Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-18-2007, 06:13 PM   #2481
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
dealership has to do it.
whats with the pics of the neon
if you have both, at least use pics of the maxima on here
SoonerFan is offline   Reply With Quote
Old 07-19-2007, 10:16 AM   #2482
00 se wont start!!, help!!!!!
my car wont start, i checked all battery connections and they re fine. it just clicks once when i turn the key so i assumed it was the starter. so from there i attempted to push start the car by catching it in gear to get to my buddies house to install a new starter. i could not get the car to start that way either. the car only has 59k on it. anyone haev any ideas about what could be wrong???
skiingss454 is offline   Reply With Quote
Old 07-19-2007, 10:54 AM   #2483
Sexier Than Simpson
Bufflomike's Avatar
I was thinking the clutch pedal sensor that tells the car it is okay to fire since it is not engaged but since you tried push starting that rules that out I believe but I am unsure.
When you push start what happens? Does it try to start? Does it just grab the clutch and bog?
Bufflomike is offline   Reply With Quote
Old 07-19-2007, 12:49 PM   #2484
2000 nissan maxima GXE
Hi everyone, I just had a few questions about my fiances new maxima. Its a 2000 GXE model with the 3.0L V6, the keyfobs that came with it dont work... and judging from their condition they probably never will... I have a 06 spec v sentra I dont use mine, is there anyway I can reprogram them to work for her car... Also when driving in a straight line in the car you have to hold the steering wheel probably about 1/8 of a turn of the wheel to keep it going straight... when I step into it holding the wheel dead straight allows the car to go in a straight line but when you let off there is... almost like a pop in the front end and you have to go right back to the 1/8 of a turn to keep it going in a straight line... the tires are kinda bad, and I know that isnt the problem but does anyone have any ideas?
thanks! The car also didnt come with the fog lights... I really like the way they look on the maxima and it would be a nice function for the car to have, would i have to go to the dealer?
cobra989 is offline   Reply With Quote
Old 07-19-2007, 01:04 PM   #2485
the car seems to start meaning all of the warning lights turn off but then when i push in the clutch pedal it just dies the gas pedal seems to bog out as you were saying
Old 07-19-2007, 05:23 PM   #2486
A/C control unit lights
wasup gents,
lights are out for my a/c unit controls. Can anyone confirm 27545MA is the right part to get? How do I convert this part no. to an aftermarket/sylvania, etc.?
thanks!
__________________
www.tsk808's.cardomain.site.com
tsk808 is offline   Reply With Quote
Old 07-19-2007, 05:57 PM   #2487
Hello all, I have learned so much reading this forum, but never had a reason to post until now....... I was rear-ended, spun several times, and slammed the left side against the guardrail. My 2000 Maxima SE with 120K miles had $6K in damage. I ended up facing the wrong way on the highway, and trying to start the car in a panic but it would not idle, finally I worked both the accelerater and brake together to move it. I got out checked everything, and found that I was still some what drivable. I again used the gas/brake method to limp it home. I immediately noticed the SES light was on, and so advised the body shop when I delivered it to them. Body shop takes it to the dealer, and that’s where it sets now, with code P0505, and needs an IACV-AAC replacement. My issue is the insurance company is saying this is not related to the accident, and I have to pay. I need a good argument, because the burden of proof is now with me to prove it happened during the accident. No physical damage to front-end, or to the IACV-AAC. Is this a mechanical device that can be damaged by impact? I would be grateful for any ideas on how to prove this? Thank you all Randy
capt_z1 is offline   Reply With Quote
Old 07-19-2007, 07:20 PM   #2488
tell them the car started fine prior to the accident...IIRC, the ECU might be able to remember how many times a code has come up (dont quote me).
slickrick is offline   Reply With Quote
Old 07-19-2007, 08:48 PM   #2489
Quote:
Great thought. I never thought of this. Possible there's a data logger of some type?
I wonder if having the battery disco'd for a month at the Body shop would have cleared the logs?.
I will research this, and let you know what i find out. thanks again
Old 07-19-2007, 08:51 PM   #2490
good luck...tell the insurance company they can pay the dealer to hook up the ECU and find out...otherwise save that $ and fix your problem.
Old 07-19-2007, 10:09 PM   #2491
Hi,
I am not sure if all 5th generation Maxima's have this, but my 2001 20th Anniversary Edition has a ring tone whenever you put the car in reverse (it is getting annoying after awhile). I was just wondering if there is a way to disable that function? Can it be done, if so, how?
Thank you in advance,
K.O.D is offline   Reply With Quote
Old 07-19-2007, 10:43 PM   #2492
SlickRick, I appreciate the help very much. ah Luck, I am going to need it. The Insurance company is already refusing to pay the diagnostic fee, so I am already out those $, don't know how much yet, will find out tomorrow. The dealer wants 1000.00 for the repair, 600.00 for the part,talk about a rip off. However I found the part for 209.00 + shipping,
I will ask that they use the consult to try to determine when the first error was thrown. If there is data and info there, I hope it will give the proof i need. If not, I'll start researching here, and am sure I'll need installation advise.
btw It was a hit and run, so no help from the culprit. I've already paid the deductible, and six weeks of rental cars, so they've worn me down, ouch... thanks again Randy
Old 07-19-2007, 11:11 PM   #2493
damn...well another small tip is to buy OEM parts from Dave B to save $ if insurance leaves you SOL...search for his # its worth it.
Old 07-19-2007, 11:13 PM   #2494
[quote=dwareroy]
Hey, my car opener recently just began to open only the driver's door no matter how many times I replaced it. I changed the battery and I am still having the same issue. Do I need to get a new door opener?
Quote:
Originally Posted by KRRZ350
does the inside switch still unlock all the doors?
Yes. It still unlocks all the doors.
dwareroy is offline   Reply With Quote
Old 07-20-2007, 12:54 AM   #2495
I will search him out, i have seen his name a few times while reading the forum. thanks for the tip !
Old 07-20-2007, 11:56 AM   #2496
Quote:
Originally Posted by K.O.D
Hi,
I'd say it's aftermarket or modded because my AE doesn't do that. Do you have some kind of navi installed? i know some (with backup cams) have a backup chime.
Is the chime different from any other ones that car has? ie. the "key in ignition reminder" or "lights are on" chime?
__________________
Old 07-20-2007, 12:00 PM   #2497
Just wondering if anyone has had success purchasing headlights from a certain ebay dealer...My passenger side caught a boulder yesterday and is cracked...need to get the pair of them for it to look half decent cause the drivers side has a slight haze. Talked to Dave B....596 each...dont really want to spend that much but may have to...for an '03 Max.
SiLvErBaCk82 is offline   Reply With Quote
Old 07-20-2007, 12:51 PM   #2498
__________________________________________________ _______________
I bought the car used so I am not sure if it was modded or not. The chime sounds like a generic ringtone.
Old 07-21-2007, 02:43 PM   #2499
Hey.. can't seem to find this sight, could somebody please tell me where to find energy suspension FSB bearings. Thanks.
MetalBlueMaxx is offline   Reply With Quote
Old 07-22-2007, 02:24 PM   #2500
Ok I found where to buy them. Do I need 22mm or 23mm??
Old 07-22-2007, 05:03 PM   #2501
Send a message via AIM to GigEmAgs07
okay so my car had been dying relatively consistently while in park. I took her into my mechanic yesterday. They cleaned the maf, and it hasn't died since, and it shifts very smoothly. They also cleaned the throttle body. However, the car doesn't seem as perky as it did a few months ago. This is not an observation i've made since i picked the car up yesterday, but rather over the last couple months. She just seems weak. Accelerating onto the highway isn't fun like it used to be. She's not pulling very hard at all. Any ideas as to what i could do to get her perky again?
__________________
Beat the Hell Outta Coach Fran
GigEmAgs07 is offline   Reply With Quote
Old 07-22-2007, 06:34 PM   #2502
I'm having trouble seeing posts! The last post I can see in this thread for instance was made on 5-28. If I go to "Advanced" under the text reply box I can see the most recent posts in the posts previews that show up on the bottom. Other than that there's some serious trouble. DoubyaTeeEff?
viperxiv is offline   Reply With Quote
Old 07-22-2007, 06:56 PM   #2503
Im looking to upgrade my brakes and im looking at the blehmco brake kit, but i heard somethin about a cobra brake kit that fits our cars. Is this the 13" brake kit from the mustang cobra???? they look very similar to the stillen bbk. because i have an extra cobra bbk lying aroud from my last car.
SE My 6sp is offline   Reply With Quote
Old 07-22-2007, 08:41 PM   #2504
After the starter went out...
I noticed the sound system and clock do not work. I checked all the fuese and they are all good. Whats next??
Old Blue 66 is offline   Reply With Quote
Old 07-22-2007, 08:42 PM   #2505
retired moderator
irish44j's Avatar
Quote:
if you have an SE, 23mm
GLE or GXE, 22mm.
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 07-22-2007, 08:44 PM   #2506
retired moderator
irish44j's Avatar
Quote:
the "cobra" brake kit uses:
z32 calipers (300zx)
jeff92se's relocations brackets
cobra rotors
jeff's hubcentric rings for the rotors.
It's similar to the blehmco kit.....except the rotors are a bit bigger.
__________________
Old 07-22-2007, 08:45 PM   #2507
retired moderator
irish44j's Avatar
Quote:
now recheck the rest of the fuses.....under the hood in 2 boxes, and on driver's side kick panel.
You definitely have a blown fuse.
__________________
Old 07-22-2007, 08:46 PM   #2508
retired moderator
irish44j's Avatar
hint: his number is in the 5th gen stickies (FAQ's)...
__________________
Old 07-23-2007, 07:03 AM   #2509
I thought the same thing, but which one is it? The only fuses that sounded like they had anything to do with the sound system were checked and were ok.
Under the hood, theres one called speaker? And under the dash, its called audio which is fine as well. I checked a couple of others that might have been associated with the sound system and no luck. Anyone know which one it is??
Im at a loss.
Old 07-23-2007, 08:53 AM   #2510
thanks so much, I was spending a lot of time looking for it ! Randy
Old 07-23-2007, 09:15 AM   #2511
GLE or GXE, 22mm.
Thanks, yall are the best for helping people like this. Time to get this order on! Lol $17, not bad!
__________________
Old 07-23-2007, 01:15 PM   #2512
so i was gettin some road noise from the rear wheels. Took it to discount and they rotated/balanced all 4 wheels. Now the noise is comin from the front wheels? What now?
Old 07-23-2007, 07:20 PM   #2513
stock 2000se rims are 225/50r17 , will 225/55r17 be ok or will it have clearance issues when i hit bumps ...being in ny i figure the 55 will give more cushion for potholes and the 2 tires that im leaning to only available so far in 55 at sears and tirerack no 50 the hydroedge and bf goodrich tractions t/at
93 SE is offline   Reply With Quote
Old 07-23-2007, 07:47 PM   #2514
retired moderator
irish44j's Avatar
Quote:
well, let's think about this for a moment, ok?
1. the noise was coming from the rear wheels.
2. they rotated the tires
3. the noise is now coming from the front wheels
solution: the noise is related to one of the tires. Many tires get noisier as they wear, or are wearing unevenly.
Replace the tire, and you will get rid of the noise.
__________________
Old 07-23-2007, 07:49 PM   #2515
retired moderator
irish44j's Avatar
Quote:
they will fit, but will look like balloons. You don't want either of those tires anyhow. If you're looking for wet traction go with Toyo Proxes4 or Falken 512/912 - both of which come in stock size, and both of which you should be able to get at Sears.
check www.edgeracing.com if you want to order online, better prices than tirerack.
__________________
Old 07-23-2007, 07:50 PM   #2516
retired moderator
irish44j's Avatar
Im at a loss.
check the lighting fuses as well.
even better, just check ALL the fuses until you find the right one. There are more fuses associated with the sound system than just the ones that are marked as such.
__________________
Old 07-23-2007, 08:12 PM   #2517
Looks like thats what Ill have to do. Its a task I was hoping to get out of....
Thanks!!
Old 07-23-2007, 08:13 PM   #2518
Agreed on the ballons look. I did that because I got a really good deal on a set. After a while I got used to it. But they DID offer a bettrer ride. Not so harsh and didnt rub on anything.
Old 07-23-2007, 08:20 PM   #2519
well it's noticeable above 30-35 mph, but even worse when i'm turning right (when the load falls onto the front left wheel). I looked and they added SEVEN or eight of those little metallic weights to the left front wheel. It's just crazy lots more noticeable... not sure how it got to be that bad when it clearly wasn't before.
__________________
Old 07-23-2007, 08:22 PM   #2520
Newbie to the site and new to the 5th Gens. I just bought an 03 SE TE 6-Speed. I am new to mods with a N/A engines as my past 2 vehicles have been Turbo AWD DSM's (Talon/Eclipse). It is easy and relatively inexpensive with turbo vehicles... Intake, Exhaust, bigger turbo, more fuel and you can almost double the stock horsepower and torque. As I have been reading night after night I am finding it hard to determine a good starting point with my new Max. It seems like the ideal would be to mimic the 350Z. What are the differences between the VQ35DE in the Z's from the VQ35DE in the Max? This might help determine a good starting point. Thanks for all the info guys!
girvinman is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
