Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 09-26-2007, 03:22 PM   #1
Points: 13,279, Level: 75
Points: 13,279, Level: 75 Points: 13,279, Level: 75 Points: 13,279, Level: 75
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to MaxedOut2g
car shaking on idle, SES light blinking...help please
before anybody says anything, i did a search and came up with a couple possible diagnosis...but nothing concrete
basically i woke up this morning and went to the gym with no problems...when i turned the car on to come back home i noticed it didnt start normally and then had quite a noticeable shaking idle...also as i started out the car didnt sound the same on acceleration either
i have a budget exhaust (CA spec) w/ greddy catback and as you all know, your car has a distinct sound and it just wasnt right...my SES light comes and goes and everytime i check it, it shows up as a P0420. Its been on but for the first time today the SES light was blinking as i headed home
oh and my car is at 99.5k miles
so i was thinking maybe i blew my MAF, but the car didnt die even while idling at a red light
so then maybe ignition coils?
maybe motor mounts or the bushings?
any help would be greatly appreciated
thanks guys
__________________
SHIFT_slowlytoavoidlicenserevokation
MaxedOut2g is offline   Reply With Quote
Old 09-26-2007, 03:25 PM   #2
TurtleHead
P0420 usually a clogged cat.
Disconnect your MAF at idle and see if it clears up. The ECM goes into "limp/default" metering and should idle good. If the idling is still bad, the it's prolly the cat.
Old 09-26-2007, 04:24 PM   #3
Points: 6,285, Level: 51
Points: 6,285, Level: 51 Points: 6,285, Level: 51 Points: 6,285, Level: 51
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
The root cause is the engine missing. Ever replaced the coils? Go with the easy stuff first.....air/vacuum leaks, then go for the spark plugs.
P. Samson is offline   Reply With Quote
Old 09-26-2007, 08:29 PM   #4
Cletus
SoonerFan's Avatar
Points: 24,824, Level: 95
Points: 24,824, Level: 95 Points: 24,824, Level: 95 Points: 24,824, Level: 95
Activity: 0%
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
its something ignition related...probably a bad coil...one or more cylinders isnt detonating
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
A few offroad mods
Maxima - sold (but my 5th gen knowledge wasn't in the trunk when I sold it)
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 09-26-2007, 09:12 PM   #5
Activity: 0%
hey thanks for the responses guys....im gonna take a look at all those things;
but a little more updating information
so about 2 hours after i got home from the gym i went to go try the car out again and no problems whatsoever
the vibrating was gone, as was the abnormal engine/exhaust sound
my dad was able to get his hands on an OBDII
and i pulled up some codes...since it was my first time using it im not sure if i used it correctly but this is what i got
Read Codes:
P0138 O2S Hi volt (Bank 1 Sensor 2)
P0139 O2S Low (Bank 1 Sensor 2)
P1320 Manufacturer check
and under Pending Codes:
P0306 Misfire detected (cylinder 6)
so it looks like combination of ignition coils and O2 Sensors?
before i take it to my dads mechanic jst wanna know what im expecting
thanks again guys
__________________
Old 09-26-2007, 09:25 PM   #6
WSH for teh cup
Kyle00's Avatar
Points: 6,717, Level: 53
Points: 6,717, Level: 53 Points: 6,717, Level: 53 Points: 6,717, Level: 53
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
I thought P1320 was multiple cylinder misfire, I could very well be wrong though. I'm throwing a cylinder misfire code and I just received my coils tonight from Dave B. They were 395 shipped for all 6 updated (grey dot) coils. You might want to get them from him if it does end up being the coils
__________________
Quote:
Originally Posted by Cutler View Post
Torgus I have owned 2 maximas and typically mod my cars to handle better and go faster....not cruise the mall and scare small children with it's body kit...
Or plow snow, you choose...
Kyle00 is offline   Reply With Quote
Old 09-26-2007, 09:31 PM   #7
Activity: 0.4%
P1320 is actually the Ignition Signal code, very often seen with a duff coil. You've also got the clincher......the P0306.....change the No. 6 coil. Forget the O2 sensor. If you're going to hang on to the car a lot longer and the coils haven't been changed out already, change them all. Remember when troubleshooting........change one "thing" at a time.
Old 09-26-2007, 09:34 PM   #8
Cletus
SoonerFan's Avatar
Activity: 0%
its a bad coil...since the cylinder didnt fire, the exhaust was rich because of unburned fuel. thats what the O2 detected.
__________________
A few offroad mods
Old 09-26-2007, 09:41 PM   #9
Activity: 0%
you guys are awesome, thanks a lot
i appreciate it greatly
__________________
Old 09-27-2007, 02:27 AM   #10
Points: 5,896, Level: 49
Points: 5,896, Level: 49 Points: 5,896, Level: 49 Points: 5,896, Level: 49
Activity: 0%
i've had this... like they said.. it's misfire
new coil time
__________________
getbigtony is offline   Reply With Quote
Old 09-27-2007, 03:52 PM   #11
I'm having the same problem as MaxedOut2g. Since coils are pretty expensive (if I were to buy 6 of them), I was thinking about finding the failing coil and changing only the particular one. Nissan Dealer told me to replace 6 coils and 6 spark plugs but the mechanics I go to says that I probably need just one coil to replace.
Any comments are greatly appreciated.
chandmx is offline   Reply With Quote
Old 09-27-2007, 04:20 PM   #12
Drug Money
MaxBoost925's Avatar
Points: 11,951, Level: 71
Points: 11,951, Level: 71 Points: 11,951, Level: 71 Points: 11,951, Level: 71
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
When my coils blew, my SES was blinking too.
MaxBoost925 is offline   Reply With Quote
Old 09-27-2007, 07:20 PM   #13
blinking? i've never seen mine blink. it goes away sometimes (for few days) and comes back on whenever it shakes.
Old 09-27-2007, 10:07 PM   #14
Points: 7,282, Level: 56
Points: 7,282, Level: 56 Points: 7,282, Level: 56 Points: 7,282, Level: 56
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Quote:
You need to change out all your cols before your engine takes a crap on you just get a hole set of ebay for like 300 bucks. Once one fails the others will follow just replace all at once and be done with it.
__________________
SuperStasiu is offline   Reply With Quote
Old 09-27-2007, 10:13 PM   #15
Cletus
SoonerFan's Avatar
Activity: 0%
contact davb about getting a set (that you know are good). dont buy something like this on ebay, you dont know what you will get.
__________________
A few offroad mods
Old 09-28-2007, 05:32 AM   #16
WSH for teh cup
Kyle00's Avatar
Activity: 0.8%
Quote:
The SES light will blink sometimes, if the ignition coil fails for an extended period of time and the light will remain on when the failure stops. Even if the SES light goes off, the code is still stored in your car unless you clear it. And at different times, the Slip and TCS lights will come on. Whatever the case, if your experiencing the same symptoms as described as the others, its most likely your coils and it's much safer to replace all 6 with updated coils and be done with the problem completely.
__________________
Old 09-28-2007, 02:08 PM   #17
Thanks for the advise. Will replace 6 of them. Should I replace the spark plugs also?
I have 130k miles and I think I have the original coils and plugs.
One thing I noticed is that sometimes it would shake like it's pulling forward and backward when I accelerate when the engine is cold. Once it gets warmed up - normal. I imagine the behavior is resulted from the bad coils.
Old 09-28-2007, 02:09 PM   #18
dot dot dot ...
NmexMAX's Avatar
Points: 47,444, Level: 100
Points: 47,444, Level: 100 Points: 47,444, Level: 100 Points: 47,444, Level: 100
Activity: 64.5%
Activity: 64.5% Activity: 64.5% Activity: 64.5%
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Might as well since you're already in there. And please don't ask why kind/type/brand etc.
__________________
03 SE 4AT 257whp/245wtq
95 SE 4AT 245k Miles
08 Pathy LE 5.6
Stuff for sale: 4" intake tubing/FastCat, HID bulbs, HID Fog Kit,front bearingshttp://forums.maxima.org/5th-generat...t-springs.html
NmexMAX is offline   Reply With Quote
Old 09-28-2007, 02:13 PM   #19
WSH for teh cup
Kyle00's Avatar
Activity: 0.8%
I'd replace the plugs too if i were you, @ 130k they've probably seen better days.
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
