Installed one wire out of the "Big 3" and wow....
Old 08-07-2006, 07:44 PM
  #41
retired moderator
irish44j's Avatar
Originally Posted by Metal Maxima
That being said, the sum of the highest possible amperage capacitance for 3 8AWG wires would still fall short of a single 1/0 AWG. I'm just a fan of taking the 'audio' route.
entirely true....I'm just not of the opinion that that much capacitance is needed in the case of an engine bay grounding setup.....but like I said, it's different if you have a high-power audio setup (which I really don't)
irish44j is offline
Old 08-07-2006, 08:43 PM
  #42
StL I30's Avatar
You need one of these:
http://www.darvex.com/miva/merchant....roduct_Count=1 to clean that battery terminal up nice. I got one off ebay for $7 shipped.
Did you use all 3ft on the battery ground? Grounded mine with 18" of 0/1ga. wire. Shorter the better.
StL I30 is offline
Old 08-07-2006, 08:47 PM
  #43
大陆弟弟
n3985's Avatar
Link to auction and pics installed please, always wanted one of those
n3985 is offline
Old 08-07-2006, 08:59 PM
  #44
StL I30's Avatar
It was before last winter that I won that auction. <<finds camera>> Pic shortly.
StL I30 is offline
Old 08-07-2006, 09:22 PM
  #45
StL I30's Avatar
I haven't done any of the other grounding mods. Only this one. She fires up 1st turn every time.
Have 8 gauge and 0/1 on the negative terminal. The blue is 4 gauge on the positive.
Wonder what my neighbor thinks of me taking battery pics at midnight.
StL I30 is offline
Old 08-07-2006, 09:24 PM
  #46
大陆弟弟
n3985's Avatar
Can someone direct me to a DIY on how to install one of those terminals? Remove the ring on factory terminal, insert into new, clamp down wire, and tighten around post?
Anf STL I30, you didn't fuse your + to alternator wire (blue)? Isn't it recommended? <- Nevermind, see the fuse now with bigger pics.
n3985 is offline
Old 08-07-2006, 09:30 PM
  #47
StL I30's Avatar
I'll try, it's easy
1)Remove factory terminal from battery terminal
2) Cut negative battery terminal off as close to terminal as possible
3) Tighten new battery terminal on negative battery post
4) Insert wire and tighten the according hex screw for the appropriate hole
Tools needed:
Wrench
Hex wrenches
Wire cutters
yeah edited last post for bigger pics-blue wire is amp
StL I30 is offline
Old 08-07-2006, 09:34 PM
  #48
大陆弟弟
n3985's Avatar
I cut off the factory terminal? .....what about when I go back to stock? (about 12 months from now)
n3985 is offline
Old 08-07-2006, 09:41 PM
  #49
StL I30's Avatar
Maybe something like this for $7.
I'd bet you can find a knock off on ebay for even cheaper. Autozone might have them.
But yeah you have to cut off the factory negative terminal.
StL I30 is offline
Old 08-08-2006, 04:39 AM
  #50
bigEL's Avatar
I think on one of SCC's project cars, they didn't mess around with no wussy cables. They just drilled 2 holes in a metal bar and bolted it from the negative terminal to the nearest point on the chassis.
bigEL is offline
Old 08-08-2006, 10:48 AM
  #51
kcowden's Avatar
Just what are the big 3?
Check the deadening sticky in the Audio section.
Checked Google and read through the deadening sticky and still can't seem to figure out what the "big 3" is. ????????????
kcowden is offline
Old 08-08-2006, 12:32 PM
  #52
siren001's Avatar
Power wire and ground wire from our alternator.
Hey what color is the power wire
What color is the ground wire from our alternators?
siren001 is offline
Old 08-08-2006, 12:54 PM
  #53
Max_Vader_2K's Avatar
Yea, me too. I found talk of "Big 3" but nothing that says what it is.
If someone dosent mind giving a simple anwser rather than dead end directions, it would be most appreciated.
And the question is, what is the "Big 3" ?
EDIT, I just found a site that that explained it.
BIG 3 = upgrades to the battery ground cable, starter cable and Alternator cable.
Max_Vader_2K is offline
Old 08-08-2006, 01:21 PM
  #54
SHIFT_om nom nom nom
Metal Maxima's Avatar
I already posted where to find the effing link.
Metal Maxima is offline
Old 08-09-2006, 12:57 AM
  #55
still brewin'
Yayomax's Avatar
So just to reiterate, a single 1/0 AWG wire from the - battery post to chassis, along with the other "Big 3", is more beneficial as a hyper ground solution than to have multiple 4 or 8 AWG wires at numerous points throughout the engine bay? Or is this to be used in conjunction with a hyper ground kit of some sort?
Yayomax is offline
Old 08-09-2006, 06:39 AM
  #56
Thats what I am gathering . . . . .
Old 08-09-2006, 06:42 AM
  #57
大陆弟弟
n3985's Avatar
Essentially yes, but you can use it in conjunction like me, which is overkill but a fun DIY project.
n3985 is offline
Old 08-09-2006, 07:27 AM
  #58
ShIft_uR FacE's Avatar
Any of you have the PPT saved? STL I30, where did you ground yours to? Seems different than N3985's.
ShIft_uR FacE is offline
Old 08-09-2006, 07:58 AM
  #59
I concur. A little overkill never hurt anyone.
Old 08-09-2006, 11:00 AM
  #60
大陆弟弟
n3985's Avatar
Spoken from the man with the overkill interior
n3985 is offline
Old 08-09-2006, 12:37 PM
  #61
siren001's Avatar
Anyone know this?
siren001 is offline
Old 08-09-2006, 02:18 PM
  #62
大陆弟弟
n3985's Avatar
Anyone know this?
You mean the factory ground wire already on the alternator? black....
n3985 is offline
Old 08-09-2006, 08:15 PM
  #63
siren001's Avatar
Which color is the factory power wire to the alternator? It looks like there is 2 or 3 wires going to it.
I want to run a new power wire 0 gauge and new ground wire 0 gauge, its a part of the big three.
siren001 is offline
Old 08-09-2006, 08:26 PM
  #64
rvamaxima's Avatar
Does anyone have a link to the stillen grounding wire install instructions?
rvamaxima is offline
Old 08-10-2006, 02:38 AM
  #65
Suspension Yoda
djfrestyl's Avatar
Just trace it, it's not that hard. The answer to this question doesn't even need to be answered because you are not REPLACING wire when doing the Big 3, you are adding to it. If you can't trace a wire then this mod may not be for you.
djfrestyl is offline
Old 08-11-2006, 07:43 AM
  #66
aminus21's Avatar
doesnt the stock negative terminal already go from the battery post tp chassis?
aminus21 is offline
Old 08-11-2006, 11:40 AM
  #67
Jfree's Avatar
As stated, dont replace it just add on. Removing the stock wire will just be a PITA since its goes all over the place and in my case is wrapped up with several other wires. Remember once you have installed the bigger wires, the power takes the path of less resistance. The only wire that is easy (to me) to remove is the stock negative wire from the chasis to the battery.
http://www.caraudio.com/forum/showthread.php?t=152355
Jfree is offline
MaximaDrvr
08-19-2015 08:20 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
kirkhilles
08-08-2015 10:53 AM
maximaham
08-07-2015 01:11 PM
Quick Reply: Installed one wire out of the "Big 3" and wow....
