6-speed swap (people who care only)
Old 02-18-2007, 03:18 AM
Hoooper
This thread is for people who care about the swap only, if you want to talk about Mathell PM me please. this is information, not a law discussion
Parts needed:
1) manual ECU
2) manual axles (both)
3) 6Speed trans
4) shifter assembly
5) clutch pedal assembly
6) brake pedal assembly
7) clutch master cylinder
8) clutch hydraulic lines
9) clutch slave cylinder
10) anti-lock brake unit mount
11) shifter cables
12) shift mount, ****, bushings etc
13) manual wiring harness(could be optional, not sure)
14) transmission mount
15) shift boot assembly
16) manual starter
The swap I guess was mostly like a 5-speed swap, I didn’t do it myself so I can give step by step instructions, but I can say some quirky things that need to be done.
1) Trans mount must be CUT off the frame, then the manual trans mount must be either welded or bolted on in its place.
2) Old shifter cable may have to be cut to be removed.
3) Neutral safety switch must be jumped in order for the car to start, place a fuse or a jumper or item of your preference where needed in the place of the NSS relay.
4) Immobilizer unit must be reprogrammed for the new computer
5) New starter must be installed because the auto one is not correct
6) Wiring harness may or may not be needed, I got a new one and mine runs now, so…
7) My flywheel was damaged and caused a lot of headaches, so make sure you have a working flywheel
__________________
Old 02-18-2007, 05:22 AM
Gle03Max's Avatar
I am very interested in this. I plan on doing it myself, but out of curiousity, do you mind if I ask how much you payed for parts and labor.
Gle03Max is offline
Old 02-18-2007, 05:51 AM
Kevlo for President
Kevlo911's Avatar
Isn't the tranny mount already bolted to the frame? Why do you have to cut it off?
Kevlo911 is offline
Old 02-18-2007, 02:24 PM
Hoooper
you have to cut the AT one off because it is different from the MT one.
GLE03, it was 6-7k, but thats with 5.6 times the labor cost than i signed on. you should be able to get 1000 labor.
make sure you look at the flywheel, i didnt see anything first and neither did my mechanic. but when i got it back i looked and saw a really obvious problem.
Old 03-17-2007, 12:03 PM
BIGMAX19's Avatar
Hey wassup!!! whats the anti-lock brake unit mount?
BIGMAX19 is offline
Old 03-17-2007, 01:38 PM
OutMaxxed's Avatar
good god 6-7k?! ..glad you got everything to work
OutMaxxed is offline
Old 03-18-2007, 09:42 PM
kbjy11's Avatar
^ good god x 2
i'm going to state the obvious... you would been much better off selling your car and buying a manual maxima..
unless the auto took a crap and needed replacing.. but even then the above would probably still apply...
but hey, its your money.. enjoy the freedom
kbjy11 is offline
Old 03-18-2007, 09:45 PM
MAXSE5SPD's Avatar
add to the list, the cover that goes above the heatshield that protects the bit of shifter assembly that sits below the floor.
MAXSE5SPD is offline
Old 03-19-2007, 09:01 AM
What we have here is a failure to communicate
Snolife's Avatar
Ouch on $$. I will be hopefully be doing this at the end of the year, thank god I know people. I am not paying that much, good god. If thats the case, screw it. Who did the work for you?
Snolife is offline
Old 03-19-2007, 09:15 AM
LA02MAX's Avatar
People, his car had been out of commission for the swap for several months. This is becuase there were a few nearly un-noticable problems (as laid out in the first post) that they could not get past. That is why it cost him so much money. Have fun hooper with the swap. Your car ran a 14.3 as an auto right? It should be much quicker now!
LA02MAX is offline
Old 03-19-2007, 09:19 AM
BIGMAX19's Avatar
On hoooper's profile he states that his car has been converted to 6th speed... Has anyone spoke to him?
BIGMAX19 is offline
Old 03-19-2007, 09:22 AM
LA02MAX's Avatar
um....you're in his thread....
LA02MAX is offline
Old 03-19-2007, 09:28 AM
BIGMAX19's Avatar
I know.. but he has been banned so it would be nice to have it confirmed that his swap was successful...
BIGMAX19 is offline
Old 03-19-2007, 09:38 AM
LA02MAX's Avatar
Yes he is finished. He is pointing out some difficult things he went through along the way.
http://forums.maxima.org/search.php?searchid=555355
LA02MAX is offline
Old 03-19-2007, 09:39 AM
MAXSE5SPD's Avatar
link doesnt work
Old 03-19-2007, 09:41 AM
LA02MAX's Avatar
then search his posts yourself. Click on his name and "Find more posts by Hooper". He's posted several things about his 6-speed swap.
LA02MAX is offline
Old 03-19-2007, 10:43 AM
Need A Light?
steven88's Avatar
snolife going to manual??
steven88 is offline
Old 03-19-2007, 10:11 PM
Drug Money
MaxBoost925's Avatar
So Hooper, when are we about to hit up Infineon?
MaxBoost925 is offline
Old 03-20-2007, 11:51 AM
dot dot dot ...
NmexMAX's Avatar
Whenver he's not banned ...
Never mind Perma
NmexMAX is offline
Old 03-20-2007, 03:16 PM
Need A Light?
steven88's Avatar
Never mind Perma
i don't see him under ban log?
steven88 is offline
Old 03-20-2007, 04:28 PM
dot dot dot ...
NmexMAX's Avatar
You're not looking hard enough.
NmexMAX is offline
Old 03-20-2007, 04:38 PM
Need A Light?
steven88's Avatar
post the link
steven88 is offline
Old 02-17-2015, 07:56 AM
Cobrastroker's Avatar
Swapping 2003 3.5 max from auto to 6 speed
Hey guys I want to build my max with a turbo setup soon and I got the 4 speed auto is there anyone who can or would be interested in doing the swap? How much am I looking at in parts minus the tranny(6 speed) and aside from that who's the man I need to see to do the job and waya charge? Please respond asap
Cobrastroker is offline
Old 02-18-2015, 10:26 AM
dot dot dot ...
NmexMAX's Avatar
Originally Posted by Cobrastroker
Please respond asap
NmexMAX is offline
Old 02-18-2015, 10:32 AM
Fakie J Farkerton's Avatar
1 post wonder.
Fakie J Farkerton is offline
Old 02-18-2015, 10:44 AM
dot dot dot ...
NmexMAX's Avatar
This might help ... maybe.
https://maxima.org/forums/5th-genera...ne-4-days.html
NmexMAX is offline
ateick
76
06-16-2019 05:41 AM
Reality sucks
12-05-2017 04:24 PM
AllBlackMax
08-30-2007 06:18 PM
Quick Reply: 6-speed swap (people who care only)
