View Poll Results: yes or no.
get them
27.08%
dont get them, cheasy
35
72.92%
Voters: 48. You may not vote on this poll
MAF replaced, feels like new!
#41
maf
I finally took the car to the dealer and they seemed to replace the MAF sensor because the car runs alot better now. The only thing is i think they didnt replace the whole assembly because theres still alot of dust on it, What it looks like they replaced was the little piece with the plug. Did i get screwed or is this fine? I just wanted to know because i think the car should accelerate slightly faster than it is now. Any im still happy its running alot better now than before.
#42
#44
Originally Posted by ColdSHO
how does one reset once a new maf is put in, i just poped in my new 01 into my 00 a few mins ago
#45
Originally Posted by instil
did you pay closer to $100, or $500. If you only paid around 100 for the part, you just paid for the sensor (little piece wit the plug). Thats the important part anyway....you dont need a whole new housing for that little sensor if yours is not broken or cracked
#47
Originally Posted by Lontar1
I paid 83 for the whole assembly......
Imax00 has a 2000, so he has to buy the entire maf assembly for a 2k2+ (MAF housing,WITH wire sensor element) for like $400,$500 i forget how much off hand. OR.....They bought the less expensive part,and mixed and matched pieces from his current part,and a new one.
Thats the MAF story in a nutshell from what i understand from these 18 posts about it.
#53
MAF Bliss
Just installed the Injen CAI - looks nice, didn't do a lot of good tho.
Step on the gas - sluggish as hell. Could be a faulty MAS..
Have the Stillen Y-pipe being installed tomorrow.
Called Dave B - great guy, spent lots of time with me, gave me some sound advice and I picked up the update MAF for my 2k for $83. Plus he ships with Fedex so us Canadians don't get gouged for customs & taxes (like UPS does).
Will let you know how it go'd. Thanks for the advise all.
#55
Yeah my max has 78k on her and im putting an injen intake on her soon since i just got the heat shield/splash guard, so i should just buy a 2001 MAF sensor (for my 2000), put it on while putting on the intake. Then just disconnect the battery for a few hours and she should be good? Is that all I have to do?
thanks
thanks
#57
Canadian ripoff
I had the same symptoms as above and had the MAF diagnosed as the problem. The dealer charged me 599.95 Canadian for the part, plus the ECM reprogram (before I read this forum - duh for me)
Is that unreal? I'm taking it up with Nissan Canada, as they apparently set the price.
Has anyone else dealt with Nissan Canada?
#58
Sorry newbie post
2K SE, MAF part# is 22680-2Y001
#61
I called my local Nissan dealer and was quoted AU$950 (approximately US$1250) for the MAF. Obviously this isn't going to happen, is Dave B a member of this site? I might have to look into getting one shipped from America, even with shipping costs it'd be cheaper.
#64
Hmm I do not seem to have the OP's symptoms per se, but I have a 2000 SE that gets really high RPMs when accellerating up from stop to 60kmph... RPMs will rise to nearly 5000, the gear will change and the car will lunge forward as well... My hypothesis is slipping transmission but could the MAF be a factor as well?
#65
bad maf - threw a p1102 code - maf sensor range/performance problem
yep, my maf finally blew...
called local nissan dealer and they quoted it me $540 US.
this is elk grove nissan of elk grove, california...(next to sacramento, ca)
#66
after changing my coolant last night i think my 2nd maf took the dump
stutter at cruise, some weird power loss at 3-4k and the nasty power loss at 2k when OD is on; almost feels like it is trying to shift. idles perfect.
yes the CEL is on. i unplugged the battery and will go hook it up in a few and see if it is still there. then it is code pulling time if it persists.
but my first maf died at an instant too so i shouldn't be surprised about this one dieing in the driveway
nissan maf < lowest imaginable scum in the entire universe
#67
Originally Posted by ses_again
Dealer told me it had to be reprogrammed because it had corrupted itself due to running with bad MAF and/or O2 sensor for a month or so.
LOL... thats the funniest **** ive ever heard.
#68
#69
Hi thanks guys I saved a bundle after reading the forum. The other day my 2001 Maxima SE 20th Anniversay was stalling and could not rev. I did a tune up and spark plug a while back and it still didn't solve the knocking problems, mainly I guess from low octane, but I switched back to premium afterwards and still had probs.
The car would rev past 2000 rpm stutter and I had the dealer check it out in Markham Villiage Nissan. They found out the car was running lean and had a faulty or "dead" MAF and it would cost me CND $770 for parts and labour. The other problem I was also having was DRL was not working and only one headlight was working and it was $300-ish. Holy cow! A MAF for $600 bucks, so I see on the forum pointing out the cost of a MAF and Courtsey Nissan has it for $89.50 and $45 UPS Express, I am saving myself a lot of money for the same part (and number). Too bad they don't have the DRL unit, states don't have DRL.
So thanks so much guys, MAF for about $200 CND, and this is the whole unit replacement, oh and $85 CND for 1 hours labour installation. The whole thing would of cost me $1200 with the diagnostic fee but now it is about half!
#71
Originally Posted by Parker Woodruff
I have a question about replacing the MAF:
If I buy an Injen CAI or a FrankenCar WAI, will that replace the MAF, or will the factory one still be installed?
#73
2002se 6spdmax
I HAVE A QUESTION FOR ANYONE WHO HAS DONE THE 2001 MAF SWITCH TO THEIR 2002 MAX, FIRST WHAT ALL DO I NEED TO BUY IN ORDER TO DO THIS UPGRADE, AND SECOND AS SOMEONE ALREADY MENTIONED DO I JUST NEED TO RESET THE ECU AFTER I INSTALL IT, OR TAKE IT TO THE DEALER FOR ADJUSTMENTS, IN OTHER WORDS IS GETTING YOUR ECU REFLASHED THE SAME AS RESETING IT?
#74
You need this part number 22680-2Y001. Then you need to take the temp wire from your old MAF and install it on the new one. I soldered my in, but it clips right on, just make sure it fits nice and tight. I then reset the ECU. I haven't done the ECU flash thing yet, but everything seems fine. I will get it done when I can. Also, take your caps lock off since it means you are shouting...
Pedro
Pedro
#75
2002se 6spdmax
Hey wasup man thanx for the reply, your anwers were a big help, hey i have one last question do you absolutely have to get a reflash done? I mean cause I was just planning on doing what you did just reseting the ecu, the thing is I don't want it to affect my 1/4mile time or my high end torque if I don't get the reflash done, if you could hit me up and let me know what you know about this thanx bro
#77
is this reflash/update done at the stealer? i know this is an old topic but i never researched it much because...it just hasn't happened to me UNTIL TODAY!!!! i wish my car pops a code already, but my MAF is DEFINITELY dead, as soon as I started my car today I could tell something was wrong with the wacky idle. then later when i was driving, and i tried passing someone and gassed it a little, my car couldn't decide whether to shift into 2nd or 1st, and I got really scared because I thought my tranny was dead, and then when the revvs were climbing, i got this huge hesitation at 4~4.5k. came home, checked my tranny fluid, it's actually a lot cleaner than i thought...so I'm pointing fingers at the MAF. i'm gonna see if a local stealer will be cool enough to warranty it, if not i guess i'll have to go the 01 route... sorry to take it OT but i still asked a question lol
#79
I never had problems at startup, but i had the same problem when i tried to accelerate, the car would stutter a bit and then pick up speed, and i also felt a loss of power and i noticed the engine was idling rough, the engine noise was higher. I thought that i had MAF problems as well. I checked the Air Filter, MAF and the transmission oil and everything looked as if they were new. I just did a ECU reset (got the procedure from the stickies) and the difference is unbeleivable. The engine runs smoother, noise reduced and the shifting is buttery and the A/C is working great too. It has been over a month since i did this and no problems so far. I wish i had done this earlier.
My car is a 2003 Sheer silver GLE, auto transmission with 41000 miles on it and it feels almost like new after the reset.
#80
well...i know i never reset my ecu after i installed my intake, but i had no problems for several thousand miles. i'll reset my ecu and put my stock flex section in and see if it helps.. otherwise to the stealership i go
