Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 05-16-2007, 10:38 AM   #2081
3-Peat!!!!!
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
Quote:
Originally Posted by hotjiggaman
can you mix the bosch n 02stock sensor together? or replace all 4
just change the one(s) that need(s) to be changed
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 05-16-2007, 10:48 AM   #2082
my car need new brake pads . it been stock ever since(2000-2007) including the brake disc. should i go with the stock pad at the dealership or is there other pad out that are good for my car? i see ppl are choosing the hawk hps is that better than the stock? also what type of Brembo brake disc to use cause there are alot of type?
hotjiggaman is offline   Reply With Quote
Old 05-16-2007, 10:48 AM   #2083
Okey, I'm a total newbie to Maximas. I have a modded Grand Prix GTP right now and I'm looking to buy a 5th gen Maxima as a daily driver. I have a few questions.
-I will most likely be buying an 02-03 with the 3.5 engine but if I find a good deal on an 01 I'll settle with it. Is the 3.0 engine any less reliable than the 3.5?
-I'll probable be buying one with a stick shift, but again if I find an automatic for the right price. How reliable are the auto transmissions in these cars?
-Any silly annoying common problems with these cars?
Thanks.
SilverBulletGTP is offline   Reply With Quote
Old 05-16-2007, 10:54 AM   #2084
Thanks.
The 3.0 is known to be more reliable in a sense. The 3.5 has been known to burn oil but both motors good. MAF sensors go bad on 02's sometimes, coilpacks go bad. Others will add more.
__________________
Hotshot Headers/Cattman Catback/VAFC-II/Zt-2/Progress+Illuminas/Cleared HID's/HID Fogs/G35 Aero Rims/Berk Intake/ES Motor Mounts/STS
Up next - Phenolic spacers
machinehead131 is offline   Reply With Quote
Old 05-16-2007, 01:00 PM   #2085
Quote:
Originally Posted by NmexMAX
Cable? Do you mean coil?
Need details of this. Are you sure you didn't get water into anything?
This means you have a misfire(multiple cylinder).
Why not check the 3 rear?
This portion of your post seems to point to a MAF problem.
Check the cam sensor (specs)
They may have already been bad.
Stop with the theory making and just check and see what codes are popping up.
Let me say I am a dumbass for refering to the coils as "wires". To be honest, none of my other VQ's ever had any engine problems. I changed the oil, plugs, filters, O2 sensors on my 01, but that was it.
No, I didnt spray my engine down, I just had a damp rag and wiped the engine cover, and the air intake. I made sure not to touch any wires or plugs.
I didnt check the 3 rear coils because it was already 11:30pm and I wouldve had to take off the manifold and collectors, which I didnt have time for. Plus, I didnt touch them in the first place, so I didnt think that was the problem.
The codes I pulled were
1- Multiple cylander misfire (pending)
2- Timing overadvanced (Bank 2 )
3- Camshaft sensor
4- Vacuum leak (Large)
*That was a cracked gas cap, which I replaced
But now, none of the codes are pending, and the idle is smooth. Is it possible that by me resetting the ECU that the computer is now compensating for the misfire? I thought that was a long shot because I dont think that if I was only producing power with 5 cylinders, that It would run as smooth as it does now at idle and under acceleration and highway speeds.
bwinter7 is offline   Reply With Quote
Old 05-17-2007, 05:04 PM   #2086
3- Camshaft sensor
Never mind guys, (and gals ) Today my ses light turned itself off and the car runs great. Maybe it was the humidity when I did all this, because about 5 min after I plugged everything back in and went on my way, It started pouring like hell. Either that or it was the Magical Maxima Fairy who fixed it......
Old 05-18-2007, 09:45 AM   #2087
LED Interior Lighting...
I am looking for LED bulbs for a few things in my interior, but i am having a hard time locating the model numbers... I have looked up almost every lighting application guide, but still no help. When i call or go to a Nissan dealer, they just give me an internal part number... no help!!!
can anyone else help???
These are the ones i'm looking for...
1) ashtray light
2) glovebox light
3) sunvisor/vanity mirror lights
4) front map lights (not the dome... already got that one)
5) instrument cluster/dash lights & how many are there???
HELP!!!
hottmaxx2003 is offline   Reply With Quote
Old 05-21-2007, 11:05 AM   #2088
Sexier Than Simpson
Bufflomike's Avatar
Bump for front page
Bufflomike is offline   Reply With Quote
Old 05-21-2007, 11:56 AM   #2089
Send a message via AIM to BMWHIGH1
Can anyone please tell me if if there is someone/place where i can have my angel eyes done, i'm talking about the ones were you have to baked the headlamps and all that good stuff. Anybody in Northern New jersey. A place that doesnt cost an arm and a leg, i went to this place on route 22 they wanted like between $300 and $400 dollars for them. I've had this light sitting in my living room collecting dust for a year anybody please
BMWHIGH1 is offline   Reply With Quote
Old 05-21-2007, 01:49 PM   #2090
Send a message via AIM to macnolias
One thing that I've been wondering in my two weeks of driving is if there's any simple ways to improve gas mileage? It's an 02 with 55k on it and I'm thinking about doing the fuel filter fairly soon and any other suggestions?
Second thing is the in-cabin microfilter. I took out the factory and cleaned it for temporary use. Would you guys suggest getting another factory filter (non-rubber edges) or go for the 2 piece filter? Also what does it mean by carbon activated? I did a quick search and found nothing that explains that one.
macnolias is offline   Reply With Quote
Old 05-21-2007, 01:55 PM   #2091
It'll be a little easier if you have a 6-speed, just dont let the revs go above 2500 before you shift. I routienly go 45-50 in sixth and reset my trip computer, I get 31mpg (That's if it doesnt lie, which I think it does a little)
I dont know if the in-cabin microfilter would make a difference. But that is just my .02
__________________
Ricer [risse-urr] N.
[Ricer: from the Latin word Ricarius meaning to suck at everything you attempt]
Old 05-21-2007, 05:06 PM   #2092
is invisible
CoolMax's Avatar
Send a message via AIM to CoolMax
Quote:
Might have better luck in the regional forum: http://forums.maxima.org/forumdispla...aysprune=&f=15
__________________
Quote:
Originally Posted by carrrnuttt
"Oh look, I can talk to the n00b any way I want, because I've been here so long, and my name says 'Cool' in it!"
CoolMax is offline   Reply With Quote
Old 05-21-2007, 05:11 PM   #2093
is invisible
CoolMax's Avatar
Properly inflated tires, PCV valve, O2 sensors, clean air filter.
I just washed mine, per housecor's instructions: http://www.innerbean.com/housecor/cabin_filter.html
__________________
Old 05-21-2007, 05:26 PM   #2094
Well my filter is a little bit beyond the possibility of saving by a good cleaning. Anyone have any preference the straight up factory one or the two piece?
My kind warranty just replaced the 02 sensors which made a big difference. I'll go threw the other ones tommorow and see how they're looking.
Old 05-21-2007, 05:45 PM   #2095
-we are your overlords-
irish44j's Avatar
the factory one IS a 2-piece....
__________________
2000 Maxima SE (sold) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
Eibachs*Illuminas*BlehmCo Stage 2 LTB*Truax SFCs*Stillen RSB+RSTB*Otto FSTB*Cattman Ypipe*Place Racing CAI*
Wilwood Calipers*BlehmCo 2pc Rotors*Frankencar Catback*ES Bushings*Samco Hoses*Goodridge Lines*Raxles
irish44j is offline   Reply With Quote
Old 05-21-2007, 05:48 PM   #2096
3-Peat!!!!!
SoonerFan's Avatar
Quote:
incorrect
the factory is one piece paper.
the replacement one you buy is two piece and carbon activated.
nissan decided the paper one sucked and started making a better one.
(i know, i just replaced mine yesterday)
replacement http://www.courtesyparts.com/Merchan...de=B7200-00005
__________________
06 Mazda 6
Old 05-21-2007, 06:04 PM   #2097
JimmyH's Avatar
that "increased output" stuff is garbage. They are 60W bulbs and that's what they put out. You can't put out more than you consume! It's just a marketing ploy.
So to answer your question: yes, you will be fine with them and do not need a new harness.
Oh, they put out more, which is why the bulb starts melting after a few dozen hours of use.
But I agree with you, they are garbage. And blinding to oncoming drivers as well.
JimmyH is offline   Reply With Quote
Old 05-21-2007, 06:22 PM   #2098
That's one hell of a price for it (high).
This might be one of the dumbest things I'm ever going to ask.
Do you think spraying cologne on it would affect the filters performance? lol
For those of us that like a certain smell during driving I'm wondering where I could spray to keep good flow of smell in the car to last the longest between sprays.
Old 05-21-2007, 06:25 PM   #2099
3-Peat!!!!!
SoonerFan's Avatar
i replaced mine and noticed the AC was blowing a lot better than it was before. the old one was very clogged.
Old 05-21-2007, 06:28 PM   #2100
is invisible
CoolMax's Avatar
Other people have done it, but "stale" cologne=
I just Febreezed it.
__________________
Old 05-21-2007, 07:10 PM   #2101
irish44j's Avatar
Quote:
Originally Posted by soonerfan
incorrect
mine didn't come with one standard. All I've ever used is the 2-pc that I bought from Nissan.
__________________
Old 05-22-2007, 02:17 AM   #2102
Is it true that when i get out of my car and lock it via keyless entry and the blinkers flash twice there is a mechanical problem i need to discover?
YungmaxiOwna21 is offline   Reply With Quote
Old 05-22-2007, 05:56 AM   #2103
Sexier Than Simpson
Bufflomike's Avatar
Quote:
Mine does that normally. Not sure if there is a mechanical issue at all I thought it was normal. My 96 did the same thing. I believe you can set it to either flash twice or beep, but I am unsure how.
Old 05-22-2007, 07:15 AM   #2104
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
That's true. Hold down the lock/unlock buttons on the fob for a few seconds to alternate between the 2. You can also roll up/down your windows by inserting your key into the door, and performing a turn & hold procedure. Where either direction either rolls them up or down. Try it and see.
Only for 02/03 models.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 05-23-2007, 02:47 PM   #2105
Sexier Than Simpson
Bufflomike's Avatar
Is 5th speed or 6th speed a direct gear
