Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 05-30-2007, 06:37 PM   #1
On the pedobear bandwagon
jdmaxima89's Avatar
Send a message via Yahoo to jdmaxima89
Buzz noise after engine is turned off...
I did a quick search and couldn't find anything... but I have a noise after I shut my car off that lasts for about 5 seconds. I had my dad check it out (technician at the dealership...) and he found a service bulletin that only applies to auto trannies in maximas built before October 2, 2000 and it is titled "Buzz noise after engine is turned off". I saw a link called "buzz noise" in the service bulletin sticky, but it's dead. I have the bulletin printed out, I'd be glad to provide it when I get home if you want to see it.
My questions are, why in the h*ll do we have electronically controlled motor mounts? Never heard of that before.
What are the negative things that will happen if I don't replace the motor mounts? I can't tell any difference with them being bad... it just makes that dang noise when I shut the car off.
My dad doesn't think that I NEED to replace them... but I don't want anything to happen. My cost will be about $300 in parts. Thanks for your opinion.
(If this has been discussed many times before, you have every right to flame me to no end... )
__________________
jdmaxima89 is offline   Reply With Quote
Old 05-30-2007, 08:42 PM   #2
Maybe your noise is different than mine but if you think there is something wrong with your engine mount, go have that checked asap.
See my story here: http://forums.maxima.org/showthread....487272&page=68 (post #2037)
Read some pages after, you'll see some other stories about burned engine mounts.
In my case the engine mount fried the ECU and I had to pay 1900$ to fix it.
mtl-maximus is offline   Reply With Quote
Old 05-30-2007, 09:03 PM   #3
Found NTB01-010:
http://www.nissantechinfo.com/nissan...RefNo=NTB01010
In my case the engine mount fried the ECU.
If there is a TSB about this, should the dealership fix the issue for free?
Old 05-30-2007, 09:33 PM   #4
jdmaxima89's Avatar
Nope... TSB doesn't mean recall. My dad said that when that bulletin came out, they probably offered replacement mounts at a reduced rate... but i'm stuck spending about 300 bucks for the two parts (as opposed to 400 for regular customers).. so it's that serious of a problem that it fried the ECU!?!?!?
I was just going to live with the noise... but maybe I won't be able to do that like I had hoped.
Old 05-31-2007, 07:18 AM   #5
The guy at the dealership said this was an issue with Maxima 2k and 2k1; engine mounts burning the ECU. The issue was fixed after 2k1 model.
Also the ECU I have now has a different P/N than the one I had before.
Old 05-31-2007, 08:41 AM   #6
Same problem I had about a year or 2 ago! I would shut the car off and there would be a buzzing noise for about 3 seconds. I used to notice all the time when I shut the car off. Then all of a sudden one day last year it totally stopped making the noise! The engine and ecu has been fine ever since so I figured maybe it just fixed itself unless it is just totally dead! Since I haven't heard the noise I figured I would be unable to take it to the stealership as they would probably say nothing is wrong since they do not hear any buzzing noise! I do have an extended warranty til 100k or Oct '08 and currently the car has 90k, so if the noise comes back maybe I should take it to the stealership!
Good luck with your scenario jdmaxima89!
__________________
BLUEMAX01SE is offline   Reply With Quote
Old 05-31-2007, 10:08 AM   #7
Had the same problem... front mount would make noise for 3-6 seconds and it would stop... one day it started making noise and it would never stop ;-) so i unplugged the harness.. Called my friendly Nissan tech, he told me its $300+ to get it replaced (ouch) , and he said that if i don't want to replace it i can drive with it unplugged. it was over a year ago.. ;-) its still unplugged..
piotroosh is offline   Reply With Quote
Old 05-31-2007, 11:33 AM   #8
jdmaxima89's Avatar
Hmmm... I may consider unplugging it then. Thats the cheapest way lol.
Old 05-31-2007, 12:24 PM   #9
Yup... I don't see any side effects of doing that.. so it is the cheapest fix possible ;-)
Old 05-31-2007, 01:05 PM   #10
jdmaxima89's Avatar
Quote:
you didn't even get a check engine light?
__________________
Old 06-01-2007, 07:22 AM   #11
nope. confirmed by nissan tech that this will not cause CEL.
over a year now... everything is good.
Old 06-01-2007, 09:34 AM   #12
jdmaxima89's Avatar
Cool... that's probably what I'm going to end up doing then. My dad said that the main purpose of the electronically controlled engine mount is that it pretty much holds the motor "tighter" while you are idling. That's why we hear it when we are either slowing down to a stop, or shut the car off.. or in my case, both.
__________________
Old 06-01-2007, 04:52 PM   #13
With the harness unplugged, would it leave the engine mount bushings in the 'soft/loose' state?
I looked over the FSM diagrams (2001 FSM Pages EC-625 to EC-628) and interpreted it as (could be wrong):
Below 2000 RPM, engine mounts: Soft
Above 2000 RPM, engine mounts: Hard
I was going to unplug mine too, but thought it may leave the mounts in a permanent soft state. I haven't heard the noises, but would like to keep them unplugged to keep the ECU safe.
A33Black is offline   Reply With Quote
Old 03-16-2008, 07:16 PM   #14
kss
I have the exact same issue, what is the long term ramifications for leaving the harness unplugged if any?
KSS
kss is offline   Reply With Quote
Old 03-16-2008, 07:37 PM   #15
How do you unplug them, where is the connector for them?
And do the 5 speeds have electronic mounts?
__________________
We, the willing, led by the unknowing, have been doing the impossible for the ungrateful. We have been doing so much, for so long, with so little, we are now qualified to do anything with nothing
ohannon7 is offline   Reply With Quote
Old 03-17-2008, 04:27 PM   #16
Send a message via AIM to 00MaximaGXE
Who cares about the buzzing sound, it doesn't bother me...Plus I don't need a bracket in my engine if I got on it hard
00MaximaGXE is offline   Reply With Quote
Old 03-17-2008, 05:08 PM   #17
The buzzing sound indicates there is a bigger issue, its not the sound itself I believe. No one wants their car to catch on fire
Old 03-17-2008, 07:15 PM   #18
Quote:
How would it cause a fire?
Old 03-17-2008, 07:24 PM   #19
EDIT: If it continued to keep buzzing got it...
Old 03-17-2008, 07:57 PM   #20
Klipsch > All
ChevelleRH's Avatar
5spds don't have electronic motor mounts.
I have a buzzing sound after i turn the car off, and a squeal at around 2k rpm (where it apparently stiffens) when accelerating. I cant figure out the cause of either...but apparently they are unrelated.
I have just replaced both lower mounts with ES inserts with no change in these sounds (ES bushings are awesome otherwise)
Therefore the sound you guys are hearing could possibly be from something else.
__________________
|Cattman Y Pipe|Progress RSB|Stage II LTB|G35 17s|GAB|FSTB|ES Misc.|
ChevelleRH is offline   Reply With Quote
Old 03-18-2008, 08:51 AM   #21
Quote:
thanks
__________________
Old 03-18-2008, 03:18 PM   #22
Wants the EVO X
MyownNismo's Avatar
I had my front one replaced. Mine started making a whining noise once you reved the motor. I unplugged it til I got a new one. I get the buzz noise still but my rear is still fine.
__________________
Custom intake w/Apex-i filter, Cattman headers & Cat-back, 350Z RAYS wheels 18X8.5 33 offset w/ Falken Azenis 615's, 2001 AE AT w/ Stage II VB, ADV Timing 17 degrees, Stillen 2 piston BBK W/ Coleman Racing 2pc Rotors(front), Racing Brake Rotors w/Hawk HPS pads (rear), Stillen Bodykit, VIS CF Invader Hood, Smoked 2k2 Headlights, Progress Springs, Tokico illumina's, Stillen RSB, FSTB.
MyownNismo is offline   Reply With Quote
Old 03-18-2008, 07:33 PM   #23
Send a message via AIM to MADE
Actually I have a 2k2 SE 6MT and I have a buzzing(or distance horn) after I shut my engine off but I figured it was a capacitor or something. If this is an A/T problem only has anyone else with a M/T heard a similar sounds.
MADE is offline   Reply With Quote
Old 03-18-2008, 07:56 PM   #24
I thought i have heard the noise too. How loud is it?
kind of like when the buzzer for an older dryer goes off?
__________________
Old 03-18-2008, 10:15 PM   #25
Send a message via AIM to mist max2000
mine has like a buzz buzz tick tick buzz and lasts about 3-5 seconds.. shes been doing it forever like a year + and have had no problems.. so idk
mist max2000 is online now   Reply With Quote
Old 03-19-2008, 04:07 PM   #26
same here most specially whens its cold. it happens everytime i shut off the car or rev it.
__________________
UNITED CUSTOMS Wheels/Tires and Accessories
25303 Sorters Road
Porter, TX 77365
Phone: 281-577-9041
s2kver02 is offline   Reply With Quote
Old 03-19-2008, 07:50 PM   #27
Video Of the sound
http://smg.photobucket.com/albums/v7...t=S5000039.flv
http://smg.photobucket.com/albums/v7...t=S5000040.flv
Old 03-19-2008, 07:57 PM   #28
kss
Does anyone know how to unplug the harness to the motor mounts so it doesn't make this noise?
thx
kss
Old 03-19-2008, 10:05 PM   #29
i always thought it was the electronic motor mounts like correcting something..
Old 03-20-2008, 08:05 PM   #30
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
Quote:
the aircon does make a noise when you turn it off or turn your car off with it on.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
jasonmax is online now   Reply With Quote
Old 03-21-2008, 03:05 PM   #31
