Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-05-2009, 07:46 PM   #801
Super Moderator
Send a message via AIM to nismology
Quote:
Originally Posted by 2slow View Post
Which signals do the S/VAFC modify?
MAF sensor voltage.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 10-05-2009, 07:54 PM   #802
Ahhh. Then I was wrong; I keep getting hung up on vehicles not using fuel trims for open loop operation. Whatever metric is used to define load (MAP, MAF, or a calculated/correlated value) is calibrated beyond normal operating parameters (VE). Eventually this ability will run out as peak MAF/MAP voltage or injector duty cycle is achieved.
__________________
2002 Maxima SE 6-speed
Impressive Mod List
2slow is offline   Reply With Quote
Old 10-05-2009, 08:00 PM   #803
Super Moderator
To my understanding it's a simple formula to determine load as far as these ECU's are concerned: (X) MAF sensor voltage + (Y) Engine speed = (Z) Injector pulse width. The only way the a/f would change is if the target open loop a/f ratio at that particular load cell is different; otherwise it should remain the same.
__________________
Old 10-06-2009, 01:52 AM   #804
Many vehicles don't use fuel trim feedback to modify base fuel delivery tables, or increase fuel delivery even if more air is measured. Based on Aaron's posts, it seems the Maxima's ecu falls into this category. As such, the fuel trims (or calibration method) will keep constant closed loop AFR, but will not accommodate air flow increases at/near WOT. The AFR changes are likely not significant as calibrations generally run rich at/near WOT to cool and protect the catalyst(s).
Nearly all OBDII vehicles require short and long term fuel trims(for emissions compliance testing) which is why often an 'ECU reset' will make the car feel quicker for a few days until fuel trims kill power again by adding too much fuel or retarding timing etc to take into account engine wear, poor O2 sensor output etc.
Nissan ECU's do not carry an 'AFR target' but a base injection pulse width for a certain cell value in open loop. Hence why using a Z32 air flow meter requires a complete retune as it is not trying to maintaina certain AFRs but a base injection pulse for a given amount of air.
Once a change is made to the induction or exhaust system, the volumetric efficiency of the engine will change allowing the engine to run more ignition advance(choked up exhaust promotes more exhaust valve heat and hence more detonation prone etc so reduced timing as an example) but by offering a colder and denser air, the knock retard map is likely to allow more timing with the benefit being that a stronger induction can be generated on the next intake stroke due to a thorough combustion from more timing and denser oxygen air on the just emptying exhaust stroke leaves more vacuum inside the bore, which increases volumetric efficiency
Narrow band O2 sensors are just not accurate enough for open loop AFR control
__________________
Nissan N14 Pulsar - VQ35DE, 6spd HLSD, Kelford Spec C cams, 12.7:1CR & E85 tuned
Smashed Holden VY SS LS1 Twin Turbo Ute - 641rwHp@12psi Pics
New LS3 6.2 Camaro, Boyd Harm wheels and a big single Turbonetics huffer...
throttlehappy46 is offline   Reply With Quote
Old 10-06-2009, 09:38 AM   #805
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
I assume you are talking about AFR at WOT (open loop)
Yes, I was only talking about open loop AFR.
__________________
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Engine Torque Link Bracing Kits now available for the 1995-2003 Maxima!
The first VQ35DE Full ECU engine swap in a 3rd gen Maxima
92 Maxima SE Auto VQ35DE Swap
VE Auto PB: 12.8 @ 104mph w/ 75 shot
VQ35 PB: 12.76 @ 108 mph ALL MOTOR
Winner of the MAXUS 09 NA Maxima Unlimited class!
Aaron92SE is offline   Reply With Quote
Old 10-07-2009, 08:12 AM   #806
were could find out how to drop a 3.5 in a 1995 maxima
clashez1983 is offline   Reply With Quote
Old 10-11-2009, 06:35 PM   #807
Quote:
How do fuel trims affect ignition timing?
The ECU should carry a base map of fixed injection durations and closed loop AFR targets. The AFR targets can be set with either a software target and a 'wideband' sensor or by a 'narrowband' sensor which activates around a fxed AFR. Without performing more research I do not know how the 5.5 Maxima handles this operation. Without an AFR target, the system would have no feedback error and would be unable to make corrections (via fuel trims). The base map acts as the default settings in the event of oxygen sensor failures and open loop operation.
When changing to another MAF (Z32, etc.) a new calibration is necessary as the new MAF's correlation of voltage to air flow is different. Consequently, this correlation must be 'taught' to the ECU as the original base map references MAF voltage and will no longer provide the correct AFR.
Yes and no. Increasing VE (air flow) allows more fuel be burned and more chemical energy converted to motive power. Supplying a cooler intake air charge will increase an engine's knock limit (decrease octane requirement) and allow increasing ignition timing towards MBT.
Yup, that is why most vehicles use 'wideband' primary oxygen sensors.
__________________
Impressive Mod List
Old 10-11-2009, 06:39 PM   #808
Quote:
That is correct, usually it is in tabular form with X & Y as axis and Z as the table values. The target closed loop values are almost always a lambda of 1, where other operation modes (WOT, catalyst protection, etc..) use open loop fuelling.
__________________
Impressive Mod List
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
