Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 12-04-2007, 06:27 PM   #4041
Send a message via AIM to Tee00Max
has anyone tried pressure washin their floor mats??? factory.....
Tee00Max is offline   Reply With Quote
Old 12-04-2007, 06:32 PM   #4042
Send a message via AIM to MoeBelikeMax
Whats is the Door speaker Size On the 2000 Se...Got a big sell at best buy and i want to buy some speakers ...oh and the Tweeters size Too
MoeBelikeMax is offline   Reply With Quote
Old 12-04-2007, 06:37 PM   #4043
Send a message via AIM to El_PrOfE Send a message via MSN to El_PrOfE
Question, I know its stupid but I have been hearing this rattling noise coming from the front end of my car when I go over a speed bump. anyone know what it can be? Could it be a TSB?
El_PrOfE is offline   Reply With Quote
Old 12-04-2007, 06:55 PM   #4044
Quote:
Originally Posted by chopstix2nrz View Post
holy crap im surprised no one posted you an answer on this, this isnt safe at all!
IIRC your car should come with ABS standard, dunno whats up with your car though. Reason why i say it should have ABS standard because when i look up parts for our cars at work esp cv axles and other driveline/brake components i do not get an option for non abs equipped vehicles
I agree with you that the 2001 SE Maxima should come with ABS standard. I have a car dealer appointment to see what happened for the ABS system. By the way, would you mind taking a look under the hood on the drivers side right in front of the battery? There should be a relay box. On top of the cover should indicate what are the relay uses? For exmaple, ABS motor, ABS actuator, radiator fan, etc. Can you open the relay box and see if the positions are filled with these relays?
I appreciate your help!
Nismo1 is offline   Reply With Quote
Old 12-04-2007, 07:00 PM   #4045
Send a message via AIM to 00SEMAX19 Send a message via Yahoo to 00SEMAX19
Mine has both an abs solonoid and abs motor fuse. both are 40A and are there. Good luck and let us know what you find.
__________________
I'd rather spoonfeed than Flame and Postwhore.
YA THERE HEAVY 20'S FROM A FX45
My 02 6-speed SE Mods = intake, headers, full custom exhaust with no cats, 75 nx wet shot nitrous,denso iridium 1 step colder plugs, ssim, slotted/drilled brakes, ce front strut bar, heavy arse wheels, tein s-tech, In need of a/f tuner and tune badly, Plus some other randoms
00SEMAX19 is offline   Reply With Quote
Old 12-04-2007, 07:09 PM   #4046
Nissan Maxima SE ABS
Quote:
Originally Posted by 00SEMAX19 View Post
I've also been thinking about this.
First thing I would do is check your computer to see if there are any stored codes. Did you buy your car from a private party or a dealer? The abs light should come on when you turn the key to ignition on. Maby somebody disfunctioned the abs and removed the bulb from the instrament cluster. Not a good idea but I've done this on a lexus before and all it did was make the brakes function like a car that never came with abs. Good luck and let us know what you find.
I bought the used car from a dealer. I have not checked the computer yet, but I do not have the check engine or any lights on. My ABS light has never come on, no matter how I turn the ignition. I do not know if the bulb has been removed. Do you know if it could be disabled?
There are no self test ABS diagnostic after start up. I am familiar with the ABS self test sound since I do have different Nissan vehicles in our family.
What's the other possibility that the ABS light never comes on?
I appreciate your input.
Old 12-04-2007, 07:27 PM   #4047
2001 se Maxima
Are you talking about fuse box left side of battery?
Yes, I do have ABS solonoid and ABS motor fuse in the fuse box on the left side of the battery. I am talking about the one black relay box front side of Battery. It should be said ABS actuator, ABS motor, radiator fan and so on.
Old 12-04-2007, 07:28 PM   #4048
2001 se Maxima
Old 12-04-2007, 08:46 PM   #4049
Quote:
Originally Posted by NmexMAX View Post
Do the MAF and take it from there. If it is still acting up, do the ECM update.
Try sanding them first, if that doesn't work, look for some cheap used housings (www.car-part.com, on here, eBay, www.pinnaclenissan.com, Dave Burnette, etc) . You have an 02 so you can still retain the HID's, meaning all you need is the housing.
Yeah basically I just want to see how it looks with the oem headlight capsules, want to compare, I may just go alone with trying to clean them up, but want to try the stock bulbs. Oh and by the way I didn't buy the projector headlights, just the stock looking ones with phillips HIDs, kind of like these:
http://cgi.ebay.com/ebaymotors/02-03...QQcmdZViewItem
So I guess my question is if all capsules are the same wattage? If so I don't think it should be a problem. I'm sure someone here has replaced capsules, so I'm guessing this is possible.
rony_espana is offline   Reply With Quote
Old 12-04-2007, 09:14 PM   #4050
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Quote:
Originally Posted by UConnJack View Post
Thanks. Is cleaning the MAF worth trying first, has anyone had any luck with this solving the problem? Or should I just go right to the replacement?
Well, since cleaning is free, I'd try that first. You may get lucky.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 12-04-2007, 09:17 PM   #4051
3-Peat!!!!!
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
usually MAF problems are because they are going out...not dirty.
but if you want to try MAF Cleaner....new product!!!
SoonerFan is online now   Reply With Quote
Old 12-04-2007, 09:17 PM   #4052
Scottwax's Avatar
Quote:
It would be fine. You can also soak them in the tub for a few hours with some laundry soap, rinse, squeegee out the excess water, let drip dry, then toss in the dryer for 20-30 minutes on medium heat.
Old 12-04-2007, 09:20 PM   #4053
3-Peat!!!!!
SoonerFan's Avatar
Quote:
or buy new ones.
http://www.courtesyparts.com/Merchan...=A33_mats_2002
Old 12-04-2007, 09:30 PM   #4054
Scottwax's Avatar
Quote:
Originally Posted by soonerfan View Post
Once I cleaned mine, they looked really good. The back ones are pretty much perfect, honestly, the whole back of the car looks like it has rarely been used.
Good price on the mats though.
Old 12-04-2007, 09:38 PM   #4055
3-Peat!!!!!
SoonerFan's Avatar
i steamed cleaned mine several times and they still looked bad. not just dirty but worn out. especially the drivers side....worn down spots from my heels.
Old 12-04-2007, 09:59 PM   #4056
Scottwax's Avatar
I've noticed that in customer's cars that have manual transmissions. The driver's side mat takes a real beating.
Old 12-04-2007, 10:06 PM   #4057
3-Peat!!!!!
SoonerFan's Avatar
exactly why mine are bad. both feet are used and move around a lot more.
Old 12-04-2007, 10:54 PM   #4058
Made my own from Home Depot.
I bought commercial grade carpet runners (usually made for hallways) with a rubber backing. Traced the factory mats, but cut the carpet slightly bigger for the added protection.
Singed the edges with a lighter, and if you want it to conform to the contours of the floor you can heat it with a heat gun and while still warm place it in its desired location, but it will eventually place itself and form to the floor.
Works great for me, and also matches the interior.
spdfreak is offline   Reply With Quote
Old 12-05-2007, 07:29 AM   #4059
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Cleaning it is a good idea, but my guess is that it wont help much if at all.
Worth a try I guess.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 12-05-2007, 11:20 AM   #4060
Send a message via AIM to Dynasty47x1
Is there a writeup somewhere on the Gab mod i see Irishi's Os mod?
__________________
Blacked out 02 headlights,15% tint, 18" rims 245/40/18 Federal tires,Fstb,Gab Mod with K&n,Highflow cat, warpspeed y-pipe,17* advance.
Daily Driver:2000 Maxima
New Weekend Warrior: 1991 300zx 5spd
Dynasty47x1 is offline   Reply With Quote
Old 12-05-2007, 11:37 AM   #4061
I know this has been discussed a lot, but i havent found quite what i was looking for. If i missed it im sorry. I Have a 2002 and my maf went out, after some reading i decided to replace it with one from an '01 (2y001 or something like that) The car runs now, but I feel like I have lost A LOT of power on the lower end. I have asked dealerships but of course they tell me it's because I have the wrong sensor in. Has anyone else experienced this? Is it possible to just get my ECU reprogrammed? Everyone else has said it worked like a dream but i was left happy because my car was ruinning again but very pissed off when i really step on the gas. any help would be great!
ktcp643 is offline   Reply With Quote
Old 12-05-2007, 04:22 PM   #4062
what's emanage? aftermarket ECU?(for auto) If piggy back is not the same, what's the difference from emanage? what does it do? cant i just tune/map out the OEM ECU?
i need details on this if someone has a link. sorry not a pro on cars....
__________________
We're always together
maxximaa is offline   Reply With Quote
Old 12-05-2007, 05:44 PM   #4063
Certified Hooptie
NmexMAX's Avatar
Read the All Motor Stickys.
Quote:
Read the 5th gen stickys.
Quote:
Any new codes?
__________________
Old 12-05-2007, 08:10 PM   #4064
I have a 2002 GLE and my driver side windshield washer nozzle does not spray near as well as the passenger side... the pressure is very low compared to it. Could this be a pump problem or do i need a new nozzle? I really hate to take it in to the shop to have this looked at. But with the snow flying and the salt hitting the road i need to fix this one ASAP. Thanks
UnseenShadow is offline   Reply With Quote
