Fuel Pump Relay Location
Old 05-27-2007, 11:58 AM
Black02Max
mmendezm3power's Avatar
Sorry for the noob question, but does anyone know where I can find the Fuel Pump Relay on the 5th Generation (2002, 6sp) Max? Does the 5gen have a Fuel Pump Relay? I found the Fuel Pump Fuse but not the Relay.....
thanks,
Martin
mmendezm3power is offline
Old 05-29-2007, 08:38 AM
Black02Max
Old 05-29-2007, 10:12 AM
Sexier Than Simpson
Bufflomike's Avatar
thanks,
Martin
http://forums.maxima.org/showthread....uel+Pump+Relay
Could have just searched but I assume it is in with the realys under the hood.
Bufflomike is offline
Old 05-29-2007, 10:15 AM
Eric F's Avatar
It is with the relays near the driver's side headlight. It's one of the front relays.
Eric F is offline
Old 05-29-2007, 04:57 PM
Black02Max
Which one? "RAD FAN 3", "INHIBIT", "MOTOR" "ENGINE CONTROL" "RAD FAN 2" OR "RAD FAN 1"?
Shouldnt it say somthing like "Fuel Pump Relay" ? .... i need a manual for this.
Old 12-29-2010, 11:40 AM
Coodawg's Avatar
I know this is an old thread, but did you ever find the relay? I can't find it on my 2001 anniversary edition.
Coodawg is offline
Old 07-15-2012, 04:50 PM
N0Lo's Avatar
ok... so I dont see this question was ever answered and now I am trying to find the fuel pump for my 03 max. Help anyone?
N0Lo is offline
Old 07-17-2012, 03:02 PM
youdoofus's Avatar
i think im having the same issue. my car cranks and begins to catch, but the second that ignition catches, it dies. sounds like it might not be getting fuel. and thoughts?
youdoofus is offline
Old 07-19-2012, 04:18 PM
N0Lo's Avatar
the location of the fuel pump relay for an 03 is right under the hood release to the left of where your foot rest is. you will need to remove the plastic cover, a sticky rubber cover and a metal bracket . im also having issues with my 03 it wont start so i have been thru this process i put a new pump checked relay n fuse still no start. i sprayed starting fluid into the intake manifold and the car started which led me to believe is a fuel system problem and not electrical. does anyone know if 03 use fuel pressure regulator and where is it located?
N0Lo is offline
Old 06-01-2015, 08:40 AM
operat0r's Avatar
Originally Posted by N0Lo
the location of the fuel pump relay for an 03 is right under the hood release to the left of where your foot rest is. ....?
THANKS! wish me luck!
operat0r is offline
Old 06-01-2015, 10:23 AM
DennisMik's Avatar
What is the problem with the car? Many people have a car not starting and blame the fuel pump. 98% of the times it is not the fuel pump. if the engine is not running, the ECU will shut off the fuel pump. When you first turn the ignition key on to start the car, the fuel pump will run. If the ECU does not get a signal from the REF crankshaft sensor within a few seconds, it shuts the pump off.
DennisMik is offline
Old 10-27-2015, 12:05 PM
beechmon's Avatar
Anyone seem to solve this part of it? i know i've been posting a bit, but just trying to search for something... I put more gas in, and it works... floater problem?
beechmon is offline
Old 10-25-2017, 01:13 PM
supersports10's Avatar
My daughter has been having a problem when car is running just stops! No fuel, no brakes, no lights, power steering gone... She is able to pullover and restart like nothing happened? Has done this twice now?!? Fuse replaced for fuel pump 1st time, 2nd time replaced fuel pump relay hopefully that is the problem? Anyone else with a similar situation? I will keep you posted, thanks....
supersports10 is offline
Old 10-25-2017, 02:38 PM
SubwayVQ's Avatar
A fuel issue is rarely caused by the relay/fuse. If it dies and restarts again, that’s typical syptoms of a bad fuel pump.
SubwayVQ is offline
Old 10-25-2017, 03:45 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Sounds like a bad cam sensor (normal problem).
Child_uv_KoRn is offline
Old 07-20-2023, 04:43 PM
Wellschick09's Avatar
Incase you never got your answer
ok... so I dont see this question was ever answered and now I am I trying to find the fuel pump for my 03 max. Help anyone?
I'm not sure how old your question is or if you ever got your answer ,but your fuel pump is part of an assembly in your gas tank.
Wellschick09 is offline
Old 07-21-2023, 12:08 PM
His question was posted in 2012, over 10 years ago.
The Wizard is offline
Old 07-21-2023, 01:17 PM
WelcomeToCostco's Avatar
Had this happen a couple of months ago. Replaced the fuel pump relay since there would be no output voltage when the power to its coil was applied. Then later that day the fuel pump also acted up. It might run for 15-45 minutes and then stop working. Replaced the pump as well.
The fuel pump relay is behind the kick panel to the left of the drivers feet. The panels comes off pretty easily and then you need to unscrew the bracket that holds the relay.
The fuel pump is located under the rear seat and under an access panel inside the fuel tank.
No smoking or sparks when you have that open
WelcomeToCostco is offline
Old 07-21-2023, 06:05 PM
^You should clarify if it's the blue relay or the brown relay.
Old 07-21-2023, 07:11 PM
Probably best to identify it by the wiring vs color of the body since aftermarket relays are often not the same color as OEM.
Last edited by WelcomeToCostco; 07-22-2023 at 04:34 PM. Reason: added wire color decoder chart
Old 07-21-2023, 11:58 PM
While helpful, you should still share which color relay is the fuel relay. It may prove helpful to others. Not everyone is capable of reading and understanding these diagrams pulled from the FSM.
Old 07-22-2023, 12:10 PM
This might provide an accurate clue for OEM fuel pump relays.
bonez_tmac
01-10-2015 12:46 PM
Gle03Max
26
11-30-2013 05:59 PM
Tatanko
08-23-2005 03:11 PM
Grisadiche
12-01-2003 10:10 AM
Quick Reply: Fuel Pump Relay Location
