3.5 L. oil burner
Old 09-04-2007, 01:32 PM
  #81
nk2k2's Avatar
Originally Posted by Stereodude
Do you have any idea how much much aftermarket rings and the honing / cleaning would cost (assuming I tear down the engine and built it back up myself)?
i would talk to soonerfan. he is planning on doing this when he gets back in the states. i think he has started to buy some of this parts already?
nk2k2 is offline
Old 09-05-2007, 09:13 AM
  #82
MintVQ35's Avatar
Is there any reason to believe that the 2nd set of rings and honed / cleaned-up cylinders won't do the same thing?
Like was already mentioned I would hope you'd select different rings if taking on the task of essentially rebuilding the motor. In my experience with non technically advanced rebuilds, I just did one on a 4.3L V6 from a chevy s10 pickup last year and to re-ring/re-bearing/re-gasket and have the machine work done to the engine alone I believe cost me in the range of $600-700 with me doing all of the disassembly/reassembly.
MintVQ35 is offline
Old 09-05-2007, 10:19 AM
  #83
DasYears
wow, in the butt eh? so they were charging you like 200$/hr?? it seriously only takes like a half hour to hone the cylinders. unless you mean that the shop did the rings, bearings and gaskets.
Old 09-05-2007, 04:35 PM
  #84
MintVQ35's Avatar
Haha no I should have clarified, between me purchasing parts/tools to install and also having the machine work done (turn and polish crank, pressure wash/prime/paint block, install freeze plugs/new oil galley plugs, + crank and rod bearings) was around $700 total!
MintVQ35 is offline
Old 09-06-2007, 10:29 AM
  #85
joebangaa's Avatar
joebangaa is offline
Old 09-06-2007, 05:55 PM
  #86
MintVQ35's Avatar
Originally Posted by joebangaa
Must have been interesting enough for you to post, though. I don't see how engine rebuilding costs can be off topic when someone mentioned possibly rebuilding their 3.5L anyways but hey.
MintVQ35 is offline
Old 09-06-2007, 06:02 PM
  #87
Will's Avatar
Originally Posted by SLVRMAXX
I denied it before but now I think there may be a link between burning oil and 6spd maximas...I think normal shifting (around 2500-3000) may be too much for the car and shifting at 2000 may be better...I have no proof of this but I just want to throw it out there
I used to shift at 2000 all the time few months ago and my oil level was always the same...lately its been 2500-3000 and I see I burned a bit
Not just that, but one thing I notice about this engine vs. my old 3rd gen is that when I fire this baby up in the morning or after just getting back in, the engine revs all the way up to 2000 rpm before coming back down. Most cars just hop up to 1500 rpm. I wonder if the sudden high revs before oil can circulate efficienty affect engine durability and wear or not.
Will is offline
Old 09-06-2007, 06:08 PM
  #88
DasYears
must be a user specific problem, cause i dont have that
Old 09-06-2007, 08:51 PM
  #89
kramarz99
3.5 burns oil, big time...thanks to the God for 5th gen...hihi
Old 09-07-2007, 06:28 AM
  #90
MintVQ35's Avatar
Informative, well documented post you've made here.
MintVQ35 is offline
Old 09-07-2007, 07:01 AM
  #91
JwaxMax99's Avatar
Well, thanks everyone who replied to my original 3.5 Oil Burner post. Some good discussion in here, and some interesting new theories.
Is there any agreement as to in what year vehicle the OB 3.5 problem has been corrected?
JwaxMax99 is offline
Old 09-22-2007, 11:50 AM
  #92
UBMAXIMIZED's Avatar
I have 225,000 kilometers on my 2003 Maxima and it's been losing oil just after warranty expired...surprise eh?
I had heard that the problem may be the valve covers in that the holes get "plugged up". Replacing the valve covers is supposed to solve the problem. However, I discussed with my dealer and he said it works 30-40% of the time. He also told me that in my case I need a new engine. Nissan does not do ANY motor rebuilds.
There is a separate engine part number for automatic transmission Maximas and manual transmission Maximas. The oil loss problem is only with the manual transmission models....according to the dealer. Sounds ridiculous to me.
My Maxima loses a liter oil every 1000 km's....that's a quart every 600 miles.
I'm not sure if using better quality rings would solve the problem. I think it's a design issue. The oil burning will come back in a short amount of time because the motor design is poor. I'd like to know how the new Maxima's and Infinity motors have changed in piston ring design.
At the end of the day, we need a motor rebuild or sell the car.
UBMAXIMIZED is offline
Old 09-24-2007, 02:35 PM
  #93
djbonsu's Avatar
DITTO MAN!!!!....my **** started brning oil @ 93k!!!!.....i told nissan about it but they ignored it!! now @ 115,000 the **** is terrible!!!....i still performs tho and i have a 6 speed. but i can tell when im low on oil vus the timing chains (i think thats the noise) ratlles like crazy!!...whateva man....my next whip is gonna be a bmw! there maintenace might be a lil high but at least they respect there customers!
djbonsu is offline
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
Fbana41
08-29-2016 12:18 PM
05RLS2
04-14-2016 11:49 AM
09maxshawn11
09-30-2015 10:28 AM
Quick Reply: 3.5 L. oil burner
