Can someone send me the instructions for removing headlights with AntiTheft kit?
I bought my Max in Conneticut, it has Data Dots and I assume it has the AntiTheft Kit. I removed the top two bolts and popped the headlight out of the 'pressure tabs' but it doesen't seem to want to move much more, so I assume I have the anti theft brackets.
I know people do not like to post info on how to remove the headlights so I would appreciate it if someone could e-mail it to me. Also how much extra work am I looking at to get the headlights out?
hey man, there are 2 large bolts way below your headlights. You need to un clip the bottom dirt shield, from the far sides of the bumpers right under the lights. there are 2 bolts, one you can see which is right next to a FRAME bolt,(dont loosen that one). and there is annother bolt up allong the "wall" that you really cant see, I just did my angeleyes and cleared them out so if you have any questions feel free to call, 4844677121, good luck man.
Once thoes are out then you just simply pull the lights straight out.
The Frye
09-02-2021 11:03 AM
Hdnseek
09-09-2015 05:55 AM
