06-06-2007, 03:16 PM
#201
Certified Hooptie
Quote:
Originally Posted by OOmaxSE
How necessary is it to relocate to the collectors? It makes more sense to have it at the collectors to me, but I do know that the stock manifolds have o2 bungs at the primaries. It probably makes a difference in a performance aspect?
Performance would not be affected, only gas mileage. And even then, it wouldn't be a horrendous difference.
06-06-2007, 05:49 PM
#202
I am going to try cutting the bung down a little and surfacing it to get it flat. That way the bung will clear. Have that done tomorrow evening hopefully.
06-28-2007, 10:03 PM
#203
Anyone buy OBX headers from ebay and have fitting issues??
I know most people say go with the cattman headers, but thats a good 800 dollars and the hotshots are a done deal. a few months from now ima be looking into some headers, gotta know what to look into and where to buy them.
__________________
 Bown down biatch
he's my second alarm
07-20-2007, 08:22 AM
#204
Certified Hooptie
This might help. http://forums.maxima.org/showthread.php?t=512293
07-30-2007, 04:14 PM
#205
If i get Cattman or OBX headers for my 2001 SE, will i need to change any sensors?
07-30-2007, 05:13 PM
#206
Maxima.org caught teh GAY
Quote:
No, either re-locate the secondary sensors or sim them.
07-30-2007, 05:35 PM
#207
Quote:
Originally Posted by NmexMAX
helped alot!!
ViperVadim - OBX headers - "if you can replace the flex section and the outlet piece with 2.5in piping more gains will be had in the midrange and top-end."
Same piping as the cattman headers = damage
__________________
 Bown down biatch
08-08-2007, 04:24 PM
#208
hmm.....
08-08-2007, 04:40 PM
#209
call cattman...
08-09-2007, 07:47 AM
#210
Owns a Maxima
Quote:
Originally Posted by nicenotrice
Like SlickRick said, call Brian Catts; their website isn't updated. He has headers for your 2002 and the catbacks are the same for 00-03s, well with the exception of the Fed spec 2000s because of the O2 bung on the b-pipe.
08-09-2007, 08:04 AM
#211
to call.... or not to call.... it's not even a question
yeah def call them up, because they dont show their headers on their website but it dont mean they dont sell them... theres alot more you'll learn from them if you call
08-10-2007, 05:42 PM
#212
Here's what I did for my relocation on my 2000 cali spec. These are the Hotshot header. It's a little too late because they don't sell them anymore (lazy me).
08-27-2007, 05:46 PM
#213
Sorry for asking a question that may have been covered:
Im buying hotshot headers for my 5.5...will I run into any fitment issues? I was reading about the EGRs and I recall some had fitment issues with the AC lines.
__________________
2006 CBR 600rr - 115whp
2003 Maxima SE TE 6mt l 8k Fogs + headlights l JWT Popcharger w/ berk midpipe l Cattman Catback and headers l Fidanza flywheel l Spec Stage 3 clutch l Warpspeed test pipe l Tein SS coilovers l Stillen Classic lip l AE rear l 7" Clarion touch screen
08-27-2007, 06:06 PM
#214
Need A Light?
you will not have issues...that is with the 5th gen...but our 5.5 gens are direct bolt on...ac and egr will not get in your way
08-27-2007, 06:35 PM
#215
positive? if so then thats a relief...at the price I cant pass these up for Cattman headers..even if their material is not as good and the gains will be somewhat less..thanks for the response
__________________
08-27-2007, 07:07 PM
#216
Need A Light?
yes i am positive...go check out all the header threads...and you will see what i mean...and if anything, HS will probably score higher than cattman....at least the new cattmans...
HS = Cattman Gen 1
HS > Cattman Gen 2
HS > Cattman Gen 3 <-----(not totally sure but it looks like it from the dynos)
08-27-2007, 07:13 PM
#217
Certified Hooptie
Ever try reading the first page of this sticky?
Quote:
Originally Posted by Puppetmaster
08-27-2007, 08:33 PM
#218
I read those but I also read somewhere that someone w/ HS had a bad installation exp. b/c the ypipe was extremely close to the oil pan and draining oil would result in it spilling over the ypipe. I know the general consensus is that HS fit fine but Im sure there are some that ran into problems.
Also, the HS headers Im getting have minimal rust..I could see small brown spots on the ypipe..not the headers so much (very minimal on the headers). Is this a cause for concern?
__________________
08-27-2007, 08:34 PM
#219
5.5 gens do not have EGR systems, so you don't have to worry. The AC line should not be an issue although I've read that someone had a problem with the clearance of their 5.5 gen. Either way, you won't have a major problem with HS installation, but you may have you slightly bend your o2 sensor at the MOST.
08-27-2007, 08:36 PM
#220
Need A Light?
you probably mistaken that for cattman gen 2's....they had a problem with oil spilling onto the ypipe
only the VERY early generation HS headers have problems...and they had fitment issues not ypipe too close to the oil pan issues....but i am sure those don't exist no more...
08-27-2007, 09:17 PM
#221
cool thanks for the heads up!
08-28-2007, 12:17 PM
#222
Im looking into buying some exhaust wrap for the ypipe and headers.
http://store.summitracing.com/partde...5&autoview=sku
Has anyone used this? More than reducing heat in the bay Im really looking to prevent possible rust on the parts. The description does not mention that it will prevent rust so Im asking if any of you have this and whether it prevented rust or not. Are there any downsides of using this?
I also saw this:
http://store.summitracing.com/partde...art=DEI-010301
__________________
08-28-2007, 12:25 PM
#223
does your set of HotShots have a ceramic coating?
If it does, I guess wrapping them is a big nono...
08-28-2007, 12:57 PM
#224
i know they have some kind of coating..just dont know what
08-28-2007, 01:24 PM
#225
looks like a dirty set of ceramic coated headers
08-29-2007, 10:37 AM
#226
edit:
10char
__________________
