Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 09-10-2006, 09:20 AM   #1
Points: 9,297, Level: 64
Points: 9,297, Level: 64 Points: 9,297, Level: 64 Points: 9,297, Level: 64
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to PlanoSER
Axle nuts keep coming loose
I've replaced both front wheel bearings within the past year or so. A few weeks ago I noticed some noise from the front end so jacked up the car only to find the axle nuts had come loose!! I took the cotter pins off, tightened them up real good and put new cotter pins in then went on my way. After driving it a few weeks it happened again.. the axle nuts were loose so I repeated the process but am tryin to figure out why this is happening and what I can do to prevent it????????
__________________
SOLD'02 Maxima SE 6MT : Place Racing CAI / Cattman Headers / 2.5" OD Cutout / NWP Spacers / BlockPlate / UDP / ES MM / Exedy OEM Clutch / 6Gen 6MT Trans / 6Gen Brakes w/ EBC Rotors & EBC Red Pads / Tokico Illumina / Progress Springs / Progress RSB / 18" SSR Type C /
PlanoSER is offline   Reply With Quote
Old 09-10-2006, 09:37 AM   #2
I had the same problem, well the real problem was Pep Boys doing a half *** job when they put new tires on my car. Did you use an impact gun?
__________________
Jfree is offline   Reply With Quote
Old 09-10-2006, 09:38 AM   #3
VaporHead
Try putting some lock thread on them bolts!
Old 09-10-2006, 09:42 AM   #4
Activity: 0%
Okay i'm going to go get some lock thread then put a hugeass breaker bar on there and torque the crap out of it! I'll see how that holds up. Still makes me wonder why its happening in the first place but oh well. Thanks
__________________
Old 09-10-2006, 09:46 AM   #5
VaporHead
Make sure you torque it to specs. If you have a chiltons/haynes, they should tell you how much.
Old 09-10-2006, 09:47 AM   #6
VaporHead
Quote:
What does his tire have to do with his axle nuts? He doesnt have a lug nut issue, he has a axle bolt issue.
Old 09-10-2006, 09:49 AM   #7
VaporHead
Oh wait a minute, are you talking about that big nuts with the cotter pin directly in the middle of the rotors in front of the bearings? If so, they aren't supposed to be torqued down. If my memory is correct, you just tighten it lightly, then turn it back like a 1/4 turn, insert pin.
Old 09-10-2006, 10:03 AM   #8
Points: 6,285, Level: 51
Points: 6,285, Level: 51 Points: 6,285, Level: 51 Points: 6,285, Level: 51
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
This nut has (or should have) BIG torque on it. (188 - 245 Ft/lbs) Snug the nut with the wheel off the ground but do the final torquing using a torque wrench AND do it with the front wheels solidly ON the ground. Once you accomplish this and if later on the nut loosens off again then there is a problem with the bearings or the bearing stack.
P. Samson is offline   Reply With Quote
Old 09-10-2006, 10:03 AM   #9
'Trynna' is not a word
mtrai760's Avatar
Points: 21,600, Level: 92
Points: 21,600, Level: 92 Points: 21,600, Level: 92 Points: 21,600, Level: 92
Activity: 0%
Wow, total mis-information. First off, what are you using to torque the nut on the axles? If your answer is anything but a torque wrench, you are wrong. Put down all the tools, head down to Sears, and pick yourself up a torque ft/lbs torque wrench that goes to at LEAST 300 ft/lbs of torque. Next, pull out your haynes or chiltons manual and look up the torque spec on those axles. I don't have one in front of me, but its in the neighborhood of 250 ft/lbs. That is a LOT of torque, if you think your going to use a little breaker bar to do it you are sadly mistaken. If you think you can estimate using the strain on your arm you are sadly mistaken. Before you torque the nuts down, clean off the axle and nut threads with a clean, dry rag. The torque application on those axles does not call for the threads to be lubricated, which can greatly affect torque application. Once you have done all of this, go back in one week and check them again. To do this apply the torque wrench to the same torque setting you used to tighten the nuts. If the nut turns at all before the torque wrench clicks, your nut has loosened again. At this point I suggest going to Nissan and buying replacement nuts. Do the same thing again, waiting 1 week. If you have the same problem, replace the axles and the nuts. I cannot overstate the importance of using a proper torque wrench to do the job. If you overtorque the nuts using a breaker bar you can have a sudden failure of either one of your axles. Think driving 60+ mph down the highly and your wheel suddenly seperating from the car. Do it right or take it to a qualified mechanic.
__________________
98 SE - VQ35 Sold
2009 SV - Stock
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 09-10-2006, 10:34 AM   #10
Activity: 0.4%
It's very likely that the nuts were never torqued to spec. and the bearing stack loosened up soon after and now a year has passed. It's possible that there has been "spinning" of the inner stack causing wear/damage. If after torquing the nut to spec. and you've got any binding or looseness or noise, then the bearings are toast. And as the chap above suggested, recheck the torque after driving for a few days.
Old 09-10-2006, 10:58 AM   #11
Points: 5,458, Level: 47
Points: 5,458, Level: 47 Points: 5,458, Level: 47 Points: 5,458, Level: 47
Activity: 0%
You really should take your car to a qualified mechanic.
__________________
2002 MAXIMA SE
K&N Filter - Magnaflow Tips - 19" G35 Coupe rims - 225/40/19 Front - 245/40/19 Rear - Eibach Springs (Fronts Only) - Stock Struts - Otto Front Strut Bar - Clear Side Markers
02theMax is offline   Reply With Quote
Old 09-10-2006, 04:41 PM   #12
Quote:
Yes and as stated, using a breaker bar is just wrong. Get it done right man, when mine was loose and I was driving it made a horrible noise. Dont want to hear about your wheel coming off and you get hurt or worse!
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
