Svc. Engine Soon Light on too soon
Old 06-21-2001, 06:27 AM
Revice's Avatar
HELP!! I had my 2000 Max in the dealership the other day because the front wheel bearing needed to be replaced-(already)! I only have 26k miles, so luckily it was covered under warranty. When I picked the car up, the "SERVICE ENGINE SOON LIGHT" was on. Has anyone had this happen? What did you do? What does it mean? The dealer told me to bring it back, so they could reset the light-he advised that sometimes when they disconnect the batteries, it will cause that light to come on....HELP!!!!!
Revice is offline
Old 06-21-2001, 06:35 AM
Got Bent?
UMD_MaxSE's Avatar
If they reset it and it does not come on again, it should be fine. An electrical spike caused by the battery could trigger the light.
UMD_MaxSE is offline
Old 06-21-2001, 07:52 AM
yongjun's Avatar
mine had the ses light on after the tranny work.
all they did was reset the ecu and everything was cool
yongjun is offline
Old 06-21-2001, 03:57 PM
NuJerseyDrive's Avatar
Mine is on now too...
arghhh. Checked the gas cap, it's tight. Thinking about swapping back to stock intake. Think thats neccessary? Stupid question...will it help if I leave the batttery unplugged for an hour?
NuJerseyDrive is offline
Old 06-21-2001, 04:11 PM
Got Bent?
UMD_MaxSE's Avatar
Re: Mine is on now too...
make sure all the sensors are in nice and tight. The OSCAI should not trigger any lights unless you have a bad sensor. Unplug the battery for a while and then see if you get any lights. If you do, take the OSCAI off and go to the dealer....
Old 06-21-2001, 04:31 PM
Sounds good
I'll try it and see what happens
Old 06-21-2001, 06:22 PM
Pmp-n8a's Avatar
can battery sparks/spikes really cause the light to come on?
when i was taking one of the adapters off of the battery to cut power that happened quite a few times...and i have the light too
Pmp-n8a is offline
Old 06-21-2001, 06:43 PM
Got Bent?
UMD_MaxSE's Avatar
I think it can.....my friend has a sentra that needed a new alternator. The dealer replaced the alternator, but when he got the car back, his MIL light was on. The dealer wanted to charge another $70 just to read the code. So, we unplugged the battery for a few hours, hooked it back up, and no light. He has not had the light go on since. So, I think a voltage spike or something like that can cause the light to go on for no other apparant reason.
Old 06-22-2001, 12:09 AM
light is gone..
I was at work earlier and knew that I was gonna be there for another 3 hrs so I disconnected the battery. When I got out I reconnected it and started the car...no light. I drove home (30 miles) and it never showed up. I'm just hoping that it doesn't light up again. If it does then I guess I DO have an issue.
Old 06-22-2001, 06:11 AM
Got Bent?
UMD_MaxSE's Avatar
Re: light is gone..
cool.....if it comes on again, then you may have a problem....but it may have just been a glitch
vingodine
45
05-21-2016 12:46 PM
MaximaDrvr
08-19-2015 08:20 PM
Samedi
08-13-2015 04:05 PM
Quick Reply: Svc. Engine Soon Light on too soon
