Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-25-2006, 07:57 PM   #1
retired moderator
irish44j's Avatar
The Great Brake Pad And Rotors Thread.
other mods: Please DO NOT sticky...n00bs don't read the stickies! I'm going to bump this thread often (if needed) to keep it on top.
Post all discussion of brake pads and rotors in this thread. Stop posting new threads every 2 days asking which pads or rotors are the best (all of you!)
Here, I'll start:
What are the best replacement rotors?
- Most people prefer Brembo blanks as OEM replacements. OEM rotors are just fine too. Other options are frozen rotors and iRotors, though nobody has conclusively proven that they are any better.
What rotors won't warp?
- Most rotors do not "warp." Most rotors get uneven pad material transfer/buildup due to using crappy OEM or cheapo pads. Use a good quality pad and you will drastically reduce the chances of this happening.
- To avoid "actual" rotor warping, make sure to:
1. bed pads properly
2. seat rotor on hub properly
3. torque lug nuts to spec - NO IMPACT GUNS
What are the best pads out there?
- In my opinion, Hawk HPS are the best for street driving and light track duty because:
1. low dust
2. quiet
3. good heat ratings
4. no/minimal pad material transfer onto rotors
5. good initial bite, cold or warm
6. little to no fade
DO NOT BUY OEM PADS or "OEM REPLACEMENTS" or other cheapo pads from your local Autozone or Pep Boys.
Should I get slotted or drilled rotors?
Only if you want them for looks. They DO NOT help your braking AT ALL. A few comments:
1. slotted is superior to drilled in terms of pad and rotor life
2. both will wear your pads quickly
3. both "can" cause noise when braking (though not always)
4. both can still "warp" due to pad material transfer
5. drilled are more likely to develop hairline cracks after time.
In my opinion, blanks are the best choice out there.
carry on....
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 09-25-2006, 11:05 PM   #2
Quote:
Originally Posted by irish44j
mods: Please DO NOT sticky...n00bs don't read the stickies! I'm going to bump this thread every day (if needed) to keep it on top.
Amen and good luck to that....
__________________
BUY MY CAR !!!!!
limsandy is offline   Reply With Quote
Old 09-25-2006, 11:15 PM   #3
Go BUCKS!!!
SEmy2K2go's Avatar
Good info Josh. Maybe this will help to cut down on repeat threads...........maybe.
SEmy2K2go is offline   Reply With Quote
Old 09-25-2006, 11:34 PM   #4
大陆弟弟
n3985's Avatar
I'd like to add that HPS pads NEED to be bedded-in correctly to work at full potential. Or else they are going to squeek a few hundred miles down the road, like on my car last car.
n3985 is offline   Reply With Quote
Old 09-26-2006, 12:56 AM   #5
Send a message via MSN to lalaMAX
how to bedded-in properly? explain plz^^
i think i screw mine up.....
lalaMAX is offline   Reply With Quote
Old 09-26-2006, 01:03 AM   #6
Go BUCKS!!!
SEmy2K2go's Avatar
Brake Pad and Rotor Bed-In Procedure
From TireRack - http://www.tirerack.com/brakes/tech/....jsp?techid=85 (This is just one reference)
Brake Pad and Rotor Bed-In Procedures
All brake pads must be bedded-in with the rotor they will be used against to maximize brake performance. Recommended bed-in procedures for newly installed brake pads and rotors are as follows:
AKEBONO
400 to 500 miles of moderate driving is recommended. Consumer should avoid heavy braking during this period.
BAER
See SBS procedure below.
BREMBO Gran Turismo
In a safe area, apply brakes moderately from 60mph to 30mph and then drive approximately 1/2 mile to allow the brakes to cool. Repeat this procedure approximately 30 times.
EBC
NOTE: If a higher than normal amount of brake dust or excessive pad squeal from EBC pads and rotors is experienced, they may be glazed. Remove this glazing by decelerating aggressively from 60mph to 20mph in a safe area. This should be repeated 3 times. Then allow the brakes to cool by driving normally.
HAWK
After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.
NOTE: Hawk racing pads (Blue, Black, HT-10, HT-12) may require a different bed-in procedure. Contact your sales specialists at The Tire Rack for racing application information.
KAZERA
Follow the brake pad manufacturer's recommended break-in procedure taking care not to produce excessive heat in the system. Avoid heavy braking for the first 400-500 miles.
POWER SLOT
SATISFIED
For Gransport GS6 Carbon Ceramic Pads
Step 1: Make 10 stops from 30 mph (50 kph) down to about 10 mph (15 kph) using moderate braking pressure and allowing approximately 30 seconds between stops for cooling. Do not drag your pads during these stops. After the 10th stop, allow 15 minutes for your braking system to cool down.
Step 2: Make 5 consecutive stops from 50 mph (80 kph) down to 10 mph (15 kph). After the 5th stop, allow your braking system to cool for approximately 30 minutes. This completes the break-in of your pads to the rotor surface.
During Steps 1 & 2, a de-gassing process occurs which may produce an odor coming from your pads as they complete the break-in cycle. This odor is normal and is part of the process your pads must go through to achieve their ultimate level of performance. The odor will go away after allowing your braking system to cool for approximately 30 minutes.
As with any new set of pads, do not tow a trailer or do any hauling during the break-in period.
Full seating of your new brake pads normally occurs within 1,000 miles.
For all other Satisfied pads
SBS
NOTE: SBS racing pads (ProTrack, ProRace) may require a different bed-in procedure. Contact your sales specialist at The Tire Rack for racing application information.
Old 09-26-2006, 04:09 AM   #7
Uber-epically-terrific!!!
GBAUER's Avatar
I'd like to add that I have TONS of brake dust from my Hawks. The stopping power if great, but the dust is rather annoying. I had far less dust from the ceramics I bought at Autozone (Hawks = needs to be washed off after 300 miles, Autozone = needs to be washed after 1,000 miles), but the stopping power was about 20% less than the Hawks.
GBAUER is offline   Reply With Quote
Old 09-26-2006, 06:14 AM   #8
Send a message via AIM to Trurida18
ok...so i still have OEM pads and OEM rotors.........when i brake hard, and then pull off...i hear a constant squeaking noise for a few minutes, then it just goes away...my rotors were resurface from the dealership when i got the car... do you guys think its the pads or my rotors....OR BOTH...my rotors dont feel warped, they are smooth
but as replacements i purchased some HAWK HPS, and as rotor replacements i was going to get either powerslot slotted rotors, or their blanks
Trurida18 is offline   Reply With Quote
Old 09-26-2006, 06:23 AM   #9
Quote:
i would have to disagree with the dusting, i have had my Hawk pads on for a year and a half and i only noticed that brake dust was building up when i didnt wash my car for about 4,000 miles during a 2 month period. i also have PowerSlot rotors in the front, so i guess they could dust more as the pad wears down faster, but they didnt.
__________________
Maxspeed Springs, CE Straight Pipe, Cattman Y-Pipe, GReddy Evo 2, ES Motor Mounts, AE Headlight Mod, Misc Interior Stuff, Tinted
Ephraim is offline   Reply With Quote
Old 09-26-2006, 08:24 PM   #10
retired moderator
irish44j's Avatar
George, you drive like 300 miles a day......you don't wash your car every day!
__________________
Old 09-26-2006, 08:49 PM   #11
Quote:
Originally Posted by Trurida18
when i brake hard, and then pull off...i hear a constant squeaking noise for a few minutes, then it just goes away... do you guys think its the pads or my rotors
Pads - the squeaking is probably the wear indicators rubbing the rotors (more of a squeal than a squek, but I think its what you are refering to)
sanmiam is offline   Reply With Quote
Old 09-26-2006, 08:53 PM   #12
vsamoylov
hawk pads. my opinion on the dust. They dust alot on my maxima. I dont have any noise problems with them but the dust is the main downside for me. I will comment about the drilled and slotted rotors. If you buy cheap knock-off brands yes they will crack and make noise. Some companies take a blank rotor and drill or slot them and then resell them. Some companies dont counter-sync the holes either so noise becomes a problem. I been running drilled and slotted rotors for a long time already and I have no negative things to say about them.
Old 09-27-2006, 06:42 AM   #13
Startin from da beginning
alicious's Avatar
Send a message via ICQ to alicious Send a message via AIM to alicious
...i'm going to throw my hat into the ring and nominate Irish for member of the year and request that he receive Lordship authority (mod power) . Always providing accurate and precise info as well as he's contributed to just about every area of this forum. Thanks for starting the thread.
Now my .02 on rotors, I have the Brembo crossdrilled and I must say it's a pretty dramatic difference from OEM and those POS ones from autozone, they are louder and after 11000miles i'm having to get new pads for the front. Other then that I only have positive things to say about them, or and they are great in high speed braking, that's were they really shine to me.
alicious is offline   Reply With Quote
Old 09-27-2006, 07:59 AM   #14
Send a message via Yahoo to bladerunr
I have the RTP xdrill/slotted rotors bought from a GD and mid grade AutoZone pads. They work great together so far. Excessive dust is not a problem. I love the humming sound when I brake hard. As long as I don't have "warping" or hot spot problems, I don't care if the pads wear a little quicker than a stock setup. I'm also not worried about cracking at the holes because I don't drive hard.
__________________
HLSD // Intake Spacers // UDP // Progress RSB & Springs // Illuminas // RTP Xdrill/slotted F/R // SS lines w/ Super Blue // Warpspeed Y-pipe // Megan Catback // FSTB // MT Lip // Hella Supertones // NT555 on 18x8 SE-R rims // 221 WHP - 232 TQ // 9.994 1/8th mile
bladerunr is offline   Reply With Quote
Old 09-27-2006, 03:27 PM   #15
retired moderator
irish44j's Avatar
back to the top! I think there's a n00b out there about to ask a brake pad or rotor question....just a feeling
Old 09-27-2006, 03:45 PM   #16
vsamoylov
is this thread the replacement for the friday thread huh josh?
Old 09-27-2006, 03:49 PM   #17
retired moderator
irish44j's Avatar
Quote:
I never posted in the Friday thread and am overjoyed to see it gone......
__________________
Old 09-27-2006, 03:50 PM   #18
jballa2KSE's Avatar
Just adding to the hawk dusting topic... I have had the hawks on since maybe june or so, and never had a prob with dusting. I drive about 100 miles a day and about every 2 weeks of driving i wash the car, and my rims still look fine even before hand.
jballa2KSE is offline   Reply With Quote
Old 09-27-2006, 04:47 PM   #19
GBAUER's Avatar
every other day....
Don't believe me on the dusting? Here's a pic. Washed it yesterday afternoon. They look like TE wheels after a day with all the dust!
I should have wiped part of it to show it better, but there's a ton of dust. I've driven around 125 miles since the carwash.
Old 09-27-2006, 05:08 PM   #20
autobrokerdave@gmail.com
maximadave's Avatar
Send a message via Yahoo to maximadave
I also bought the RTP/EBC gd a few months back and have noticed that the brakes do squeak loud especially when its hot outside plus getting alot of brake dust. Lately when I wash the Max, it looks like the finish is coming off my wheels...does brake dust cause the finish to come off the wheels?
__________________
http://www.coronacarbrokers.com
maximadave is offline   Reply With Quote
Old 09-27-2006, 05:17 PM   #21
GBAUER's Avatar
Quote:
metalic brake pads can corrode your wheels. Another good reason to go with ceramic.
Old 09-27-2006, 05:25 PM   #22
I was told to have even new-off-the-shelf rotors turned on the car before first use...any truth to this? Brembo blanks BTW...
Architect is offline   Reply With Quote
Old 09-27-2006, 05:35 PM   #23
retired moderator
irish44j's Avatar
whatever.....that's an old wives tale back when people had steel wheels with a couple coats of spraypaint on them. Modern finishes are resistant/immune to those issues for the most part, unless you buy cheapie wheels. Look around teh interweb and you'll see the only sites that say "brake dust corrodes wheels" are sites that are trying to sell something to "stop brake dust" or to clean off brake dust. I went almost all winter last year with the wheels dirty and the rims that were on the car are in perfect condition....
I like stopping. Ceramic pads do not stop as well. Bite sucks, and cold bite sucks more.
george, just get these, dork:
http://www.kleenwheels.com/about_kleenwheels.htm
__________________
Old 09-27-2006, 05:37 PM   #24
retired moderator
irish44j's Avatar
every other day....
wait, I thought you were a young guy not an old lady who drives with one foot on the brakes all the time and the other foot on the gas. I hate those people who are going 65 on the highway uphill and their brake lights are on
__________________
Old 09-27-2006, 06:24 PM   #25
sciff5's Avatar
Send a message via AIM to sciff5
Have to comment about the HPS pads. They dont make noise, they grab nicely and grab even better when you've been beating on them.
In my opinion, They create more dust than stock FOR SURE. I bedded them in properly. I didnt get a chance to wash my car before going to a new england maxima meet and people there were having fun tagging my rims writing their names and drawing stuff in the brake dust with their finger.
__________________
2002 Infiniti I35 Sport Package
Progress RSB, Otto FSTB, Michellin Pilot Sports A/S, Eibach Springs, Illumina Shocks, Fx35 Brakes Rotors/Calipers, Custom SFCs
1989 Mazda Rx7 GTU
Ls1/T56 W/ Ported TB and Full Exhaust
11.67 at 120mph 3rd time out
My Car Domain Page
http://www.cardomain.com/ride/2340299
sciff5 is offline   Reply With Quote
Old 09-27-2006, 08:43 PM   #26
ptviperz's Avatar
Guys, are the rear pistons the screw in type or just the regular push ins? I know I've done a brake job on a Infiniti Max that had the screw in pistons.
Edit: I have a 2K3 SE Max (6M)
ptviperz is offline   Reply With Quote
Old 09-27-2006, 08:46 PM   #27
retired moderator
irish44j's Avatar
screw-in.
what is an "infiniti max?" an I30/35? If so, the Maxima and the I30/35 are the same cars with different skin. My front left spindle is off an I30.
__________________
Old 09-27-2006, 09:31 PM   #28
Nightmare = Reality
Maxim(a)SerjVQ's Avatar
Send a message via ICQ to Maxim(a)SerjVQ Send a message via AIM to Maxim(a)SerjVQ Send a message via MSN to Maxim(a)SerjVQ Send a message via Yahoo to Maxim(a)SerjVQ
I run the Hawk HPS pads with the Brakepros xdrilled (Brembo blanks Machine xdrilled and anti-corrosion plated before shipping)
I really don't have an issue with dusting. Overall I think i might be getting even less dust than stock pads. Occassionally they'll squeal a little when they're cold. My results are slightly varied from irish but overall the same result.
1) A little soft initially
2) INSANE bite when hot
3) No warping and quality work on the Rotors
4) look hot behind the Ti edition rims
Maxim(a)SerjVQ is offline   Reply With Quote
Old 09-28-2006, 12:02 AM   #29
ptviperz's Avatar
screw-in.
Yes, that's the one. I don't care for the screw in pistons. I need to buy more tools now ;-) Honestly, why do they do the screw in piston, it's just a pain for no good reason that I can tell. Doing these brake jobs is a pain in the...
Old 09-28-2006, 12:50 AM   #30
sciff5's Avatar
They arent that much of a pain I used needle nose pliars to screw the piston in my rear calipers in. Its not a big deal at all
__________________
1989 Mazda Rx7 GTU
My Car Domain Page
Old 09-28-2006, 08:19 AM   #31
GBAUER's Avatar
Go to Autozone or any other car store and buy the tool. They're around $5 and the attach to a 3/8" ratchet.
Old 09-28-2006, 08:22 AM   #32
GBAUER's Avatar
Maybe I just brake harder than you because I'm a better driver. Ever think of that?
For the rest of you: Irish and I will be autocrossing in October. Just to prove a point, I'll clean my wheels before I run and then we'll take a look after I get my three rounds in. I'll bet Irish (1) happy meal that I have a lot of dust when I'm done....
Old 09-28-2006, 08:23 AM   #33
GBAUER's Avatar
Heard it on Goss's Garage two weeks ago. Besides, I'll have to take a pic of mine and my wife's wheels where they both have corroded slightly.
Old 09-28-2006, 08:48 AM   #34
Hi, I drive a Maxima.
spark plugs.'s Avatar
i'm sorry, but i personally HATE hawk pads. i don't think they're practical for daily driving as they:
a. dust more than most pads
b. are prone to squealing
from experience and working at autoparts stores, i have noticed the people are most pleased with EBC green stuff and akebono for day to day driving, although, Hawk has been known to be better for light-duty track pads.
spark plugs. is offline   Reply With Quote
Old 09-28-2006, 08:52 AM   #35
Quote:
if you look closely at most new rotors, they're already "etched" so that you don't have a completely smooth surface and you can just "plug and play"
Old 09-28-2006, 08:54 AM   #36
another good thing to do is make sure that you use some form of brake cleaner on new rotors to remove that anti-corrossion crap they put on thme.
Old 09-28-2006, 09:00 AM   #37
Just MO, but the screw in type isn't any harder to do than the push in.
__________________
Mints33 is offline   Reply With Quote
Old 09-28-2006, 10:55 AM   #38
ptviperz's Avatar
Quote:
I worked in a garage and most of the time I did a car that had screw in pistons it was a Chev Lumina, those were a complete PITA. I know I did an Infiniti, I don't remember it being hard or easy, I just remembered it had the screw ins.
Old 09-28-2006, 11:42 AM   #39
I think the screw in piston has something to do with the parking brake, if they are nice and free they are a piece of cake. On an older car they can be a PITA with the cheap tool that fits on a rachet.
I just bought my third set of Hawk HPS pads, IMO great feel and stopping power, no noise and dust does not seem to be bad at all
__________________
98 Sage Mist Green Maxima SE, 5-speed. Modded Totaled
2003 Sheer Silver Maxima SE, 6-speed, Titanium edition, 'everything but Nav' - FSTB, RSB, Clear Marker Lights, Cleared front turn signal, HID fogs, Angel Eyes
Anachronism is offline   Reply With Quote
Old 09-28-2006, 01:40 PM   #40
Send a message via AIM to ctrent86 Send a message via Yahoo to ctrent86
I am considering getting pbr axxis ultimate pads(since I can get a good deal on them). Has anyone had any experience with them?
__________________
looking to to get another maxima
ctrent86 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
