Installed Hawk HPS brake pads and resurfaced front rotors.
Old 09-28-2007, 11:33 AM
myMAXse's Avatar
The pedal feel is very soft and have reduced braking performance. Do I need to bleed the lines?
myMAXse is offline
Old 09-28-2007, 11:55 AM
F---ing Kangaroos
Stardust's Avatar
yes
Stardust is offline
Old 09-28-2007, 12:56 PM
myMAXse's Avatar
I thought bleeding the brake lines was only necessary
if connection to caliper was opened. How else would air get into the brake line?
myMAXse is offline
Old 09-28-2007, 12:58 PM
dot dot dot ...
NmexMAX's Avatar
I'm guessing you did something you weren't supposed to.
NmexMAX is offline
Old 09-28-2007, 01:07 PM
myMAXse's Avatar
Nope... just used a C-clamp to push the caliper piston back.
Kept an eye on the reservoir so as to not overflow.
myMAXse is offline
Old 09-28-2007, 01:11 PM
dot dot dot ...
NmexMAX's Avatar
Check the pad position. It's possible (more so for the rears) that they are off angle and not making full contact on the rotor itself. But, in the end, I think a good bleeding should be on order anyhow.
NmexMAX is offline
vingodine
45
05-21-2016 12:46 PM
03VQMAX
09-25-2015 04:19 PM
homeyclaus
09-03-2015 06:15 PM
MAXSE5SPD
08-23-2015 12:06 PM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Installed Hawk HPS brake pads and resurfaced front rotors.
