.5" Exhaust | Yellow 3000K Fogs | MagnaFlow Y Pipe | 6000K Headlights | 2" Drop Springs |
xWasX08 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
