12-02-2007, 10:33 PM
#4001
pedal pusher
Quote:
Originally Posted by spdfreak
Not sure what you mean by "MDS ignition system".
A 5.5 turbo? Thats going to cost you.
Not MDS, MSD igniton. MSD being the brand name.
12-02-2007, 10:49 PM
#4002
Quote:
What about it. Our cars work with a coil pack per cylinder.
Have you read any stickies?
Doesn't seem so.
12-02-2007, 10:57 PM
#4003
That's Mr. Detail to you
GAB, Berk...
OSCAI-just did that one the other day-well, I cut the elbow and attached some 4" dryer ducting but haven't had a chance to cut an opening to make it a true CAI, but it definitely pulls in more air than just the small factory intake, top end feels noticably better. Probably do the GAB as well once I finish the OSCAI. For $11 in parts (dryer ducting, 4" worm clamp), it can't be beat.
FWIW, I did a similar set up on an Accord I used to own and when I replaced it with an AEM CAI, other than the weird 4000 rpm torque bump (typical of AEM intakes), the power didn't noticably increase over my home made set up but the noise sure did.
12-03-2007, 08:06 AM
#4004
Quote:
Originally Posted by bigjoe87865
Alright... im having this creaking noise... like an eirie creaking noise.... like a old wooden door..
anyways... the noise comes when my steering wheel is all the way to the left...and at a complete stop... and i decide to start moving forward... if the steering wheel isnt all the way to the left... and if i didnt start from a complete stop... I WONT hear the noise..
I did a search...
1 thread said that its my wheel bearing
another thread said its (3rd gen forums) strut bearing?
another thread said.. its the CV boot seal (if the sound was a grinding sound
as of right now... i dont hear it on the right side...
any suggestions?
edit :... i rechecked it.... the noise only stays on while the car is rolling from 0-3 mph.... has to be going really really slow... and only when turned to the left.... all the way.
AND... i jacked the car up on the front... and tried moving the front wheels.... it doesnt jiggle around or anything... which from what i read is a sympton of bad wheel bearings.
bump
12-03-2007, 09:03 AM
#4005
bump
This might seems weird but have you checked your brakes?
__________________
Been loving my max since 01
12-03-2007, 09:22 AM
#4006
I did a search...
any suggestions?
i had the same problem last winter, and for some reason it went away.
havent heard from it this winter yet but will keep an ear on it...
i dont what the problem is neither have a solution for it..
__________________
We're always together
12-03-2007, 03:54 PM
#4007
Heres a quick question since i just recently bought a 5.5 gen. I bought a set of clear corners question is how badly do people out there get nailed by the cops if they don't put red lights on the rears, but i assume it varies in different states. Specifically I'm in NJ.
__________________
1999 SE
2003 SE
2006 SE
Automagic FWD FTW!
12-03-2007, 03:58 PM
#4008
Quote:
After a year with no problems $101 ticket for me in WA. with superwhite bulbs. I've been running bulbless ever since.
__________________
I'd rather spoonfeed than Flame and Postwhore.
YA THERE HEAVY 20'S FROM A FX45
My 02 6-speed SE Mods = intake, headers, full custom exhaust with no cats, 75 nx wet shot nitrous,denso iridium 1 step colder plugs, ssim, slotted/drilled brakes, ce front strut bar, heavy arse wheels, tein s-tech, In need of a/f tuner and tune badly, Plus some other randoms
12-03-2007, 04:45 PM
#4009
i havent had bulbs in my corner lights for 2 years and no problems
12-03-2007, 05:00 PM
#4010
So you guys basically only running lights in the front and nothing in the back correct? Few minutes ago i just installed the back clears with 194 red bulbs but turned pink. thanks for the input i might as well take the bulbs out of the back and leave the amber bulbs in the front. Any suggestions on how to get a brighter red color rather then a pinkish lol.
__________________
1999 SE
2003 SE
2006 SE
Automagic FWD FTW!
12-03-2007, 05:27 PM
#4011
I don't have bulbs in the front or the rear. I put blue bulbs in for meets and thats it. It's not illegal or anything to not have bulbs in, only illigal to have the wrong color in
__________________
12-03-2007, 06:33 PM
#4012
'99 Maxima 16" wheels fit on '02 SE?
I've been running 16" snow tires on Altima steel wheels during the winter on my '02 SE (hey there were free).
Would '99 16" 5-spoke wheels fit?
12-03-2007, 06:36 PM
#4013
Certified Hooptie
I would assume so, since 02 GXE's came w/ 16's.
12-03-2007, 07:16 PM
#4014
2001 Maxima SE
Hello I'm a newbie here. I just bought a 2001 Maxima SE with cloth seats, automatic, without sun roof. My question to all of you is does the ABS come standard? I thought is was standard. I tried this weekend on the slick ice and it doesn't seem like the ABS engaged. The ABS light did not light up when I turned the ignition. I went to the fuse box inside the car and under the hood inside the engine compartment. The ABS fuse was inside box. When I went to relay box, the ABS acutator and motor relay was missing. Does this seem right? I found the actuator control module in the engine. Do I have ABS with this car? I really thought ABS was standard with 2001 SE. I do appreciate your input.
12-03-2007, 07:21 PM
#4015
Thanks- I know 16" wheels will fit since I've been running the Altima steel wheels the past 3 winters.
I've been poking around Tirerack.com that suggests my OEM 17" have a 40 mm offset with 5-114 bolt pattern, same as the '02 16" Altima S wheels (where I got the steel wheels) and same as the '99 Maxima SE (which is where I *think* the 5-spoke wheels for sale came from).
I was wondering if anybody has actually tried the swap before I buy them.
Thanks again,
Pat
fyi- 62,000 miles and problems have been: flaky auto-up passenger window, occasional cd trouble with the bose 6-cd changer (and those darn noisy rear windows). Love the 6-speed & wish I had the posi on the front end!
12-03-2007, 08:14 PM
#4016
Certified Hooptie
02 GXE’s came w/ 16’s, so, with that, I would assume they will fit. Also, 02 Altimas had the same brakes as 02 Maximas, so, yet another theory backing reason.
12-03-2007, 08:37 PM
#4017
JPayner4
In the "THE YELLOW BULB vs "LEXUS CAPSULE OFFICIAL COMPARISON" thread, are all of the yellow bulbs in this test HIDs or are they standars filament bulbs? As far as I understand they are all standard H3 filament bulbs that are just "yellow". I also understand that on page 5,6,7 they are filament bulbs with a capsule over them. But there is a picture and description of a capsule over an HID bulb. And also what about the comparison with the 3 cars in them from page one? I ask because I just got a HID conversion kit for my fogs and Im trying to figure out what mine are going to look like. I got the H3 bulb HID conversion kit with a 3000k bulb.
12-03-2007, 09:02 PM
#4018
Quote:
My understanding was that they were NOT HID bulbs. But, if you've got a 3000k kit, then that's even better.
There's a pic in that thread with 3000k HID headlights (not fogs) that should give you an idea on how the color will look.
12-03-2007, 10:08 PM
#4019
3-Peat!!!!!
Quote:
WRONG
front side must light and reflect amber
rear side must light and reflect red
how many times must this be argued on here
12-03-2007, 11:01 PM
#4020
Quote:
Originally Posted by soonerfan
WRONG
Didn't realize I was arguing or that there was even an argument. I just no many cars don't even come with sidemarkers so I guess it was my fault and I stand corrected. I guess the cars that don't have them maby have them in the headlight housing or corner light housing
__________________
#4021
any suggestions?
The sound that you are describing sounds like something my last two maximas have had. It is the steering stops. There are some pegs on each side of the car and when the steering wheel is turned all the way the peg will touch the stop. If the cap on the end of the peg is shot it will sound like metal on metal screeching together. I haven't replaced mine yet but I rotated the cap on the end a bit so a new spot was touching and the noise went away for a while. Might be worth looking at.
__________________
A33b 6MT
PR CAI hybrid intake ~ Flowmaster 50 Deltaflow ~
ES shifter bushings ~ Maxspeed with Tokico Blues ~
MT-90 ~ STS ~ G35 wheels BFG g-force Super Sport ~
PIAA bulbs with cleared headlights ~ Blacked out ~
12-03-2007, 11:04 PM
#4022
Not a Maxima owner
That would be my fancy pants.
I now have 3000k headlights and 3000k fogs.
__________________
Stance/Fitment - epitome of low, wide, and slow.
12-04-2007, 12:02 AM
#4023
Do Work.
Quote:
holy crap im surprised no one posted you an answer on this, this isnt safe at all!
IIRC your car should come with ABS standard, dunno whats up with your car though. Reason why i say it should have ABS standard because when i look up parts for our cars at work esp cv axles and other driveline/brake components i do not get an option for non abs equipped vehicles
__________________
00' Maxima
95' 240sx Work in progress.
12-04-2007, 01:32 AM
#4024
