Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 09-05-2007, 11:22 PM   #2881
Mine works fine though. Its just occasionally that it opens by itself when i bearly start the car, or like a min or 2. But im goin to read the manual in the morning, see if it has anything that would help. thanks
koolguy4u is offline   Reply With Quote
Old 09-05-2007, 11:26 PM   #2882
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
Why not read the thread, the information from the manual is in there.
What does 'barely start the car' mean, exactly?
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 09-06-2007, 06:31 AM   #2883
I did read the thread and it talks about when you disconnect the battery, it causes your sunroof not work completely (like it don't work)and you have to activate it(shows you in the owner manual). "Bearly start the car" means when i turn the ignition is on to turn the car on. Its not just in the morning nor the first time of the day. Its anytime it can happen.
Old 09-06-2007, 09:40 AM   #2884
lawls not found?.....ban!
Kyle00's Avatar
That doesn't mean the car is on as in running.....
__________________
Quote:
Originally Posted by BEJAY1 View Post
...Dupage County sheriff (great guy) kept me warm in his back seat while waiting...
Quote:
Originally Posted by Crusher103 (sh*t faced) View Post
try it never is and never will be but should people stop trying to making it comparable to sports car performance?
Kyle00 is offline   Reply With Quote
Old 09-06-2007, 09:50 AM   #2885
1. perform sunroof relearn procedure
2. enjoy
DasYears is offline   Reply With Quote
Old 09-06-2007, 09:52 AM   #2886
Kyle00's Avatar
Quote:
Originally Posted by TeH BawNeY
I want to clean the inside of my headlights as over the 7 years they've gotten kinda yellow. My mom always drove it and she just gave it to me recently so I'm starting to fix it up etc.
How do I go about cleaning them?
Its a 2000 se btw.
The inside of the headlights shouldn't be dirty because the headlights are sealed. However, the outside of the headlights tend to become yellow and scratched up over time. here's a thread on how to clean your headlights.
http://forums.maxima.org/showthread.php?t=443410
__________________
Old 09-06-2007, 10:15 AM   #2887
Kyle00's Avatar
Quote:
Originally Posted by bjr
So i finally got an 2000 GLE handed down to me.
First thing.
Headlights?
Not planning on going HID but what are the the best Halogen bulbs for this car in your opinion. Also where can I find them.
Next.
Fog Lights.
I want the JDM yellow fogs. Will these work?
http://www.automotivelightingusa.com...roducts_id=983
I went from the stock 200 headlight bulbs to the 2k3 HID's but I do have some Sylvania Ultra foglight bulbs and I like them. Here's a link to their page. You can get them at Autozone.http://www.sylvania.com/ConsumerProd...ar/default.htm
I don't know about those fogs.... This might help you though. http://forums.maxima.org/showthread.php?t=449650
__________________
Old 09-06-2007, 11:11 AM   #2888
I have clanking noise coming from the right rear wheel side, especially when i run on bumps. It sounds like something is loose. But when I took a glimpse underneath the car, it seems like everything intact. Could it be the exhaust or muffler?
fuctkeen is offline   Reply With Quote
Old 09-06-2007, 11:25 AM   #2889
yes, actually it happens a lot with aftermarket exhaust. try putting hose clamps on the rubber hangers and see if it makes a difference.
Old 09-06-2007, 11:46 AM   #2890
I have a 2000 Maxima Automatic with 54K miles on it.
I have had a coil that go bad on me a week ago and I was getting constant misfire with the usual TCS/SES/SLIP indicators on. About three days ago the new coil arrived but the ABS light suddenly went on. I replaced the coil and cleared the codes for the OBD and SES and SLIP went away. However, the ABS and TCS OFF lights are still on. I reset the OBD again and then removed the battery link and its still there. Anybody got any clues? I searched all over the place for TCS + ABS but haven't found anything conclusive. Basically, the TCS and ABS lights don't light until about two seconds after the car is started.
Is it an ABS sensor failure? Or alternator Failure? Or do I need to flush my break fluid? Help? Anybody seen this before?
dsx724 is offline   Reply With Quote
Old 09-06-2007, 11:56 AM   #2891
sounds like ABS. i have a bad RF abs loop and my light is off when i start the car, but then after driving like 20ft it goes on...
Old 09-06-2007, 11:59 AM   #2892
Kyle00's Avatar
Try this link... http://forums.maxima.org/showthread....hlight=TCS+ABS
__________________
Old 09-06-2007, 12:06 PM   #2893
CRAP, now i'm only get 1320...errr...now i have replace all my coils....
Old 09-06-2007, 12:47 PM   #2894
Kyle00's Avatar
Yeah, i know a lot of people have said it's easier to replace all of them instead of messing around with trying to figure out which one is bad
__________________
Old 09-06-2007, 02:13 PM   #2895
I think my car is trying to mess with my head. Here's the series of events:
Day 0: SES light comes on, I get code p1320 and misfire in cylinder 6. Tested resistance of coil: 3.3M ohms #Bad
I order new coil.
Day 1: SLIP and TCSOFF lights come on, some occasional shaking. #EXPECTED
Day 3: ABS Light turns constant #WTF Never Seen This Before, stops driving car and wait for coil
Today part 1: Coil Arrives/Installed, Reset OBD, ABS + TCS Still On #ERR
Today part 2: Disconnect Batt and ABS TCS SES SLIP All ON #!!!!
Today part 2 cont: OBD 1320 No Cylinder Misfire Code #???
Today Part 3: Reset OBD, ABS and TCS. Drives Around Block to test ABS, no avail, can't stomp on break hard enough to lock wheels cause traction too good.
Today Part 4: Confused and Drives 20 Miles (ABS and TCS light turns off when stopped and on when moving but turns off randomly) #ABS sensor Problem probably
Today Part 4 cont: Restart engine and TCS + ABS is GONE!! #YAY
Today Part 4 cont: But Brake + Battery Light Turns ON #QWE@#%#%#A
Today Part 8: Posting this on forum to see if ne1 else knows wtf is going on. I swear my car is out to f*$% me.
Old 09-06-2007, 02:38 PM   #2896
Kyle00's Avatar
It now sounds like an alternator problem to me....http://forums.maxima.org/showthread.php?t=535158
Old 09-06-2007, 08:07 PM   #2897
will 350z seats fit in the 5.5, at least with minimal work? thanks
majesticmaxima is offline   Reply With Quote
Old 09-06-2007, 08:19 PM   #2898
oh i also want to lower my 02 but i only wanted to do the front since it is much higher than the rear, can anyone advise good or bad? or how much is a good drop (") thanks for the anticipated help
Old 09-06-2007, 10:05 PM   #2899
Noticed this morning while warming the car up, my A&B trip miles were reset to 0.0 mi. I know it was at about 530 mi prior as I was keeping count of how many miles after I changed my IACV. Clock, and radio presets were normal. Any ideas what the hell happened?
Maxim24 is offline   Reply With Quote
Old 09-07-2007, 06:57 AM   #2900
Kyle00's Avatar
Quote:
Thats not such a bad idea, many people have done it. Usually with H&R springs. They lower the front 1.4 (give or take)
__________________
Old 09-07-2007, 07:16 AM   #2901
Send a message via AIM to sirjinx21jay Send a message via Yahoo to sirjinx21jay
Is it a good idea to pay $400 to get the 90,000 mile scheduled service done to my car at All Tune & Lube??? Cause it seems a bit much to me; they are only changing the oil, oil filter, air filter, spark plugs, and drain and fill the radiator. The rest i think they are inspecting, well the guy there said that he was going to do the BG44k thing to my car thru the brake booster hose (i already did the seafoam thing to the gas tank and the engine crankcase) so is this amount too much or can i do it on my own?
sirjinx21jay is offline   Reply With Quote
Old 09-07-2007, 02:30 PM   #2902
Certified Hooptie
NmexMAX's Avatar
Quote:
Originally Posted by sirjinx21jay
they are only changing the oil, oil filter, air filter, spark plugs, and drain and fill the radiator.....can i do it on my own?
A quick trip the the How To Stickys will get you where you need to be in the comfort of your own front yard for less than half that price.
__________________
Old 09-07-2007, 05:04 PM   #2903
i have a nooooobie question: the insulation on the hood, is it for sound or heat? ive wanted to remove it for a long time for weight reasons but im afraid the hood could get warped from the heat. i felt it one time and there was a considerable difference in temp between the temp on the surface of the insulation and the surface of the inner hood. any thoughts?
Old 09-07-2007, 05:06 PM   #2904
Certified Hooptie
NmexMAX's Avatar
You'd have to get pretty hot to warp the hood, i.e. you wont warp it.
Old 09-07-2007, 05:09 PM   #2905
thx. i saw that krismax had it removed, but i also knew he had a lot of janky things going on for weight reduction so i wasnt sure. but thanks for the help
Old 09-07-2007, 05:26 PM   #2906
3-Peat!!!!!
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
Quote:
you realize you could get the same weight reduction by removing a can of coke from the cup holder?
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline
