04-26-2007, 11:12 AM
#161
Bad *** Newb
Quote:
Originally Posted by knight_yyz
i have cattman 3.0 headers on my 3.5 because there was a miscommunication. I had to buy a plug for the egr valve. Ports are the same.
bty that is going to be freeking loud!!
hehe  That's what I'm going for. I have all of these morons with crapstangs and junk cars like that around me with "exhausts". I'm fixing to make them all look like pansies
04-26-2007, 11:17 AM
#162
Owns a Maxima
Quote:
Originally Posted by MaxBoost925
Are you sure dude? Me and Steven88 both had bend it on our cars.
I'm pretty sure I'd remember having to intentionally bend a motor mount bracket, lol. Nope, didn't have to do it.
04-26-2007, 03:12 PM
#163
Need A Light?
Quote:
thats weird...maybe you worked from the top and bottom? cuz we worked completely from the bottom of the car
04-27-2007, 08:25 AM
#164
Owns a Maxima
Quote:
Yeah, we worked on the rear manifold from both top and bottom. Trust me, I remember because a certain unnamed person was afraid to get under the motor with the center member removed, so he was helping from top.
04-27-2007, 08:29 AM
#165
Certified Hooptie
I worked 100% from the bottom. Had to tilt the engine sideways IBitsalreadysidewaysFWD.
Which means, it needed to be taken off mounts etc.
04-27-2007, 10:08 AM
#166
is there anyway the motor can fall out if the center member is removed?
04-27-2007, 10:28 AM
#167
Not a Maxima owner
Quote:
No. Not if you leave the top mounts intact.
My motor was hanging by 1 motormount, I had to place a jack under it to keep it secured.
__________________
Stance/Fitment - epitome of low, wide, and slow.
04-27-2007, 10:39 AM
#168
Owns a Maxima
No, there are 4 motor mounts; front, rear, left, and right. The removal of the center member only requires front and rear be removed, so the motor will remain in place via the two side mounts. You will be able to rock it back and forth (its not something I'd do for fun though) to move it around to get to the manifolds if necessary.
Some people play it safe by putting a jack or jack stand under the tranny, but as long as the side mounts are secure, you don't really need to.
04-27-2007, 04:40 PM
#169
For my header install, didn't bend any motor mounts. I completely took off the front and rear motor mounts on the cross member. Unless you guys are talking about 3.5L.
04-27-2007, 05:01 PM
#170
Quote:
We bent the mount brackets not the mounts themselves. 3.0 or 3.5, Maxboost and Blackbirdvq both have 3.0's and they had to bend their brackets.
Towards the middle of the write up..... 5Zigen MK6 for my I35
__________________
Polished Titanium 03 SE TE 6MT HLSD
I/H/E/Maxspeeds/Illuminas/Pioneer D3 touch screen/a few other goodies
New Money Pit: 2002 Honda VFR 800
04-27-2007, 05:25 PM
#171
my crossmember never came off on my install..all done with removing the IM
04-27-2007, 07:04 PM
#172
Maxima.org caught teh GAY
I never had to bend mine, and I put on Hotshot and Cattmans...
04-27-2007, 09:36 PM
#173
This write up should definitely be at the front of the page. This answered all my questions that i may have posted earlier about the tools and etc. Thanks.
04-28-2007, 03:47 AM
#174
hahaha thank Puppetmaster. Its on the first page. Its on Puppet's install tips then theres a link in there to Blackbird's write up, just wanted you to do your research so that YOU found it.
P.S. I heart tequila
04-28-2007, 06:24 AM
#175
drag racing is for wussies
I didn't have to bend any motor mounts for my install. Once you remove the center member, you can tilt the motor backwards and will be able to reach the bolts on the rear header. Removing the IM will also help getting to the upper bolts from above.
There is a bracket that bolts up to the BACK side of the motor- it attaches to the block with 14mm bolts x 4. There is a 17mm bolt that goes through it AND the rear engine mount. In order to remove those 4 bolts you need to bend the RIBBED tab inside that bracket, use a large prybar to bend that and then get yourself a 14mm boxed end wrench to break those suckers loose. They should come out by hand if the engine doesn't have a million miles on it.
I always remove the cross member, it makes this job much easier than removing the intake manifold. You CAN reuse your stock exhaust manifold gaskets AT the head, they are metal- vs the cheap stuff that comes with your new headers that will eventually leak.
__________________
Mike Jez
2004 Volkswagen R32.
OZ wheels, tons of suspension mods, brakes, go fast & light goodies.
04-28-2007, 11:13 AM
#176
Certified Hooptie
Cattmans gaskets are very nice. Metal.
05-04-2007, 06:33 PM
#177
Quote:
That depends on what Generation the Cattmans are... Whoever supplied the headers (made them), supplied the gaskets.
05-04-2007, 07:26 PM
#178
Certified Hooptie
If they were the first sets, there are no quality issues. Mine have been on for quite a while issue less.
05-04-2007, 07:33 PM
#179
Yeah, the first ones were supposed to be good, but the next batches were hit and miss I guess.
05-05-2007, 10:50 AM
#180
Not a Maxima owner
Quote:
According to what I heard:
Gen 1 = best, proven HP
Gen 2 = less hp, quality issues?
Gen 3 = not proven yet.
__________________
05-05-2007, 03:40 PM
#181
Toolie
i didn't get any gaskets with my 3rd gen headers, used OEM's
05-07-2007, 10:17 AM
#182
I called the stealership for prices on oem gaskets for my header install and he said i needed a plenum gasket as well. I dont know what the heck hes talking about. Let me get this strait. will the stock oem gaskets on my car be ok to reuse. He quoted around 70 dollars for new gaskets and that seems pretty high. Can someone tell me what gaskets i need to make sure i have the right ones. are the supplied gaskets in the hotshot kit any good?
05-07-2007, 11:11 AM
#183
Your stock gaskets will work. I and many others have used stock gaskets. As far as the plenum gasket, i dunno, i guess hes talking about the gaskets for the y pipe? but those should be provided, i know in my Cattmans they were. Call him back and figure out what plenum gasket hes talkin about cuz the gaskets for the manifolds def. arent plenum. Ya the gaskets provided by hotshot should be fine.
__________________
05-07-2007, 11:19 AM
#184
Owns a Maxima
The plenum gasket is what goes between the intake manifold lower collector and the intake manifold; you only need this if you are taking off the lower collector (and we usually loosely use the term intake manifold or IM around here to describe it). That being said, I didn't replace the plenum gasket when I did that. The Cattman headers that I bought came with copper gaskets for the exhaust manifolds, but if yours didn't, new OEM exhaust manifold gaskets are good enough.
I've heard that the Hotshot gaskets suck, so I wouldn't use those.
05-07-2007, 11:59 AM
#185
where can i get good gaskets that will fit the hotshot headers? if i cant figure this out them im going to have to cancel the install.
05-07-2007, 12:09 PM
#186
Owns a Maxima
Just use OEM gaskets or some high temp liquid gasket, available at any auto parts store.
05-07-2007, 12:59 PM
#187
The gaskets on there should be fine.
__________________
