Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-26-2006, 05:36 PM   #1
retired moderator
irish44j's Avatar
300ZX TT Brakes on...thoughts, comments, and pics
Got around to installing the 300ZX TwinTurbo calipers with 6th gen rotors, SS lines, and the BlehmCo kit. A few thoughts first of all, then some pics:
Getting the stuff:
- The calipers I sourced from a local junkyard for $40 each...a great deal for the aluminum Z32 TT calipers
- Caliper rebuild kit, pad shims, and new pins I got from DaveB - reliable as ever!
- Hawk HPS pads and new 6th gen rotors from Jeff at ImportRP - Great service, and when Jeff found out that the Brembo blanks wouldn't be in for a few weeks he worked with me and got me some OEM replacements (Kiriu, which makes our OEM rotors). Thanks Jeff!
- BlehmCo brackets and SS lines from Matt Blehm, of course. With Matt's hectic schedule these days, I greatly appreciate him finding time to get me the stuff when I needed it. When he didn't think it would make it via USPS on time, he 2-day'd it DHL. Excellent at always.
- ATE Racing Blue brake fluid: Had a couple cans around, originally acquired from OG Racing and also from Cutler.
Pre-work:
- Caliper rebuild. It's really quite simple to rebuilt the Z32 calipers, and it took me about 2 hours for both of them. From what I've read, it's a good idea to rebuild them periodically. Replaced seals, boots, pins, and cleaned and re-greased spring clips. Assembled and greased shims and pads.
- Caliper painting....of course. Just some basic black, nothing flashy
- Test-fitting. Using a rotor and spare spindle/hub assembly I double-checked to make sure they'd fit all of my wheels.
- Test-fitting: brackets - One of the bracket holes was about 1-2mm off, so I had to dremel it out just a bit. No big problem, took about 5 minutes
- The rotors come coated with NASTY grease, and it took a while to get all that crap off. I still didn't get all of it.....
Putting it together:
- Like I said, pretty simple. I had no real problems at all with anything. One of the easiest brake jobs I've ever done.
- My wife helped out bleeding the brakes - the best-looking assistant I've worked with! Then Cutler (jason) came over and helped with the other side. He's not as attractive, but equally good at pressing the brake pedal!
Performance:
- After bedding, they feel....alot like the 6th gen setup in initial bite. Good pedal feel, and I think the compression is more "even" than with the single-piston calipers...if you get what I mean. If you really stomp it, these calipers/pads have NO problem locking the wheels up and kicking in the ABS. I call it an improvement to the full 6th gen setup. I don't think I'd call it "drastic" but it is definitely noticeable.
Other notes:
- Thanks to Jason for his help.
- Thanks to my wife for her help (and patience with me spending Saturday working on the car AGAIN)
- This is a worthwhile mod. I spent under $500 total for everything I used for this, and it is an improvement in both performance and looks. Very happy with the results.
So...I'm sure you all want some pics, so I'll post them momentarily
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 08-26-2006, 05:37 PM   #2
retired moderator
irish44j's Avatar
Pre-staging of the parts, pre-rebuild
Test-fit on spare wheel
Parts ready to go on the car
BlehmCo bracket installed
Old 08-26-2006, 05:38 PM   #3
retired moderator
irish44j's Avatar
Caliper/Rotor installed
Top angle
Clearance under G35 18’s (18x8, 30mm offset)
Old 08-26-2006, 05:38 PM   #4
retired moderator
irish44j's Avatar
Clearance under G35 17’s, my winter wheels (17x7.5, 30mm offset)
Clearance under the track wheels (5zigen fno1r-c 17x8, 35mm offset) These were a VERY close fit on offset, thanks to the spoke design
The ghetto-fabulous bleed reservoir
Old 08-26-2006, 05:39 PM   #5
retired moderator
irish44j's Avatar
The before (6th gen brakes)
After:
EDIT: Pics with 2pc rotors installed end of 2006
some extra painting to cover up the unswept area so it doesn't rust, and also to bring just a tiny bit of ricy color to my all black and silver car.
Old 08-26-2006, 05:40 PM   #6
Need A Light?
steven88's Avatar
Send a message via AIM to steven88
LOL, u definitely need to resize those pictures!!
steven88 is offline   Reply With Quote
Old 08-26-2006, 05:41 PM   #7
retired moderator
irish44j's Avatar
working on it...stupid photobucket
Old 08-26-2006, 05:42 PM   #8
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
looks good. sorry i couldnt help but it looks like you got it done.
i have a 19in WS monitor...and i have to scroll to the right!!!!
SoonerFan is online now   Reply With Quote
Old 08-26-2006, 05:53 PM   #9
retired moderator
irish44j's Avatar
photos fixed
Old 08-26-2006, 05:53 PM   #10
Pointy Elbows
00MaxSE's Avatar
Send a message via AIM to 00MaxSE
Looks good, Josh.
__________________
8.18.09 CAR IS GONE
*FS: 00-01 6000K McCulloch HID fogs* http://forums.maxima.org/5th-generat...-housings.html
00MaxSE is offline   Reply With Quote
Old 08-26-2006, 05:54 PM   #11
wow that looks awesome great job are you running stock in back? i know backs arent as important just wondering
misiek is offline   Reply With Quote
Old 08-26-2006, 05:58 PM   #12
retired moderator
irish44j's Avatar
Quote:
yeah...that's another project for another day.....not high on the priority list considering the cost of rear upgrades...
__________________
Old 08-26-2006, 06:01 PM   #13
gotcha either way nice job looks sick
Old 08-26-2006, 06:29 PM   #14
Nyarlathotep's Avatar
Those brakes look awesome. Another one of your killer mods that I'd love to copy. By the way thanks for the Eibach spring advice, I got them installed last tuesday and I love the way they feel.
Nyarlathotep is offline   Reply With Quote
Old 08-26-2006, 07:07 PM   #15
Send a message via AIM to !PrjctMax!
That looks amazing! Are the "Nissan" emblems a part of the caliper or are they stickers? And are these calipers dual or quad piston?
Great Job!
Btw, how much did all of this run you, if you don't mind me asking that is.
__________________
Stopped in on 10/29/09.
!PrjctMax! is offline   Reply With Quote
Old 08-26-2006, 07:15 PM   #16
retired moderator
irish44j's Avatar
Quote:
The Nissan part is metal, part of the caliper. Calipers are 4-piston (2 inside, 2 outside)
you clearly didn't read my text part
I got good deals on a few things though, and found the calipers super-cheap (got lucky)
__________________
Old 08-26-2006, 07:21 PM   #17
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
Nice thread as always! Any plans for the rear setup?
__________________
-Jon
Daily driver: 98 Maxima SE ... 14.9 @ 95
09 Drag car: 94 Sentra E ... 1/8: 8.2 @ 94, 2.1 60' 356whp/322wtq
06 Drag car: 91 Sentra SE-R ... 1/8: 8.6@ 86, 1/4: 13.1 @ 110, 2.2 60' 250whp
JSutter is offline   Reply With Quote
Old 08-26-2006, 07:29 PM   #18
Doctorate in Detailing
Nice job irish! Glad they fit under all of your wheels.
Bluesbrekr is offline   Reply With Quote
Old 08-26-2006, 07:34 PM   #19
retired moderator
irish44j's Avatar
Quote:
not at the moment....I really can't justify the significant cost for the rears. The only kit out there for the rear is Matt's, and with calipers and all it runs well over $1000.....
Hell, This is my fourth front brake upgrade, and I still have OEM pads in the back - need to put some HPS back there at least
I think the car is pretty much where it will stay until next summer. Maybe a few small things here or there, but I've accomplished what i wanted to do with it this year and now it's time to work on the house more, finish up the autocross season, and stash every extra cent away for a new house with a garage
__________________
Old 08-26-2006, 07:35 PM   #20
retired moderator
irish44j's Avatar
Quote:
Thanks Tom...yeah me too - if they didn't, I wouldn't have put them on.
You've been quiet recently...what are you working on? I don't think you can get your paint any shinier, so you need to do something else
__________________
Old 08-26-2006, 07:36 PM   #21
Puerto Rico-Maxima Lover
Lontar1's Avatar
Nice job.........
__________________
AT TRANNY FLUSH
http://www.cardomain.com/ride/335521/3
Lontar1 is offline   Reply With Quote
Old 08-26-2006, 07:47 PM   #22
Good job irish, hope to some day do the same conversion.
hawnboy is offline   Reply With Quote
Old 08-26-2006, 09:23 PM   #23
CaTalyst.X's Avatar
That looks very nice, that project is on my list as well this helps
CaTalyst.X is offline   Reply With Quote
Old 08-26-2006, 10:41 PM   #24
The opposite of bling
Derrick2k2SE's Avatar
Very sweet. I've been wanting to do that for a while now. Do you think they'd fit under a set of 16 inch 5zigen wheels? I'd still have to be able to run my drag radials.
__________________
2K2 SE 6 speed w/leather, sunroof and Bose : HLSD tranny from 2004 car, Fidanza 15lb flywheel, 350Z clutch, Hotshot headers, Warpspeed B-pipe, PR CAI, homemade VAIS blockoff plate, Apexi S-AFC2, 17 degree timing advance, HP autoworks STS, PR solid motor mounts, PR shifter bushings, FSTB, RSB. Eibach springs with Ilumina 5-way adjustable struts, 16.5 pound Enkei Wheels. Over 145,000 miles. I turn my own wrenches.
00 GLE Forest green (wifes car)
Check out my Cardomain page http://www.cardomain.com/ride/2451788
Derrick2k2SE is offline   Reply With Quote
Old 08-27-2006, 02:14 AM   #25
I R The Law
The Law's Avatar
Send a message via AIM to The Law Send a message via MSN to The Law Send a message via Yahoo to The Law
very nice josh
The Law is offline   Reply With Quote
Old 08-27-2006, 04:26 AM   #26
westler92
Looks hella good. Gives it an agressive brake look....
Old 08-27-2006, 04:30 AM   #27
Funny you should mention that, Josh. I've been doing a few minor cosmetic things. Hopefully I'll get pics today and post a thread.
__________________
2002 Black SE 6sp, HLSD, Sunroof and a mod or two
Old 08-27-2006, 07:15 AM   #28
STFU n00b!
Pics of your assistant?
(and I'm not talking about Jason).
Matt93SE is offline   Reply With Quote
Old 08-27-2006, 06:15 PM   #29
retired moderator
irish44j's Avatar
haha.....she won't allow me to post pics on the org...she knows how "car guys" are She looks quite a bit like the girl in my avatar, though....
instead, here's a pic of my other assistant, who usually sits around and does alot of watching, but little to no helping..
[img][/img]
__________________
Old 08-27-2006, 06:18 PM   #30
tru story
SoonerFan's Avatar
so that assistant is more helpful then jason r?
Old 08-27-2006, 06:33 PM   #31
retired moderator
irish44j's Avatar
here's a pic showing the pad contact area...
Old 08-27-2006, 07:48 PM   #32
Droppin logs
D-Bo's Avatar
Send a message via Yahoo to D-Bo
Nice write up bro. I am definitely jealous. One question though, what prompted your choice of the 6th gen rotors over the Cobra rotors?
D-Bo is offline   Reply With Quote
Old 08-27-2006, 07:55 PM   #33
Wants the EVO X
MyownNismo's Avatar
Looks great. Wish I didn't have to sell mine. But they didn't clear my 19's.
__________________
Custom intake w/Apex-i filter, Cattman headers & Cat-back, 350Z RAYS wheels 18X8.5 33 offset w/ Falken Azenis 615's, 2001 AE AT w/ Stage II VB, ADV Timing 17 degrees, Stillen 2 piston BBK W/ Coleman Racing 2pc Rotors(front), Racing Brake Rotors w/Hawk HPS pads (rear), Stillen Bodykit, VIS CF Invader Hood, Smoked 2k2 Headlights, Progress Springs, Tokico illumina's, Stillen RSB, FSTB.
MyownNismo is offline   Reply With Quote
Old 08-27-2006, 07:59 PM   #34
Go BUCKS!!!
SEmy2K2go's Avatar
Josh, not sure if you've touched on this at all, and I know those are good quality pieces, but the welds on this bracket kinda scare me...(maybe it's just the picture)
__________________
Maxima Cardomain
SEmy2K2go is offline   Reply With Quote
Old 08-27-2006, 08:11 PM   #35
retired moderator
irish44j's Avatar
Quote:
I didn't think the Cobra rotors would clear the diameter of my winter wheels - as you can see, these are pretty close.
That, and I was originially going to re-use the 6th gen rotors I already had (though I ended up getting new ones)
Quote:
you could have gotten spacers, couldn't you?
Quote:
Tim, the welds are a bit sloppy appearance-wise, but I have no concerns on the strength for a few reasons:
1. Those parts are really not holding the caliper, they are essentially just spacers sandwiched between the flat bracket and the caliper. It's the vertical plane of the bracket that's really holding the force of the caliper. Of course like everything else I'll periodically check for cracks and stuff, but I'm not concerned at all.
2. The welds on my LTB are almost as unattractive, but have proven extremely strong. The LTB gets alot more torsional stress on the welds than these brackets do, I'd guess
3. Also of course how many people have used these with no issues at all, including several guys who track them.
__________________
Old 08-27-2006, 08:15 PM   #36
Wants the EVO X
MyownNismo's Avatar
They wouldn't clear with a 5mm spacer. I got new wheels picked out and for the time being I just got a set of brembo rotors.
__________________
Old 08-27-2006, 08:27 PM   #37
Man, Looking good. I wish these bad boys would clear OEM 17's, looks like they will have to wait until I get a wheel upgrade.
__________________
New $400 Kouki Project LS14
Gjohnson is offline   Reply With Quote
Old 08-27-2006, 09:39 PM   #38
vsamoylov
looks pretty good josh. would look even better with 2 piece rotors
Old 08-28-2006, 07:10 AM   #39
STFU n00b!
Quote:
http://i78.photobucket.com/albums/j8...s/IMG_6603.jpg
Take a sledgehammer to one and see what the outcome is.
ugly welds: 1
sledgehammer: 0
Those are some of my more ugly welds. didn't have much time so I had to run out there and do them in order to get these parts shipped. not my best work.
also note there isn't much stress on them in the first place. the back plate itself takes all of the shear forces and the bushings are there simply as washers. The first few sets of these I made and tried on my personal cars weren't even welded- just used the bushings as spacers. They've been on there for over 5 years and 60,000 miles (about 8,000 of that is track miles too) without a single incident. may be ugly, but they work.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Old 08-28-2006, 09:17 AM   #40
kcowden's Avatar
Very nice Josh. I'll keep this upgrade in the "future upgrades" file.
kcowden is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
