11-06-2006, 10:47 AM
#441
Certified Hooptie
Quote:
Originally Posted by chris in va
I just bought a 2000 SE 5-speed, 112k miles. The previous owner said he replaced the MAF but it still has an obvious stutter at 3500rpm, so I'd like to try cleaning it before dropping $120 on a new sensor.
I'm armed with a Dremel and some QD electronic cleaner. The 'torx' bolts have that post in the middle, so I'm guessing those have to be ground down first? Or can it be cleaned still installed in the tube...
You shouldn't have to grind anything down. I just unbolted mine, sprayed it from all angles, let it dry, and reinstalled it. It might not be your MAF that is causing that shutter. Do you have any MIL/SES lights?
Quote:
Originally Posted by XKlusive_Drunky
I got a 03 GLE with 75k, my check engine light came on and i talked to my uncles and my dad but when i turn the engine on and rev it on 2k rpm, it makes a vibration noise on the motor. Now my uncle said it was my valve lipster that got weak and i got power still, i changed my oil and it makes the noise alot less but my check light is still on......
Was the MIL code read via an OBD II reader/scanner? Or is your uncle just making an assumption?
11-06-2006, 01:04 PM
#442
just had my muffler replaced and they didnt put the tip back on it because they couldnt get it off the old muffler...can anyone tell me where I can get a new stock tip for a 00 maxima?
__________________
I'm on that New York Sh|t
11-06-2006, 01:12 PM
#443
Quote:
Good luck! I posted a thread a few ago trying to find a place to get one. You will probably have to go to a junk yard, or get some aftermarket ones from Pep Boys or something.
11-06-2006, 01:49 PM
#444
Certified Hooptie
11-06-2006, 03:09 PM
#445
Quote:
Originally Posted by NmexMAX
$42 for a piece of aluminum. lol we both are are better off getting aftermarket.
11-06-2006, 03:38 PM
#446
Certified Hooptie
11-06-2006, 03:48 PM
#447
It's definitely the MAF. Previous owner said he replaced it, but I'm not convinced after tearing out the airbox last night. Looks like it hasn't been touched in years.
The bolts I'm talking about are the two on either side of the MAF sensor holding it in the tube. Torx style with the center post. Maybe they include the tube with the MAF when you buy one?
I did a little searching and it's called a 'Tamper Resistant Torx' bolt.
11-06-2006, 05:49 PM
#448
-we are your overlords-
no need to take the sensor out of the tube. Just gently spray it and let it dry inside the tube.
btw, MAFs are alot cheaper if bought from DaveB
__________________
2000 Maxima SE (sold) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
Eibachs*Illuminas*BlehmCo Stage 2 LTB*Truax SFCs*Stillen RSB+RSTB*Otto FSTB*Cattman Ypipe*Place Racing CAI*
Wilwood Calipers*BlehmCo 2pc Rotors*Frankencar Catback*ES Bushings*Samco Hoses*Goodridge Lines*Raxles
11-06-2006, 08:39 PM
#449
I own a 2k2 SE max... on the head lights where they have yellow/amber lenses on the turn signals is there clear replacement lenses..and if there is..is it a real PIA to change over...thank for the help.
11-06-2006, 08:48 PM
#450
Quote:
read and know...
http://www.innerbean.com/housecor/clear_HIDs.html
__________________
11-07-2006, 12:16 AM
#451
Quick ?. I'm about to do the fog lights re-wire...does Housecor How To on the re-wire allow the fogs to come on when I lock/unlock my car with my remote? Key not in the ignition i guess...?
http://www.innerbean.com/housecor/fog_rewire.html
11-07-2006, 12:28 AM
#452
i went to auto zone and the codes said that i have a camshaft sensor troubleshooting on #1 and crankshaft sensor troubleshooting on #2 i dont know what the hell that means but i know it dont sound good i cant remember exactly what it said but when i get back home i'll let you know, im working offshore right now.... i just needed some pointers that way when i get home i know what to do.
and like i said any help would really be greeatful..:confused
11-07-2006, 12:46 AM
#453
it was an assumption but he might be right cuz i talked to my homies dad who is a mechanic and had him confirm and said yea its most likely the valve lipster.... but i havn't taken it to him cuz im way out here and dont get home till the 16th, so i got some time to think what i can do when i get home.... i didn't wanna drive it 600 miles round trip and break down in the middle of louisiana.
11-07-2006, 01:02 AM
#454
Will HID 4300k in high beams make a BIG difference in seeing more **** at night?
11-07-2006, 04:51 AM
#455
Quote:
Originally Posted by Trevor28
Hey on the 2000 Maxima, is there a way to retract the rear seat belt into its compartment? The one in the middle that is. Usually , you pull on it the belt and it retracts. Thank you
It has been my experience that the dealership will repair/ replace faulty seatbealts.
11-07-2006, 08:27 PM
#456
Owns a Maxima
window regulator and motor
Posted on behalf of nditsmo
Quote:
Originally Posted by nditsmo
Sorry to ask this but I have been searching with no luck. I need help installing a window reguator and motor in a 2000 nissan maxima. I can't move the window up or down to get the screws out and I saw the installation on CraigBrace's 93 maxima, is it similar cause the only thing that I can't do is move my window up or down in order to get to the screws at the bottom of the window. It also seems that I will not be able to fit my arms behind the door to get to the old regulator also. Any ideas on how I should do this. Any advice is helpful. If Anybody near Buffalo can help me it would be much appreciated. Thanks
11-07-2006, 09:07 PM
#457
Let's Go BUCKS!!!
Quote:
Originally Posted by Memphis2k1
Your headlights don't flash when you lock/unlock your car with the remote, just the marker lights, so I don't think your fogs will "flash" either.
__________________
Quote:
Maxima.org is the Anheuser-Busch of the internet.
Maxima Cardomain
11-07-2006, 09:58 PM
#458
Certified Hooptie
http://forums.maxima.org/showthread.php?t=498617
http://forums.maxima.org/showthread.php?t=378156
CA registered legal tint limit
Please stop saying that word.
11-07-2006, 10:17 PM
#459
My Questions
1. My car stutters between 1000-2000 rpm. Plus the cruise goes up and down.
2. P0420 came on 2 days ago . I reseted the ECU by unplugging the battery and the SES went. It happened on a rainy day. Can O2 be sensitive to get moisture and trigger SES. Should I update the ECU.
3. How do we fit 5" rear speaker when there are only 3 holes in the door.
11-08-2006, 01:45 PM
#461
Regarding your code 0420 Aluminum floor mats!!!
Why do you want 5"? Don't we all have 6.5" stock in all doors? If you want a 5", then you have to make a bracket to mount the speaker and probably drill new holes.
11-08-2006, 01:48 PM
#462
Quote:
Originally Posted by GigEmAgs07
Your bulbs draw 55w of juice from the car, but, the light output is 80W. Most l ight bulbs draw less juice, but give out more light. Look into getting some PIAA H3's/4's. They are more expensive, but have nice light output.
11-08-2006, 04:28 PM
#463
Quote:
So a 55/130 light poses no more potential harm to my wiring/harnesses than a 55/80 does? Both are safe?
__________________
Beat the Hell Outta Coach Fran
11-08-2006, 04:32 PM
#464
Yes, they are safe. You just need to look at the draw wattage, i.e. 55W/80. Just look at those first set of #'s.
11-08-2006, 04:37 PM
#465
good deal, thanks for the quick response. Just in time for me to have to go to class! Stupid biochemistry.
11-11-2006, 04:00 PM
#466
Man I've had it with this car here's my questions
1) will the motor mounts off of a 3.5 02 max fit on my 2000 max? both are auto
2) will the starter off of the 3.5 02 fit on my 2000?
thanks
11-11-2006, 04:37 PM
#467
Are you talking about the hole mount or just the inside? If you want better mounts just get after market replacements for the stock rubber part inside the motor mount.
