Check engine light wont go out
Old 12-26-2006, 01:41 PM
jeff5347's Avatar
Ok well i disconnectd the brake booster hose so i could spray carb cleaner in it to clean the manifold and after that took out the air box so i could clean the throttle body w carb cleaner. THe check engine light is on and wont go off. I know the engine was reading that the mass air flow sensor "was broke" as no air was flowing past. NOw the check engine light is on and wont go off. And yes i did the ecu reset procedure wit hthe gas pedal and such but no results. Any hints other that going to my fathers and connecting to a scan tool to clear the light?
jeff5347 is offline
Old 12-26-2006, 02:13 PM
Suspension Yoda
djfrestyl's Avatar
Clear it with a scanner. If it comes back, then your MAF is no good.
djfrestyl is offline
Old 12-26-2006, 02:51 PM
2002 maxima se
OC guy's Avatar
^follow his advice.
OC guy is offline
Old 12-26-2006, 04:47 PM
jeff5347's Avatar
ses light was ok before hand. just disc to clean and now light is on. I dont think the maf is bad just a code. Ill have to put a scanner on it. Why wont the ecu reset work
jeff5347 is offline
Old 12-26-2006, 05:01 PM
2002 maxima se
OC guy's Avatar
once you erase it with scanner sEs shoudnt come back again.
OC guy is offline
Old 12-26-2006, 05:28 PM
Suspension Yoda
djfrestyl's Avatar
If you're getting a code, something is wrong. You should find out what the code is before clearing it. If you clear it and it doesn't come back, then you're most likely ok.
Old 12-26-2006, 09:01 PM
jeff5347's Avatar
thats what im saying, no code, but doing the ecu reset procedure doesnt work. ill do the scanner and clear the light
jeff5347 is offline
Old 12-27-2006, 06:06 AM
MIXXMAX's Avatar
I heard that the later 5th gener's have problems after a self throttle body cleaning. I believe this is mainly caused by the throttle positioning sensor. The sensor is much more sensitive than the 2k-2k1 models. I would check here and ask around with other members who have done this procedure for the 2k2-2k3 models.
MIXXMAX is offline
Old 12-28-2006, 06:11 AM
jeff5347's Avatar
well got the code cleared last night. Hooked up the scanner and at first it was a 1102 code " mass air flow sensor" like i thought. Cleared it and it came on again. WTF. I just took care of it. So hook up again and now a 0507 code. Code for the throttle body. Checked a bunch of stuff and then shut car off, disc the plug to the tb and cleaned it and plugged back in.... cleared code, drove it and now its bye bye light. Moral. Check connections cause that may throw a code and urk you all day for no reason but to just clean the connections.
jeff5347 is offline
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
beboski
08-16-2015 05:23 PM
Flores94
08-11-2015 12:53 PM
Quick Reply: Check engine light wont go out
