06-03-2007, 06:24 PM
Points: 11,352, Level: 70 |
P1800 - VIAS Control Solenoid Valve Circuit Open
Ok, so I removed the VIAS unit a couple weeks ago and used a DIY block-off plate to see if the mod the Altima guys had been doing is worth trying. Well I did not like the loss of low-end when driving around town and did not really notice any high end improvement, so I put the VIAS unit back in later that day.
Ever since then I have been getting the following code...
It does not set off the CEL, but the code is in memory. I've erased the code with my scanner on multiple occasions, but the code keeps returning. I have also noticed that my car appears to be sluggish now. WOT seems to take forever to get in the upper RPM range now.
Anyone have any more details to what this means or what steps I can take to see what is causing this to occur.
__________________
Custom GAB Mod - Custom VIAS Block Off Plate - Custom Short Throw Shifter
Ralco RZ Performance Pulley - 2.5" SS Cat-Back Exhaust - TuningPros Springs w/Sensen Struts
17" 6-spoke G35 Coupe Rims - 245/45-17 Rubber - 5th Gen GLE Taillights
06-03-2007, 06:28 PM
dot dot dot ...
Points: 43,405, Level: 100 |
Check the harness and verify it is plugged in and still functioning. Also, try checking your vac tubes to verify that they are not reversed.
06-03-2007, 06:33 PM
Quote:
I'll check the harness to see if loose, but I did not have to disconnect that. All I had to do was disconnect the vaccuum line that goes to the VIAS unit and plug it with a screw.
When I swapped the unit back in, I removed the screw used to plug the line and put the line back on the unit.
__________________
06-04-2007, 12:09 PM
Update: I read over the FSM for testing procedures. Checked the connector and it was fine, then pulled the fuse that according to FSM supposedly controls the solenoid to see if blown. It was not, so I put it back in.
Went inside and went to bed.
Woke up this morning, checked codes on my scanner and P1800 code was gone. I drove 60 miles to work, then at lunchtime, drove around and checked codes again. P1800 showed up in PENDING DTC's, BUT driveability issues are gone????
06-05-2007, 06:08 AM
Super Moderator
Points: 36,133, Level: 100 |
Any updates? Sounds like you may have fixed the open circuit, since the VIAS is working again (based on your driveability comment).
06-05-2007, 09:54 AM
Quote:
Well, I haven't scanned the DTC's since yesterday afternoon. On my way home last night I did have a "spirited" drive home, so I will check the DTC's after work today and see if the code still exists.
I am wondering if the solenoid and/or valve is not working properly causing the random code and since it is a pending code, it has to occur so many times before it is considered by the ECU as a saved code (issue).
__________________
04-16-2008, 07:41 AM
Any updates on this? because i have two!! of these codes.
One is P1800 AND one is P1800 Pending.
What does it mean when it says "pending"?
__________________
We're always together
03-08-2009, 02:32 PM
Bump? Is there a part you have to replace for this P1800 code?
__________________
No more I35
03-08-2009, 03:36 PM
If your vacuum hoses are fine, replace your VIAS. It's right next to the throttle body.
03-23-2010, 12:26 PM
hi does anybody have a picture of this valve or diagram w/ exact location... i got a CEL also today and it is a P1800... i would like to fix it myself if possible thanks
03-23-2010, 04:58 PM
I borrowed this shot from another thread on the block off plate/VIAS delete.
here's the link, some good info throughout the thread
http://forums.maxima.org/5th-generat...r-5-5-gen.html
__________________
Sig. Rendered By Rochester
Llumar 20% /FSTB /SRI /BPI Stack /*17 Adv. /ATE Slotted Rotors & ATE Pads / 6000k HID Fogs /2x10 Subs & 1000w amp. /Michelin 235/45/17 /Budget B pipe & Vibrant Exhaust /LED Interior Lighting /Chrome Gauge Rings /Viper Security /F&R ES MM & Sub Bushings /Sm Markers /KYB GR2's-S-Techs /Cus block plate-VIAS del /NWP Spacers /Stillen Lip & Rear Valiance
Open to all Connections On LinkedIn
Maxima's FSM's
Owensfamily TSB's
Nissan "How To"
08-15-2010, 03:04 AM
sorry to be a noob but what does it mean to cap it off? like to have it cover with something or remove it? as to remove the vacuum tank
11-06-2010, 07:09 AM
Hi Guys,
Does anyone know the model number for the VIAS control solenoid?
Thanks for the postings as they are very helpful.
10-30-2011, 10:17 AM
my car has the same issue....i have to get it inspected but 2 cose came up:
p1800 - solenoid valve
p0345- cam position sensor
so should i just change both? because my battery connection n everythin else is good
02-17-2013, 12:32 PM
Anyone know where I can purchase the VIAS Control Solenoid Valve. I would prefer not to purchase from the dealership.
MaximaOrg
Nissan Maxima
Paid Advertisement
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
