Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-22-2007, 04:27 PM   #1
pbn85's Avatar
Who has had the ypipe heatshield rattle?
So here it is: I was getting the annoying rattle mostly heard in 2nd gear (not 1st at all for some reason) under slight acceleration. I got under the car and saw that the heat shield of the ypipe was making contact w/ the crossmember. So I had a big chunk of the heatshield welded off...problem NOT solved though. I ended up getting Nissan to put a new motor mount b/c they explained to me that due to unequal support, the heatshield would continue to make contact w/ the crossmember. Fine, that was replaced and the rattle subsided.
But the rattle is still there to an extent. It seems on and off now. My question is who here has had this same rattle and how did you go about fixing it? The ypipe heatshield will only come off when taking the ypipe out. So has anyone does this and did the noise go away? Or my other alternative is to get a performance ypipe that has no heathsield. Any input is appreciated, thanks
__________________
2006 CBR 600rr and 2003 Maxima 6mT
pbn85 is offline   Reply With Quote
Old 06-22-2007, 04:30 PM   #2
retired moderator
irish44j's Avatar
the correct title would have been "Who HASNT had the ypipe heatshield rattle" lol.....
the heatshield on the cat will also rattle, FYI...
irish44j is offline   Reply With Quote
Old 06-22-2007, 04:30 PM   #3
i have the same problem it comes and goes. the dealership says its from using poor quality gas but i cant find nothing better that ultra, lol im just dealing with it until i get the cattman headers with the pipe
TorridoMax is offline   Reply With Quote
Old 06-22-2007, 04:36 PM   #4
pbn85's Avatar
but I want to know WHO has had it so then they can tell me how they fixed it (...or am I missing something lol?)
For some reason my cat has no heathsield
__________________
Old 06-22-2007, 10:33 PM   #5
SHIFT_In2D
Jess's Avatar
Send a message via AIM to Jess
I've got the rattle...
But I only use Premium @ BP along with Cattman Y-pipe
Before with stock Y-pipe the rattle was around 1700 - 1900 RPMS
Now with Cattman Y-pipe it can be heard at 2500 RPMS + louder than stock rattle
So if anyone has fixed the problem let me know. I plan on getting the car on a lift soon so that I can see if anything needs to be tightened or is touching something.
__________________
***Named X5-452***
Birthday: 03/11/03 (Purchase Date)
2003 Maxima GLE - Gray Luster
AMD - Atlanta Maxima Drivers
| Smoked Lights | Cleared Signal | 19" A34 Nismo/Falken 452 | BC Racing Coilovers | H&R TRAK 15mm | Ichiba 5mm |
| Stillen Classic Lip | Stillen FSTB | Injen | NWP IM Spacers | Cattman Y-Pipe | Custom 2.5" & Flowsound Exhaust | Magnaflow Tips |
| 28% Tint | 20th Ann. Pedals + Door Sills | Super White Bulbs | KV3 Eyelids |
Jess is offline   Reply With Quote
Old 06-23-2007, 08:41 AM   #6
pbn85's Avatar
cool...anyone else?
__________________
Old 06-23-2007, 10:16 AM   #7
Got the rattle you're describing but cant locate where exactly its coming from. I hear it temporarily when rpm drops between 2000 and 1800 or so.
maceace is offline   Reply With Quote
Old 06-23-2007, 02:30 PM   #8
Im having that rattle too...Just came out this week....Comes between 1500 and 2000rpm, mostly at 1700.
Anyone has an idead of how to correctly fix it?Its really not loud but it annoys me a lot.
theoutsider is offline   Reply With Quote
Old 06-23-2007, 02:35 PM   #9
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
I would remove the heatshield(s) altogether. Seems logical to me.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-23-2007, 02:52 PM   #10
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
mine rattles but i don't care, i'll fix when i get the chance
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
DrunkieTheBear is offline   Reply With Quote
Old 06-24-2007, 12:13 PM   #11
Quote:
Are there any negative effects to removing the heat shield?
__________________
Hotshot Headers/Cattman Catback/VAFC-II/Zt-2/Progress+Illuminas/Cleared HID's/HID Fogs/G35 Aero Rims/Berk Intake/ES Motor Mounts/STS
Up next - Phenolic spacers
machinehead131 is offline   Reply With Quote
Old 06-24-2007, 02:49 PM   #12
retired moderator
irish44j's Avatar
no, not really. Mine have been removed forever.
Just don't drive through any fields of tall, dry grass or you might set it on fire
Old 06-24-2007, 03:50 PM   #13
I 'll drive a 4x4 for that haha.
__________________
Old 06-24-2007, 04:18 PM   #14
pbn85's Avatar
update: noise greatly subsided recently....I did nothing
__________________
Old 06-24-2007, 06:49 PM   #15
My cat heat sheild (the one between the cat and the ground) some how fell off the day I ordered my y-pipe/test pipe.
I must have been doing aroun 45 on the street near my house when I hear a noise and see in my rearview mirror this piece of metal bouncing off the road. "I hadn't driven over anything so where was this thing from?" I told myself.
Backed up and got out to check it out. Sure enough it said NISSAN on it so I put it in the trunk for later examination.
It had rusted off. Pics to come soon.
spdfreak is offline   Reply With Quote
Old 06-24-2007, 07:01 PM   #16
Heres the pictures of the rusted heat sheild.
For larger pics visit my cardomain.
http://memimage.cardomain.net/member...259440_105.jpg
http://memimage.cardomain.net/member...259440_106.jpg
http://memimage.cardomain.net/member...259440_107.jpg
Old 06-24-2007, 10:00 PM   #17
SHIFT_In2D
Jess's Avatar
Dangerous!! LoL wonder if you've got less noise now?
PS: The heatshield removal doesn't work if you've got an aftermarket Y-pipe/headers, usually they're gone.
But I may know the culprit of my rattles. I forgot that there weren't any gaskets installed. Will have to try and report back.
__________________
***Named X5-452***
Old 06-25-2007, 11:41 AM   #18
DasYears
ive got no heat shield, and no rattle...go figure...............
Old 06-25-2007, 12:47 PM   #19
there are heatshields all the way back for the full exhaust. If you have a rattle other than where the headers and y pipe would have them, then is it ok to remove all heatshields?
__________________
Old 06-25-2007, 01:12 PM   #20
I was thinking about jacking the car up and put on some screws with a washer onto the heatshields so they stop moving....What do you guys think about it?
Old 06-29-2007, 09:51 AM   #21
Anyone wants to share your thoughs about my previous comment?
Old 06-30-2007, 05:53 PM   #22
boondoxmax's Avatar
I have it also. But I've had it on every car I've owned. Damn winters in Boston do a number on it. I only get the rattle in the morning but once the car warms up it goes away. Sometimes i get it when my a/c is on also
boondoxmax is offline   Reply With Quote
Old 07-02-2007, 07:01 AM   #23
Send a message via AIM to jeff5347
Well i wanted to chime in as i had this problem of the vibrating heat shield ( thought it was before checking). When start up or slowly accelerating it would give a slight rattle.
changed oil yesterday and tapped on the heatlshield and it was definitely the rattle i had. So i unbolted it and removed it from the exhaust. So nice now. no noice or rattle or anything. Sound much nicer than before. So yea for me the heatshield was a POS
__________________
http://www.cardomain.com/ride/2547814
AND NO IM NOT A NEWB. BEEN HERE QUITE SOME TIME But thanks for asking
jeff5347 is online now   Reply With Quote
Old 07-02-2007, 08:52 AM   #24
pbn85's Avatar
was this the heatshield over the cat or the ypipe?
__________________
Old 07-02-2007, 09:48 AM   #25
the one i removed was surrounding the y pipe. the top piece is still there. Its somehow held on there fairly tight plus trying to get it out would be a beotch. I removed the bottom section and wa-la. No more vibration or noise,. Now i notice the wire mesh stuff that surrounds the flex pipe is breaking. One thing after another.
__________________
Old 07-02-2007, 10:06 AM   #26
pbn85's Avatar
Quote:
i DEFINITELY feel you on that...every month a new SES light goes on and a new sensor needs to be changed...always something to keep me busy
I'll try taking out the bottom portion of the heatshield...thanks
__________________
Old 07-02-2007, 10:24 AM   #27
its not hard at all. Took me about 5 minutes. There are 4 or 5 bolts that need to be undone and then the bottom piece will come out. When i tried to unbolt mine the bolts were rusted right on there so 2 turns of the rachet snapped the nut and bolt clean apart Good for me. The only one i had a problem with was the one rearest on the shield. Couldnt get a socket on it so twisted and bent it till it snapped off. I think they are 10mm bolts. if they dont fit try a 3/8 in socket. Best of luck and im sure thats your problem. Let me know. Sounds so nice now on start up and takeoff. No rattle whatso ever and you never know what your gonna find under your car. The plastic pans under the front end, i found a wire cutter i was looking for and a mysterious bumping sound id finally gone.
__________________
Old 07-22-2007, 05:36 PM   #28
I never had a problem with the stock Y........
Then I installed a Warpspeed Y this weekend, and removed all heat shields in the process.......
Now there is a violent vibration on acceleration, but it goes away once you get up to speed. I figure it has something to do with the flex in the car as you accelerate. Here's the thread I started earlier today if anyone is interrested......
http://forums.maxima.org/showthread....71#post5841871
__________________
NewfoundlandDud is offline   Reply With Quote
Old 07-22-2007, 07:08 PM   #29
DasYears
banging on the cross-member right around the cat is pretty normal too, you could use washers or just remove it to get it out of the way
Old 07-22-2007, 07:30 PM   #30
Wouldn't that mess with the suspension....and give me less stiffness in the body??
__________________
Old 07-22-2007, 09:24 PM   #31
Also shields are "supposed" to make passing air reach a faster velocity due to higher heat thus resulting in more horsepower. It's probably very minimal.
__________________
LTB stage II, Progress RSB, FSTB, Poly bushings, Progress/illumina, 6th gen brakes, Motegi and T1R,
NisTech is offline   Reply With Quote
Old 09-04-2007, 02:43 PM   #32
yippeeeee i have a rattle too!!! i figured it was a heatshield of some sort, i can only hear it at idle, it rattles when the a/c's on more than without it, so i'm anxious to see what it is so i can tear it off lol, but i need to get under the car IF IT EVER STOPS RAINING when i'm not at work!!!!! grrrrrrr @ fl weather....
Rach
cbr_rachie is offline   Reply With Quote
Old 09-04-2007, 08:00 PM   #33
Quote:
Rach
I had it 2 months ago..
I took the car to the garage because I had a nail in a tire.The guy was fixing it and I asked him if I could take a brief look because I had a little rattle between 1300 et 2000rpm.Took me 10 seconds to figure out what it was.Putted a bolt and a nut to get the two h-shield sandwich back together.Stopped making the noise right after that!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
