Non working windows and door locks Need Help
Today on my way home from work, I went to put up my drivers window, and it would not go up. The buttons would not do anything. None of the window switches on any of the doors will work, for windows or even the door lock switch.
I replaced the relay for central locks under the hood thinking that was it, but to no avail.
I can turn on the alarm, but it will not lock the locks. When I turn the alarm off the locks stay locked.
Anyone have this issue before? Its supposed to rain tonight and I live in the city, so no garage.
Thanks in advance.
Thanks in advance.
I have this exact same issue, and replacing the fuses does nothing for me either.
Thanks in advance.
Thanks in advance.
same problem
I have the same problem also, my seat does not work. I have taken it to a mechanic and he gets it working and says its fixed and as soon as I get on the road, I try to roll the window down, or move my seat back and nothing. He has replaced the relay and it worked in his lot of course, but about 5 minutes away from the shop it stopped working again.
yea that happend to me one time. it was a hot summer day and i went to put the window up to turn on the ac. and everytime i hit it to go up automatically it would go up and then open up again. i was like what the hell is going on. i did it twice but then on the second try it went back to normal, and i havent had problems. since.
Well fellas, I figured out a quick fix to the problem without spending any money...With the help of illlojik, he emailed me the electrical system breakdown, and from there I just went to the "main driver door switch", matched up the wire colors, tapped into them and ran 2 wires from the corresponding window, straight to the batterys' "-" & "+" side. They let right up, BUT, i still can't get the driver side window to go up, for some reason it didn't work for me when I tried that one. Still haven't figured out the cause of the problem yet, but thats work in the making!! If anyone needs this electrical layout let me know...
ok fellas, I've got ALL the windows up now, here's a description of the wire colors, just go into the main switch on the driver side door:
LF Window- Blue & Green
RF Window- Red/White & Red/Black
LR Window- Yellow & Red
RR Window- Green/White & Green
Just tap into these wire and run it straight to your battery, depending on what you want the window to do (*go up or down*) depends on which wire you hook to the positive side of the battey....Have fun, IT'S VERY SIMPLE!!!
if youve got proper power to the switch, then you can just jump to the power and ground of the switch itself to activate a window (and bypass the switch), rather than run wires to the battery
Same problem on hot day
It seems that when the car get hot from the sun, especially direct exposure to the sun, the driver's side window doesn't want to roll down. Its a son of a gun, cause it will work when the temp cools off, but then tonight same thing and when it cooled off, nothing still. All 3 others work properly and when i push the button i just hear clicking. Gunna take apart the door this weekend and get in there. Is there any airbags or crap in there??
King_Ten_Ahead
09-30-2015 04:27 PM
jerrod99_se-l
08-27-2015 08:27 PM
shaunkey1
08-18-2015 10:09 PM
