Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-01-2007, 12:42 PM   #2561
I suppose I could put the old stereo back and see if the light goes off. It just seems like a big coincidence to me so I was wondering if others have noticed this problem.
hokie1525 is offline   Reply With Quote
Old 08-01-2007, 01:59 PM   #2562
Sexier Than Simpson
Bufflomike's Avatar
Quote:
Go to Autozone and have them pull the code and then we can tell exactly what the problem is. It may be your stereo has so much base you are kicking off the knock sensor code...
Bufflomike is offline   Reply With Quote
Old 08-01-2007, 05:02 PM   #2563
Ok. I took it to Autozone. The code came up P0011 and P0021. They are "Camshaft Position Actuator A - Bank 1" and "Bank 2" respectively. "Timing Over - Advan."
I had him erase the code. I then drove home (about 3 miles) without the radio. The warning did not reappear. I'm going to drive without the radio in the morning and see if it comes on. If not, my guess is the poster above was right...some loud bass during my testing of the unit may have triggered a sensor to register a bad number. So I guess I have to limit my bass in the future...
Old 08-01-2007, 05:30 PM   #2564
retired moderator
irish44j's Avatar
We don't bass here in Fairfax anyways
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 08-01-2007, 06:54 PM   #2565
----------irish44j
Hey, I got the ES FSB bushings you suggested..
To change em out there wasn't enough room for me to break the nuts with a socket, what do I do? You could remove the subframe bracket.. don't tell me I have to do that for 2 bushings..
__________________
MetalBlueMaxx is offline   Reply With Quote
Old 08-01-2007, 07:51 PM   #2566
retired moderator
irish44j's Avatar
Quote:
Originally Posted by MetalBlueMaxx
----------irish44j
what do you mean there isn't room?
I'm pretty sure I used a socket....maybe you need a smaller one
or just use box-end wrench with another one flipped over on the end as a cheater for leverage....
The bolts aren't really very tight. Douse them in PB blaster and you shouldn't have any trouble breaking them free.
__________________
Old 08-02-2007, 10:26 AM   #2567
Clock Wiring Harness
From this link: http://forums.maxima.org/showthread....193#post548193
The writeup talks about a scanner. I just want to tap an LED in there. I know the yellow/red is 12V when ign is OFF. Do I use the black wire on the harness for my negative lead?
ty
__________________
www.tsk808's.cardomain.site.com
tsk808 is offline   Reply With Quote
Old 08-02-2007, 02:39 PM   #2568
Yeah I have really bad tools with lots of play Lol. I didn't think of the wrench.. I"ll try that. Thx. PB blaster.. who needs PB blaster. Yeah ok.. I'll go pick some up. Thanks for the advice woo FSB bushings, new boots, cut bumps, and new strut bearings my car is going to float
__________________
Old 08-02-2007, 05:58 PM   #2569
Skyline Calipers
just wanted to know if the Skyline R32 front brake calipers are the same as the 300zx calipers and could be used in the maxima bbks like the blehmco kit. they look similar in design and structure but the R32's ar a bit beefier
SE My 6sp is offline   Reply With Quote
Old 08-02-2007, 09:02 PM   #2570
I can't seem to find a write up on how to install reverse indigo glow gauges.
Anyone have any pointers? I know how to take the cluster out and thats about all. I don't want to flush mount the switch just, put in the gauges. I have an 01 maxima. and the gauges look like this
Any help would be appreciated.
imported_eddie_D is offline   Reply With Quote
Old 08-03-2007, 06:00 AM   #2571
Sexier Than Simpson
Bufflomike's Avatar
Hey where did you get those because I bought my car with them:
Old 08-03-2007, 12:48 PM   #2572
Send a message via AIM to sirjinx21jay Send a message via Yahoo to sirjinx21jay
How Do You....
Can someone tell me how to replace the spark plugs in my car it's a 2000 SE Max????
Jay
sirjinx21jay is offline   Reply With Quote
Old 08-03-2007, 01:00 PM   #2573
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
Jay
http://www.cardomain.com/ride/2076435/5
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 08-03-2007, 01:04 PM   #2574
Quote:
Originally Posted by NmexMAX
Thanks im going to check it out now.....
Old 08-03-2007, 01:08 PM   #2575
Now how hard is it to do this cause it looks easy but i dont want to be fooled by the pics.....
Old 08-03-2007, 01:24 PM   #2576
Certified Hooptie
NmexMAX's Avatar
Follow the instructions it's not that hard.
__________________
Old 08-03-2007, 01:32 PM   #2577
Oh ok....i will do that.... now i have to find a place that sells the ignition coils at a good price....lol
Old 08-03-2007, 01:36 PM   #2578
Certified Hooptie
NmexMAX's Avatar
BTW, you don't need to repalce the coils if they're not bad. You can, if you want to, only repalce the plugs.
__________________
Old 08-03-2007, 01:43 PM   #2579
i thought that i should do that cause i just bought the car in march of this year and the check engine light comes on and off periodically and the p120 code reads all the time so i was just trying to take baby steps at correcting the issue with what time and resources i have so i was wondering why not change them cause i dont know who did what on this car before i bought it and the dealership where i got the car from is being really "tight-lip" (lol) about the maintenance done to the car.......they probably do not know.... lol
Old 08-03-2007, 01:55 PM   #2580
Certified Hooptie
NmexMAX's Avatar
In that case, it's a good idea.
__________________
Old 08-03-2007, 02:01 PM   #2581
Quote:
http://www.procarparts.com/store-det...0MX%2D12041RGX
Anyone?
Old 08-03-2007, 05:24 PM   #2582
what are the cheapest and/or easiest performance mods for a 5th gen auto?
Sadida is offline   Reply With Quote
Old 08-03-2007, 05:30 PM   #2583
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
Quote:
3.0 (00-01) or 3.5 (02-03)?
the answer is in the stickies.
if you have specific questions about a specific mod, post here for more information.
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 08-04-2007, 05:47 AM   #2584
tru story
SoonerFan's Avatar
bump...so people who cant remove their MAF wire harness realize the correct thread for newbies questions
Old 08-04-2007, 12:42 PM   #2585
I have new clear marker lights and all the links in the stickies with directions to swap them out are dead....anyone know where a good tutorial is?? I don't have a manual so i'm not sure if it tells you in there or not..2000 GLE
ageezee is offline   Reply With Quote
Old 08-04-2007, 12:45 PM   #2586
Certified Hooptie
NmexMAX's Avatar
Quote:
http://www.courtesyparts.com/nissan-manual/index.html
__________________
Old 08-04-2007, 12:52 PM   #2587
Anybody know where i can go to find a list of the original colors that the '03 came in?
BamaMule is offline   Reply With Quote
Old 08-04-2007, 01:17 PM   #2588
thanks!!!!!!!
Old 08-04-2007, 01:34 PM   #2589
Quote:
anyone know about the skyline calipers
Old 08-04-2007, 02:14 PM   #2590
tru story
SoonerFan's Avatar
__________________
06 Mazda 6
Old 08-04-2007, 02:37 PM   #2591
tru story
SoonerFan's Avatar
Quote:
some answers can be found with google
http://www.carsdirect.com/2003/nissan/maxima/colors
__________________
06 Mazda 6
Old 08-06-2007, 07:52 AM   #2592
Power Steering High Pressure Hose is leaking!
Has anyone replaced the Power Steering high pressure hose on an 02? I need suggestions for getting to the lower side for replacement.
jkmorgan3max02 is offline   Reply With Quote
Old 08-06-2007, 08:35 AM   #2593
Any ideas on how to remove a stuck spark plug socket that is in the chamber? I have tried everything to get it out. My only hope is to wait for the car to cool off a bit, then try to go at it again. The wrench extension just won't hold on to the socket.
Brunt182 is offline   Reply With Quote
Old 08-06-2007, 09:34 AM   #2594
Hows it going... Since its obvious that the whole Helios HID thing didnt work out too well for some folks(my apologies to all who got burned), Is there another company out there who offers HID kits for an 02 SE.. Headlights and Fogs?
SexiMaxSE is offline   Reply With Quote
Old 08-06-2007, 10:37 AM   #2595
Startin from da beginning
alicious's Avatar
Send a message via ICQ to alicious Send a message via AIM to alicious
Quote:
Several in the GD section
http://forums.maxima.org/showthread.php?t=515274
WTB: Stock 02 16" wheel
http://forums.maxima.org/showthread.php?t=518750
alicious is offline   Reply With Quote
Old 08-06-2007, 10:59 AM   #2596
Quick question whats the bulb size for the map light and the dome light. For a 2001 Se. I remember readint it somewhere, just can't find it again. Thanks in advance.
Old 08-06-2007, 11:08 AM   #2597
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Quote:
Is it stuck on the plug or in the chamber? If it's stuck on the plug than yes, and it's going to sound so simple...... Unscrew the plug, take it all back out, and tightly wrap electrical tape around the socket and extension, if it is stuck in the chamber you will need the assistance of some really really long needle nose pliers.
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
Cheap VIAS block plates
Dual-mass 6-speed flywheel resurfacing available!
NX wet kit w/digital gauge $400 shipped
KRRZ350 is offline   Reply With Quote
Old 08-06-2007, 11:16 AM   #2598
I have a 2003 Maxima and recently installed a trailer hitch. Does anyonehave any idea what the maximum towing capacity is? I am trying to keep it below 1500 lbs.
kevinhcraig is offline   Reply With Quote
Old 08-06-2007, 12:17 PM   #2599
Send a message via MSN to NJYTHRD
rotors.........
I was looking at all the good upgrades and suggestions on the other threads , but my question is -- has any body stayed stock and bought rotors from NAPA.....? and if so were they up to par? (with the ceramic pads..)
thanks for the input.....
__________________
NJYTHRD
NJYTHRD is offline   Reply With Quote
Old 08-06-2007, 12:24 PM   #2600
thank u Alicious... That helped alot.. I appreciate it.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
