Need advice buying ECU
Old 05-09-2007, 01:39 PM
Nomad's Avatar
Ha ha this one wasn't discussed (used a free search).
To the point:
I need to replace my ECM (ECU) unit after it's burned on me. Problem described in this topic: http://forums.maxima.org/showthread.php?t=504874
I have an option to buy either rebuilt or junk yard ECU. Price is approximately the same but re-builders offer 1 year warranty. Also my ECU is kinda rare 2001 w/TCS so I'm leaning towards rebuilt unit.
Let me know what you think guys?
Nomad is offline
Old 05-09-2007, 01:45 PM
brusk's Avatar
Does it work at all? do they have serial numbers on them. I know on older cars I'd to the test drive fix. You know test drive one and swap the parts make the dealer cover it. But if there's serial numbers that can be traced back or it doesn't work at all that wouldn't work.
brusk is offline
Old 05-09-2007, 01:51 PM
Nomad's Avatar
Current ECU works fine, but it's unable to control Idle speed valve solenoid so no Idle. Heh, can't do it by myself I don't have $3G tool on me. I'm not certain about serial #, however, it is a certain part number year, TCS/ no TCS.
Nomad is offline
Old 05-09-2007, 09:42 PM
Willing to learn
oldngivout's Avatar
Well, whichever one you choose to install, the car won't start anyway until the dealer programs the keys. So you'd better give the old bad for good ECU switcheroo a second thought.
oldngivout is offline
Old 05-09-2007, 09:51 PM
A33 VQ30DEK's Avatar
that's an easy fix though. Just change the ECU at the dealership and they'll program the key on the spot.
A33 VQ30DEK is offline
Old 05-10-2007, 11:53 AM
Nomad's Avatar
that's what I was giong to do. My friend works at stealership.
More opinions on ECU?
Thanks to all who's responded.
Nomad is offline
Old 05-10-2007, 12:38 PM
sooner02r1's Avatar
Technosquare?? Aren't they a stand alone ECU?
sooner02r1 is offline
Old 05-10-2007, 01:39 PM
BIGMAX19's Avatar
i bought an ECU from a junkyard for $100... no problems... just make sure that you have the same production date and you'll be fine... I did a six speed swap and bought a six speed ECU and i have absolutely no problems... best route and much cheaper... all i had to do is get it reprogrammed...
BIGMAX19 is offline
Old 05-10-2007, 06:52 PM
monty31's Avatar
When I replaced mine there were hundreds of matches on car-part.com. Most of them come with a warranty too. It's fairly rare to have the IACV burn-out problem so you should be fine with buying a used one. I saw many traction control ECU's available when I was searching for my 01.
Oh and the re-program for the keys and all that was ~107 for me.
monty31 is offline
Old 05-10-2007, 08:48 PM
I just received my ECU today.. after 2 years of doing my 5spd swap. i got it for 150 dollars on carparts.
Old 05-11-2007, 12:56 PM
Nomad's Avatar
Technosquare does only programming.
I was able to find only one (reman) in my area. $250.
I consider junk yards don't ship parts?
Nomad is offline
Old 05-11-2007, 03:20 PM
Toolie
knight_yyz's Avatar
i'd say get the rebuilt one just in case. a few bucks for a warranty never hurts
most junk yards I talked to in the past will ship UPS.
knight_yyz is offline
Old 05-11-2007, 04:00 PM
Nomad's Avatar
I'm back from car-part.com no unit for reasonable price nationwide.
waiting for quote on a BN unit. If this is not a case I'm leaning towards re manufactured ECM
Nomad is offline
220k+ A32
09-22-2015 03:08 PM
QueensMAX
09-15-2015 04:14 AM
lux97Max
09-11-2015 01:12 PM
mix master
09-07-2015 08:28 PM
mix master
09-04-2015 05:50 PM
Quick Reply: Need advice buying ECU
