Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 08-16-2006, 06:21 AM   #1
Mod her. Ate her.
phenryiv1's Avatar
*NOOBIES* - The "I AM NEW HERE BUT HAVE A QUESTION" thread
Credit to SEmy2K2go & phenryiv1:
This thread is for the new members so that they are able to post a question. It can be ANYTHING that is 5th generation related. If we think it is important, we will either answer or make it into its own thread. If not, we will delete it.
This is only for LEGIT 5th Gen questions that may be specific to one user.
This is for noobs only and will be open only as long as we feel like maintaining it. SPAM WILL NOT BE TOLERATED.
This idea was brought to my attention by phenryiv1 in the I30(35) section
ALL MEMBER RESPONSES MUST BA A QUOTE OF THE ORIGINAL QUESTION! New questions, obviously, need not have any quotes.
____________________________________________
5th gen FAQs (READ ME! PLEASE! READ ME!):
2k Max Se Headlights Conversion To 2k1 Ae Headlights
Modification and other HOW-Tos (tells you how to do common things done to 5th Gens):
Car died...........????
ECU Fault codes or Check Engine light diagnostics (5th Gen):
FS: 99 SE 5-Speed Sterling Mist
THIS IS NOT A SUBSTITUTE FOR SEARCH!!!
How do I search? How to inspect Swaybar endlinks ?
Even if you are new and have no search privileges, you can read the Stickies (which we are working on to update), use the Google search method, or scan through the forum pages using the Find function on the browser (what I did when I first joined), or any other methods of research you may prefer, prior to just blurting out a question that has probably been asked before.
Please refrain from postwhoring in this thread. Since this thread is meant to help those who still cannot start their own threads, postwhoring just to reach 15 posts is inexcusable.
phenryiv1 is offline   Reply With Quote
Old 08-16-2006, 06:26 AM   #2
Mod her. Ate her.
phenryiv1's Avatar
Quote:
Originally Posted by four
I've got one!
I'm picking up an 02 today. Bought it on Saturday. I really only have 3 real questions that I am having difficulty finding out.
1.) The 02 that I'm picking up has the DataDots stickers. Im assuming the previous owner already bought the car in for the recall. Has this recall substantially help reduce the theft of our headlights/HIDs?
2.) Aside from MAFs issues, I've read that there are oil leaks on the 3.5. What is usually the main reason why they leak, and is there anything I can do, other than general maintenance, to prevent the leaks?
3.)I'm probably going to keep the car bone stock. Has anyone else here kept their car relatively stock (mechanically)? If so, what other problems have you encountered?
THanks!
From what I have read, this recall has put a dent in the theft of the 5.5 gen headlights. I woudl check to be sure that the headlight recall was performed before I got too confident, however.
Welcome to the site.
__________________
Patrick Henry
2008 Subaru Legacy 2.5i SE 5MT (DD) 1992 BMW 318i 5MT (Project)
Past: 2003 Sentra SE-R SpecV, 2000 Maxima SE 5MT, 1997 Infiniti I30t 5MT VLSD
Old 08-16-2006, 06:30 AM   #3
Send a message via AIM to four
Thanks,
Im pretty sure the recall was done. THe stickers on the headlight are there. I didnt check to see if it was on the windows though.
I'll check to see if the ballast was relocated.
four is offline   Reply With Quote
Old 08-16-2006, 07:03 AM   #4
Ok I own a 00 Maxima. I know that ppl here dont like talking about headlight removal. In my opinion, would-be robbers would crowbar the HIDS right out, not gingerly remove the headlights. I plan on doing the AE mod and am ready but would like a little headlight removal assisstance. Can I get a PM with the info.
westler92 is offline   Reply With Quote
Old 08-16-2006, 07:23 AM   #5
Owns a Maxima
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Quote:
The 00-01 headlights are not a theft concern at all. And here's a write up on the AE mod:
http://www.cardomain.com/ride/2190617/3
Puppetmaster is offline   Reply With Quote
Old 08-16-2006, 07:29 AM   #6
Owns a Maxima
I've got one!
THanks!
1. While it may help deter HID theft, it may result in the thieves causing more damage to your car while trying to get the lights out than if you did not have the data dots.
2. Its not so much leaks, but oil burning. Look through the old threads and you'll find plenty of these discussions. Here's one to start you off:
http://forums.maxima.org/showthread.php?t=486215
3. I've had no problems with mine other than the Bose headunit. Look for the discussions like "Buying a 02-03 Max, what issues should I look out for?".
Old 08-16-2006, 07:43 AM   #7
00 Max, about 135000 miles. Engine codes P0139 and P0430. Is there a way to check if the catalyst converter is bad without replacing O2 sensors? What are the consequences of not replacing the Catalyst Converter if its bad? Are there any consequences of not replacing O2 sensors if they are bad? I know I can't pass emissions, but I don't have to go again for a while. I am so strapped for money. I just had to replace the axles because of the terrible condition of both cV boots. I am slightly concerned as I have to drive over 700 miles from my home in Maryland to my school in Alabama this weekend. Tell me I am not endangering my life.
BlackEnigma is offline   Reply With Quote
Old 08-16-2006, 07:45 AM   #8
"tse-tse fly"
2K3MAX2NV's Avatar
Send a message via AIM to 2K3MAX2NV
sticky?
2K3MAX2NV is offline   Reply With Quote
Old 08-16-2006, 07:50 AM   #9
Owns a Maxima
Quote:
Originally Posted by 2K3MAX2NV
sticky?
Not yet, we're pretty sure this thread will be bumped up a lot on the first page.
Old 08-16-2006, 08:01 AM   #10
Mod her. Ate her.
phenryiv1's Avatar
Quote:
All of these will result in a decline in fuel economy, but will not endanger your safety.
Unfortunately, your trouble codes are considered "jackpot" codes where there are multiple potential causes. I recommend seeing if you can hook up with someone who has had these codes before and seeing what their fix was. I have an SES light and have seen a 1 mpg decrease due to a bad 02 rear fault- but it may NOT actually be the rear o2- it could be 3-4 other things. It is really a crapshoot, and no dealership or repair shop will guarantee that what they do will actually FIX the problem, unless they just replace both o2s AND the cat...
__________________
Patrick Henry
Old 08-16-2006, 08:02 AM   #11
Mod her. Ate her.
phenryiv1's Avatar
sticky?
on b15sentra.net (where I got the idea) it is 15 pages long and is NOT a sticky, but it never leaves the first page. People don't seem to abuse it there.
__________________
Patrick Henry
Old 08-16-2006, 08:18 AM   #12
I have one, not exactly a newb but no where near some of u guys. I'm mostly trying to learn more about these motors and how they work, some stuff is simple others kind of confusing. Specifically, what years between 00 and 01 have an EGR valve, i heard 2000 did and 01 didnt, and what is the difference in the way the engine takes care of emissions? Did it have anything to do with the switch between fed and cali-spec cars?
carsarecool is offline   Reply With Quote
Old 08-16-2006, 08:26 AM   #13
Thank you, Phenryiv1 and great idea as well. Because of it I was able to get valuable information without a forum official exclaiming "burn him! (in hot motor oil)". Anyway, have a great day. Thanks again.
Old 08-16-2006, 09:13 AM   #14
I'm the guy who had the worst oil consumption. I had to add a quart every 300 miles. We (well, Redlinemax.com) replaced my engine with one with 28,000 miles on it, so when Corey at Redline and I have a chance, we'll tear down the old engine and find out what the real problem is. I can tell you this much though: my pre-cats were completly shot at 160,000 miles. They were so bad that they actually clogged the main cat causing the engine to die due to excessive back-pressure. Until we tear down the old engine and inspect it, we cannot definitivly say if it was the pre-cats that caused the oil consumption by scoring the rings / piston walls or if the rings went causing the oil consumption and the death of the pre-cats was a consequence of this. Stay tuned, however, and we'll find the problem and the solution sometime within the next couple of months.
Oh, and there were no leaks. It was burning oil. However, there is a documented problem area for leaks: the rear valve cover. It'll leak around the center spark plug and drain into the plug well. If it is left too long, it may foul the plug. It's pretty easy to fix, however, and wouldn't act like a major leak like my oil consumption.
GBAUER is offline   Reply With Quote
Old 08-16-2006, 09:27 AM   #15
Quote:
I believe the cali-spec cars have the EGR, and the non-cali spec don't, but I could have that backwards. The difference isn't in the year so much as whether or not it's cali.
Old 08-16-2006, 08:01 PM   #16
I thought all newer cars had an egr valve?? Like mid-late 1980 or 90's and up
also try howstuffworks.com. good site
5thgenmaxima is offline   Reply With Quote
Old 08-16-2006, 08:19 PM   #17
Obama hates Maximas
irish44j's Avatar
IIRC they all have EGR valves.
More information about what the EGR valve does:
http://forums.maxima.org/showthread....ight=EGR+valve
see post #6 in particular
__________________
2000 Maxima SE (sold but still on the org) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
Eibachs*Illuminas*BlehmCo Stage 2 LTB*Truax Stage 2 SFCs*Stillen RSB+RSTB*Otto FSTB*Cattman Ypipe*Place Racing CAI*
Wilwood Calipers*BlehmCo 2pc Rotors*Frankencar Catback*ES Bushings*Samco Hoses*Goodridge Lines*Raxles*Everything JDM yo!
irish44j is offline   Reply With Quote
Old 08-17-2006, 12:08 AM   #18
uhh i have a basic question where can i find the thread to open and remove the amber lense in the front headlight of my 2003
thanks
felon is offline   Reply With Quote
Old 08-17-2006, 12:53 AM   #19
Send a message via AIM to rkyat Send a message via MSN to rkyat Send a message via Yahoo to rkyat
Quote:
thanks
try www.innerbean.com/housecor
__________________
Bye 5.5 gen
hello 5th gen..... wtf?
rkyat is offline   Reply With Quote
Old 08-17-2006, 11:03 AM   #20
Quote:
Originally Posted by rkyat
hey thanks, that link worked out perfectly
__________________
-Andrew
Team ZKdesigns
03'SE-K&N and a damn fast sticker....
Old 08-17-2006, 04:34 PM   #21
Here's my problem: the driver side window opens 3" by itself when I auto-close it. I found a thread about it, read through it, and didn't find any answers. So I'm throwing it out there again in case someone has any updates. Thank you for you time.
__________________
Maxima sold
Romster is offline   Reply With Quote
Old 08-17-2006, 04:46 PM   #22
Thanks everyone for your responses.
I just picked mine up last night, and its awesome. There are two issues I've ran into though throughout the day today.
1.) When the AC is on, there's a squeakish kinda sound when i'm turning my wheel to the right. (This is under load BTW, when the car is idle and i turn the wheel, there's no noise) Anyone have an idea what it could be? Shoudl I change my belts? The sound sometimes comes on when i hit a series of bumps on the road.
2.) My bose headunit has a mind of its own. Sometimes the display will turn on, sometimes it wont. I saw a few threads regarding this, but it looks like people either swapped out their hu's with a new bose one, or they got aftermarket HU.
Any help would be much appreciated, especially my 1st one.
Edit: one more thing. When I hit a pretty deep bump on the road, it seems like you can feel it on the steering wheel. Is that normal?
If anyone thinks it might be serious, please let me know, as Im still covered from all problems from the dealer for 30 days. (they assured me they'd fix anything that was wrong, including the engine)
Old 08-17-2006, 07:04 PM   #23
OK, I'm a n00b here but I've been around a bit. However, I didn't have much luck doing a search. Anyway, I recently purchased a 2003 Maxima 6spd with about 46K miles on it. I had the oil changed at a Jiffy Lube (about 2K miles ago) and lately I've noticed the oil light gives a quick flicker and I hear a little rattle when I start the car. I remember issues with other manufacturers where the OEM oil filter had a check valve in it but the aftermarket ones did not. The check valve kept oil from draining back when the engine was off. Am I dealing with a similar situation here or do I need to look elsewhere.
Thanks,
Larry
larryg is offline   Reply With Quote
Old 08-17-2006, 07:26 PM   #24
PMmeFor411AboutMaxus
alicious's Avatar
Send a message via ICQ to alicious Send a message via AIM to alicious
Quote:
Thanks,
Larry
first thing is have you taken it back to Jiffy Lube?
