5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
ok jus wondering because i changed mine last year around thanksgiving and was wondering do you change them every year....jus feel a lil misfire in the engine......a barely little shake and i figured if i changed the plugs it would go away....
i had one bad coil and i replaced that a while back......and i dont have a check engine light....i mean on a level of like 1-10 on the shake its like a 1 4real....but still dont like things goin on with the car......and i put in bosch last thanksgiving....
If they are bosch then they are platinum plugs, those should last you a while. Also sometimes if you have a bad coil it wont thow a code immediately.
I wouldn't put Bosch. Also, "last Thanksgiving" is very vague. Mileage is more important.
Quote:
Originally Posted by s10_mack
I don't want a skyline, I want a Maxima with a skyline motor because I have a family that needs a sedan, and I want just want something to occupy some of my spare time. It's just a project.
If you want a cool project, build a DE/HR hybrid w/ some extra goodies (cams, HR-Z pistons/ L34 IM) and toss it in your Max.
Quote:
Originally Posted by Scottwax
Probably be more cost effective to find a totaled G37 and snag that motor, transmission and wiring harness for a swap. 85 hp more than stock right off the bat.
Holy mother of all that is holy and electrical. I think I would myself trying to get that ECU config in my car. Aside from that, something needs to be tweaked with that thing. To my horrific surprise (read: disappointment) the HR in the new Z gives a better, fatter power curve.
True but if you are going to spend a ridiculous amount of money on a swap, why not go RWD as well?
No, still no. Define ridiculous.
__________________ 03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
if you had great fab skills you could make a RWD max for not THAT much. obviously it would take forever in the driveway though and having a shop do it would cost the original asking price of the car...plus some
Thank you. That is exactly mine look like. Your box is missing an ABS ACTR & ABS motor relay. I assume your ABS is working?
I am going to scan my computer but no check engine or abs light on.
Do you think scanner will read any codes based on this?
I was interested in getting a new sound system put in my 01 GLE.. but from looking at the dash unit, putting anything else in seems like it wouldn't turn out to pretty.. I don't know much about sound systems for cars in general.. so i'm just curious of people who have replaced the bose and how well it turned out x_x
The audio forum is your friend...
__________________
2002 Maxima SE, NWP block plate, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Hello: I just bought an '02 Maxima from out of state. The car appears to have never had a license plate on the front before, but living in Ohio, I am required to have a front plate.
Is there a license plate bracket, specific to the '02 Maxima, that I need in order to mount a license plate? If so, where can I get that bracket.
The dealer should have the bracket, or you may find one available in the 5th gen for sale forum. I don't know if the front bumper is pre-drilled or not but if it isn't, you will have to drill two holes in it to attach the bracket.
__________________
I own 02 Maxima SE. I was looking through previous threads and couldn't find anything as far as a turbo for it. I know there is probably nothing that is a straight bolt on. If they are out there, then about the tuning? Could you perhaps point toward the right direction?
Your in the newbie section!
The right direction would be to look at the stickies of the Supercharged/Turbocharged section, under the Advanced Performance section.
Looked through the FAQ's and the How-To's, and did a google search but couldnt find anything on a fix for the glove compartment rattle. Can anyone point me to a thread or give some advice on how to fix it. Its bugging the hell out of me.
i have a question, why does my left speaker keep going in and out when i listen to the cd player, what is wrong with my system, i have a 2003 maxima se and a bose system, it's only when i play the cd player, when i play tape or fm radio its fine
__________________ Merlot 2003 Nissan Maxima SE
Mods
MOMO Challenger Pedals
Clear Front Bumper Lights
15% Tinted Windows
Stillen Hi-Flow Intake
What is a fair price to pay for an 02-03 full headlight conversion (ballasts, bulbs, housing, etc) for my 01?
Well for a set of oem headlights you should expect to pay between 400 and 600 dollars then the wiring harness is gonna cost you around 30-45 buck or maybe cheaper. Then you can look up direction on how to wire it its pretty easy or when you get everything just pm me and i'll send you the how-to
