Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 05-08-2007, 08:01 PM   #1
Points: 7,470, Level: 57
Points: 7,470, Level: 57 Points: 7,470, Level: 57 Points: 7,470, Level: 57
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Fuel pump going out?
When I try to start my 02 6 speed after it's been sitting for more than a few hours, the fuel pump doesn't turn on right when I turn the key on. The engine will turn over, but it won't start because the fuel pump isn't going. As soon as it's started, there is no hesitation at all. The fuel pump works fine once it starts going.
Sometimes it will turn on after the key has been turned on for a few seconds. Sometimes it takes up to 30 seconds. The fuel pump isn't louder than normal. I have to turn the radio off to hear it go on.
Is this the fuel pump going out, or is it a relay or something that is taking a while to kick on when it's cold or hasn't been powered in a while. Today it was 80 degrees outside and it still did the same thing, so the outside temperature doesn't seem to have anything to do with it.
Has anyone else experienced this?
Eric F is offline   Reply With Quote
Old 05-09-2007, 03:28 AM   #2
schemes on chicks in his max.
Points: 6,822, Level: 54
Points: 6,822, Level: 54 Points: 6,822, Level: 54 Points: 6,822, Level: 54
Activity: 0%
Send a message via AIM to MaximaInCT203
just go out, buy a new one, and replace that bish!!!!!!! If you are accurately describing your situation, your fuel pump is damn near gone bro....ur lucky to even be able to start the car actually! Goto the how-tos section for helpon replacing the fuel pump...its not hard at all though
MaximaInCT203 is offline   Reply With Quote
Old 05-09-2007, 04:10 AM   #3
Activity: 0%
If the fuel pump was going out, it seems like there would be at least some hesitation while driving. They usually sound noisier than normal when they're on their way out too. Mine isn't any louder than a normal working fuel pump. It seems like it is more likely to be a relay than the pump itself. If I don't find anything else out, I'll replace it this weekend.
Old 05-09-2007, 12:27 PM   #4
Points: 5,903, Level: 49
Points: 5,903, Level: 49 Points: 5,903, Level: 49 Points: 5,903, Level: 49
Activity: 0%
test the voltage on the wire to find out when it's getting power and when the pump is kicking on. If it's not getting power immediately then follow it to the relay.
brusk is offline   Reply With Quote
Old 05-09-2007, 06:20 PM   #5
Activity: 0%
Sorry for the noob question, but where is the DIY section on the board? Do I have to pull the gas tank to change the fuel pump? It sounds like it's coming from under the hood.
Old 05-09-2007, 06:57 PM   #6
wat
AceofSpds's Avatar
Points: 9,174, Level: 64
Points: 9,174, Level: 64 Points: 9,174, Level: 64 Points: 9,174, Level: 64
Activity: 0%
Send a message via AIM to AceofSpds
Quote:
Search for Fuel filter change, there are allot of threads on that and the fuel filter and pump are together. They are in the fuel tank, but you can access it through under the rear seats.
AceofSpds is offline   Reply With Quote
Old 05-09-2007, 07:10 PM   #7
Quote:
10 char
__________________
Quote:
Originally Posted by BMWHIGH1
Yup I Read Somewhere That When You Let Your Car Idle Its Actually Getting Zero Miles To The Gallon.................
5thgenmaxima is offline   Reply With Quote
Old 05-10-2007, 08:08 PM   #8
Activity: 0%
Ok, the other morning, it wouldn't start at all. The fuel pump isn't ever turning on anymore. How much voltage should the pump be getting? When I first turn on the key, it gets about 5 volts for a second and then goes down to 2 or 3 volts. With the engine cranking, it gets about 1 volt. I'm suspecting that the fuel pump is bad, because it isn't trying to turn at all.
Now, where is the best place to get a reasonably priced pump and fuel filter? The stealer wants around $300 for a new pump.
Old 05-11-2007, 07:50 PM   #9
Activity: 0%
The relay was bad. I swapped it with a headlight relay and it started right up. Now I need to go get a new relay.
Old 05-11-2007, 08:27 PM   #10
yup.. FYI the pump should be getting source voltage. or about 12 for a second or two after key on engine off, around 11 during cranking and 13.5-14.2 while running
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
