Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 05-12-2007, 08:08 PM   #2041
JimmyH's Avatar
Quote:
Originally Posted by mtl-maximus
Hi there everybody!
The service guy said there is a problem with the MAF and beside that 'the engine was programmed for an old man'. I have to admit, I know very little about things like this, I took the bait and accepted the MAF replacement.
Of course I had to pay ~800 US for the whole thing.
Bad MAF will do that. $800 seems high to me though.
I dont think you can program an ECU for better gas mileage or performance. They do, however, learn your driving habits, and adjust fuel delivery accordingly.
Since then the gas consumption went up like crazy, being ~25% higher than before changing the MAF and reprogramming the computer.
If they reset the ECU, it is going to "clear out" how the computer maps fuel delivery. So if it was delivering fuel conservatively before (which would explain why your car was slower) lower fuel economy now that it is back to default would make sense. I can verify this because my 2000 SE is alot faster than my mom's 2001 SE, and the difference is more than can be accounted for by a torque converter. Her's doesnt have that oomph.
As for the rest of it, I have learned with modern automobiles, anything is possible. My Maxima spent two weeks at the dealer for them to try and figure out why it intermittently would not start. In the end, it was corrosion between the engine and trans. Who would have figured that?
But a partially dead ECU sounds a little fishy to me. If you can, I would go to another dealer and get a second opinion.
And to keep your ECU from getting "conservative" in the future, if you want to keep the power, you have to use it. WOT regularly. That will blow carbon build-up out off the pistons as well.
JimmyH is offline   Reply With Quote
Old 05-12-2007, 08:29 PM   #2042
JimmyH's Avatar
Quote:
Originally Posted by ajamil
Ok, here is the situation. I recently purchased an '00 maxima for a very good deal, has 200,000 KM no check engine light, clean inside and out, beautiful Glacier Pearl paint job...
Symptoms of the unknown problem are:
1) 8 KM / L (roughly 19 MPG)
2) 0-60MPH in 9 Secs. (Way below the average 7.5 secs. that I see others get)
3) Between 2500 and 3500 RPM I feel a drag when flooring it. (Like something is holding the car back)
I recently got a highmileage oil change. Did a 4 step emissions cleaning (which includes seafoaming), did not help at all.
Is this a MAF issue?? I've been reading that airflow and dirty sensors are the culprit of most gas mileage and acceleration problems, but others with the same problem did not notice a change. I took a look at my MAF and it looked clean to me.
What else could I do to diagnose the problem?
I would really appreciate any suggestions or advice.
Thanks!!!!!!!
MAF is a good bet. Could also be the ignition coils. Unfortuneatly there is no way to test them. (For you and me anyway.)
Another thing to try, pull the spark plugs and see if any/all are fouled. (They will be jet black) Or if they are white (I dont remember what that indicates, but I know it isnt good.) Spark plugs are cheap fix if you can turn a wrench, and not a bad idea to replace them anyway with that many miles.
Seafoam has to be the one of the biggest scams out there. I cannot possibly see how that could not damage something. I have never used it but with all that smoke, and people saying how their engines are barely running and shaking madly while the stuff is in there...
Welcome to the club. I have 165k on mine, and she runs better than the day I got her.
Old 05-12-2007, 09:02 PM   #2043
JimmyH's Avatar
Quote:
Originally Posted by fldash
One of the rear tail lights (passenger side) has a broken seal with moisture in it. Do I simply replace the whole light? Also, the brake lights on my spoiler do not work? Is that an easy fix or ? ? ?
You have to remove, or pull back the trunk sidewall liners. There are four nuts (I think it is four) to remove. You will then see the studs sticking in, those are attached to the taillight. Now is the fun part. You have to push like the hades, and them some more, and then some more. And just when you think it is loose, you are about 1/3 of the way. Keep going. There is sealant all around the taillight between it and the 1/4panel. (Which you should replace by the way.)
After you finally get it out, you are on your own, I have no idea how to find the leak if there is one. If you find one, just get some plastic repair putty. I would make sure it is epoxy based. Or go to courtesynissan.com. They sell new 02 taillights right on the website for a reasonable price. And it will have the new sealant on it already. (or it may be on a strip that you press into place.)
It seems to run well, no check engine light and no other issue except that I'm not used to driving a car and I'm feeling afraid of it...
Respect it, but don't be afraid of it... this is not the best handling sedan out there, not by a long shot. But it is ONE OF THE MOST responsive. 5th gens don't suddenly lose traction. Unless you have really cheap tires, they give you warning. (within reason) Altimas, 6th gen Max, Accord, and Jetta do not. Ease into it. Find a turn (or better, highway ramp) that you are comfortable with, and push it a little farther each time. Coming from SUV's this is going to feel like a sports car to you.
How do I know if I need new brakes or rotors? I THINK I'm having some vibrations when I step on the brake, but I'm not sure as I'm really paranoid since I just bought it. My uncle once told me to replace the brakes when I heard them squeal/squeak; none of that coming from this car....
If it vibrates only when you apply the brakes, your rotors are either warped, or more likely, coated with brake pad residue. Either way means they need to be turned or replaced. If you can turn a wrench, replace the rotors and pads yourself. Jack up the car and remove the wheel. You will see the bolts you need to remove on the calipers (if unsure, search the stickies, there are bound to be pictures.) Remove the calipers. Get a bucket or something to rest it on, so you dont have to remove the brake lines. Pull the two pads out. Get some disc brake quiet (in blue packets at most auto part stores) and spread it on the BACK of the new pads (side facing away from the rotor). Replace the shims and put back in the calipers. Pull the rotor off, may need to tap from the back with a mallet, and put the new one on. (I always go new, not much more than getting one turned) Then put the caliper back on. Then get someone to step on the brake pedal while you quickly open and reclose (less than a second) the bleeder valve. Do that about 5-6 times until no bubbles come out. You can skip bleeding, and still drive the car. If a little air got in the system (it will be very small if any at all) the worst is the pedal will be a little mushy. You can go back and bleed it later. If the piston did not move while you were working (unlikely), you dont have to bleed it at all.
That is pretty much it. Start with the fronts. That should get rid of your vibration. If not, then do the back.
Sqeaking/squealing is not a sign that your brakes need to be replaced. It is high frequency vibration between the back of the pad and the brake piston (which the aforementioned disc brake quiet mostly eliminates) and it is inherent to disc brakes. If you can live with the sound, it is not damaging in any way to your brakes.
Screeching, on the other hand, is a sign that your pads are down to the wear indicators, and every time you apply the brakes you are damaging your rotors.
It has 116k miles on it...
Standard or auto? If its an auto, pay attention to it. You most likely will have no problems, but I have heard of autos failing at less than 100k.
Oh, one more question, how does this trip mileage work, or does it? I haven't yet looked in the manual but I reset both Trips odometers when I got it and checked them when getting to work this morning. Showed 25.3 mpg with about 80% highway, 20% city, does that seem right; or is that mileage very generous?
That is about right. I get anywhere from 26-27 with that mix when I am behaving.
Edit: I'm not a new driver... I'm 28, but have driven only trucks and SUVs until now...
You made the right move. My wife has a Pilot, and I drive it as seldom as I can. There is nothing like a sedan for the right compromise of utility, efficiency, and fun!
Old 05-13-2007, 03:49 PM   #2044
Send a message via AIM to ATLienGeorgia Send a message via MSN to ATLienGeorgia Send a message via Yahoo to ATLienGeorgia
Quote:
Originally Posted by irish44j
it is extremely easy. Undo two bolts on the top in the engine bay, unplug harness from bulbs, pull light out. Install is reverse of removal. Make sure to line up the tab/stud on the outside of the light that goes into the fender.
I appreciate it, it sounds like something I would have no idea doing. I was looking at it the other day and it seemed pretty easy.
I also wanted to ask if I use a replacement brand, not Nissan brand is there going to be any headlamp issues?
ATLienGeorgia is offline   Reply With Quote
Old 05-13-2007, 05:14 PM   #2045
P0158 & P0159
So I looked at the SES codes thread and followed the link for P0158 ( same as P0159 ) - http://forums.maxima.org/showpost.ph...&postcount=100 .But there wasn't any real mention of this code specifically.
Now as far as i understand, the Bank 2 sensors are after the cat, and only monitor the cats functionality (or lack there of).. So would i be safe not replacing the sensor and clearing the error from the ECU? Do i have to go to the dealer to clear it?
harpua is offline   Reply With Quote
Old 05-13-2007, 05:35 PM   #2046
Sexier Than Simpson
Bufflomike's Avatar
yeah it would. Because n00bs never actually READ the stickies.
We keep it floating free so it's in the middle of all the "hot" threads at all times
Thanks to Irish and LA who always respond with helpful suggestions and answers to questions they have answered 15 tiimes already.
Bufflomike is offline   Reply With Quote
Old 05-13-2007, 07:09 PM   #2047
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
Link to how to clear my wing's brake light on my 03 max...
Torgus is offline   Reply With Quote
Old 05-13-2007, 09:07 PM   #2048
-we are your overlords-
irish44j's Avatar
Quote:
I don't see a link....where is it?
Oh wait...are you ASKING for a link?
If so, be more polite and say "pretty please."
http://www.cardomain.com/ride/211310/8
__________________
2000 Maxima SE (sold) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
Eibachs*Illuminas*BlehmCo Stage 2 LTB*Truax SFCs*Stillen RSB+RSTB*Otto FSTB*Cattman Ypipe*Place Racing CAI*
Wilwood Calipers*BlehmCo 2pc Rotors*Frankencar Catback*ES Bushings*Samco Hoses*Goodridge Lines*Raxles
irish44j is offline   Reply With Quote
Old 05-13-2007, 09:18 PM   #2049
3-Peat!!!!!
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
a simple question mark would have made it more clear
and dam your fast searching skillz...i couldnt find it
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 05-13-2007, 09:22 PM   #2050
irish44j's Avatar
you lose. It's in the freakin HOW-TO stickies
__________________
Old 05-13-2007, 09:23 PM   #2051
3-Peat!!!!!
SoonerFan's Avatar
my search kept timing out
i was trying to post the link to get some of your leg humpers
__________________
06 Mazda 6
Old 05-14-2007, 05:51 AM   #2052
Thank you very much for your answer!
What a noticed after the MAF was replaced was the engine RPM's went up compared to what it was before (I hope this makes sense). Let's say at 60 mph it used to be 2000rpm when driving on the highway. After, it was 2400rpm for 15-20min then was slowly going back towards 2000rpm.
I'm saying this because before entering the highway on my way to work, I have to drive the car through the city (lights, stop signs, etc) for about 10 min. It was like the car was entering the normal running mode way much slower than before.
Now about the half-dead ECU, can I ask the dealer for the burned one back?
Do they have to keep it?
Thanks again!
mtl-maximus is offline   Reply With Quote
Old 05-14-2007, 08:36 AM   #2053
JimmyH's Avatar
That can only mean your torque converter was not locking.
It is your ECU, you own it, they should give it back if you ask. I dont know what you are going to do with it.
Old 05-14-2007, 09:34 AM   #2054
Thanks again JimmyH.
Like I said I don't know much about this kind of stuff.
What has caused this? Does this mean something else is defective?
Is it easy to fix? How much would it cost?
Old 05-14-2007, 09:44 AM   #2055
JimmyH's Avatar
I dont know much about automatics, I have been driving standards my whole life(well, since 15 anyway). I know until the torque converter locks, engine speed relative to vehicle speed is variable based on load. In the old days, the torque converter locked when a hydraulic valve opened (or closed?) based on throttle position, engine speed, etc, etc. Now it is done electronically. So probably the ECU is what is causing it.
I would just go to the dealer. But then I am lucky, my family has bought over a dozen cars from the dealer, and have a direct link to the GM. So we always get good service. And when we dont, we call the GM and he fixes it.
Old 05-14-2007, 10:59 AM   #2056
Makes sense.
I just have a strange feeling every time I take my car to the dealership, like they're always trying to rip you off. I just wish I could find some garage / good mechanic that I can trust here in Montreal.
See the labor estimates they gave me, they seem unrealistic to me.
Anyway, I'm glad I found you, guys. This place is great!
Old 05-14-2007, 02:35 PM   #2057
sorry i asked before an no one responded. i usually try to be more polite when i ask questions.
__________________
--Jon--
Currently driving:
03 Maxima: 40k miles, Bodykit, CF hood, 20'' Chrome DUBz, Alarm, Tint, Eclipse AVN6500, Rainbow Profi Vandiums, Boston Pro60s, 2 12'' Type Rs, Suspension, Cleared 8k HIDs w/ DDE Angel Eyes, Intake, Exhaust, Timing Adv, Custom 2 Tone Interior, x drilled/slotted/zinc rotors, SS brake lines, etc.
92 Max SE: 5 speed LSD 230k Daily Driver FTW 4DSC!!!!
Retired:
97 Max modded: BURNED IN FLAMES
96 Max modded: Sold to brother
95 Max modded: Attacked By Volvo
Quote:
Originally Posted by KRRZ350 View Post
yes, she said she had plans with friends but I knew she really just didn't want to take it up the butt anymore.
Old 05-14-2007, 08:37 PM   #2058
Shift Lock Mechanism functionality
I have a question about the shift lock system in my car, an '02 Infiniti I35.
When the shifter is in park and I apply the brake, I feel a click in the shifter (I guess that's some kind of actuator) and I can then move the shifter to D or R, or whatever gear I want.
What I notice, is this clicking sound continues to happen everytime I press the brake, even if I'm in D! So I could be cruising down the road at 40mph, see a red light ahead, apply my brakes, and I feel the same click in my shifter (I hold my shifter at all times since I'm so cool). Should this mechanism continue to work even when not in P (park)?
My Pathfinder doesn't do this, it clicks only if in Park. Just wondering if you guys notice the same thing in your cars?
Joe.
The Hulio is offline   Reply With Quote
Old 05-14-2007, 09:13 PM   #2059
Nokya Stage 1 Arctic White Headlight Bulb
Hello, a couple days ago I bought some Nokya Arctic White headlight bulbs on eBay. Under the specs, it said its consume wattage was 45/60W and it says it has an output of 60/75W. Would it be safe for me to put these in now or should I wait and buy a wiring harness? Here's the link: http://cgi.ebay.com/ebaymotors/ws/eB...5329335&rd=1,1
sirmixalot42691 is offline   Reply With Quote
Old 05-14-2007, 09:18 PM   #2060
irish44j's Avatar
Quote:
that "increased output" stuff is garbage. They are 60W bulbs and that's what they put out. You can't put out more than you consume! It's just a marketing ploy.
So to answer your question: yes, you will be fine with them and do not need a new harness.
__________________
Old 05-15-2007, 05:06 AM   #2061
3-Peat!!!!!
SoonerFan's Avatar
Joe.
its normal...........
if you turn up your stereo, you wont hear it.
__________________
06 Mazda 6
H&R Spri
