B pillar tape
Old 12-24-2006, 09:57 AM
JaKillz2's Avatar
B pillar tape
I know that the B-pillar is actually just coated with a vinyl like tape, almost like electric tape. Mine is warn and a little faded and I was wondering where, if any, you could find such tape to replace this, and how you would get the moulding off.
JaKillz2 is offline
Old 12-24-2006, 10:04 AM
ChromeSE5's Avatar
If you are referring to the outside right next to the windows, then you can actually remove the tape and reveal the factory paint. Since you are black, it would look like stock just in gloss black.
I think some people did that since thiers was ripping off.
ChromeSE5 is offline
Old 12-24-2006, 11:03 AM
JaKillz2's Avatar
really? do you have to remove moulding? And why would they cover that with tape?
JaKillz2 is offline
Old 12-24-2006, 11:16 AM
aaron lavigne FTG
sickmax's Avatar
nope just peel the tape no removing anything
sickmax is offline
Old 12-24-2006, 02:51 PM
JaKillz2's Avatar
I went outside to look at it and cant see where to start the peel, I know it shouldn't be this hard, but ya know, give me a break ha.
JaKillz2 is offline
Old 12-24-2006, 03:11 PM
Mass_Media™
Mass_Media's Avatar
I know a few people have done it. Makes a big difference on light colored cars
Mass_Media is offline
Old 12-24-2006, 03:58 PM
JaKillz2's Avatar
ya but where do you start? I noticed on the inside edge of the door, the tape is exposed, I tried picking at it on a corner and it seems like it would be impossible to peel off, it just comes off like paint would, little chips kinda. It would never leave a good finish, not to mention, it would take hours to get even one off. Am I missing something?
JaKillz2 is offline
Old 12-24-2006, 04:31 PM
Mass_Media™
Mass_Media's Avatar
Try searching. I remember reading that a knife of some sort was used to help peal it off. Ill search a little and see if i can find the thread
Old 12-24-2006, 04:33 PM
absoundlab
can someone post pictures of there car with the black removed from the pillar?
Old 12-24-2006, 04:35 PM
Mass_Media™
Mass_Media's Avatar
http://forums.maxima.org/showthread....ghlight=Pillar
Old 12-24-2006, 05:07 PM
JaKillz2's Avatar
Hey, I found a little thread about this, they said they scored the edges of the tape, for a nice clean tear, I don't see why you couldn't just cut through if your carefull, Heat up the tape, (i thought about this, similar to de-badging, it loosens the glue) and it should just peel off. I'll try it tonight or tomr. Another point is that some people think it looks better to keep the black on the pillar if you have a colored car or tint, its all opinion though. Mine is ugly and faded thats why im taking it off. Just think before you do.. and good luck
JaKillz2 is offline
Old 12-24-2006, 05:43 PM
JaKillz2's Avatar
Follow-up = @(*&$$ !!! I tested the top of a pillar tonight and all it did was pick away like those darned sticker tags on toys when you were younger. Like I said, it would take hours to get one off. I used a 1100 watt hair dryer and i basically think it was useless. I tried light flame.. (i know harsh but i was carefull) just to see if anything came of it, and all it did was dry the tape. So now i have this "attractive" gloss black spot randomly at the top of my pillar and i'm pissed. I have to try an actual heat gun, I'm pretty sure that'll work... i hope..
JaKillz2 is offline
Old 12-24-2006, 05:57 PM
Cletus
SoonerFan's Avatar
heat it up with a blow dryer...peals right off.
SoonerFan is offline
Old 12-24-2006, 06:08 PM
JaKillz2's Avatar
i did man, I dunno it just didn't go anywhere even after continuous heat for minutes its 1100 watts, and not THAT hot, worked on my badges so I assumed it would do this. The glue is definately still hard, because it chips off rather than pealing
JaKillz2 is offline
Old 12-24-2006, 06:10 PM
Cletus
SoonerFan's Avatar
well your's might chip off since the tap has been exposed to the sun for 2 years longer than mine
Old 12-24-2006, 06:34 PM
JaKillz2's Avatar
ill try a heat gun and hope for the best.. if it doesn't work .. then im left with the ugly patch of chipped off tape... cool.
JaKillz2 is offline
Old 12-24-2006, 06:59 PM
LA02MAX's Avatar
worked fine for me...i actually didn't even need to use a hair dryer but it certainly helped...just need to soften up the adhesive and tear it off.
LA02MAX is offline
Old 12-24-2006, 07:27 PM
JaKillz2's Avatar
arrr wtf am i having so much trouble with this.
JaKillz2 is offline
chisam14
11-06-2018 08:56 PM
Matt93SE
04-08-2018 09:23 AM
jsmith24
02-01-2016 12:35 AM
Junebug1701
09-25-2015 01:54 PM
delerium75
08-19-2015 11:08 AM
Quick Reply: B pillar tape
