HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
Old 07-04-2006, 11:47 PM
  #81
ManUtd18's Avatar
Nice work... I think I need to wear sunglasses to look at it.
ManUtd18 is offline
Old 07-05-2006, 06:50 AM
  #82
merovi's Avatar
I could have swore you said this was being done without removing the needles...
merovi is offline
Old 07-05-2006, 06:56 AM
  #83
You embarrass me.
zero2sixtyZ's Avatar
Metal, this looks badass. I might have to buy an extra cluster soon and TRY to follow this. Excellent work once again.
zero2sixtyZ is offline
Old 07-05-2006, 08:19 AM
  #84
SHIFT_om nom nom nom
Metal Maxima's Avatar
For 5.5 gens and AEs, no.
For 5th gens and lower, yes.
Additional pics coming up tonight...all I have left to do is color my needles (not sure what color yet) and pulg her back in!!!
Metal Maxima is offline
Old 07-05-2006, 01:45 PM
  #85
Future Camaro SS owner
MyownNismo's Avatar
Dan I got the e-mail from the guy that might be able to make the boards. PM me and I will give you the e-mail.
MyownNismo is offline
Old 07-05-2006, 02:47 PM
  #86
EdgeX's Avatar
Dan check your hotmail please.
thanks man
-Greg
EdgeX is offline
Old 07-05-2006, 04:11 PM
  #87
chigga's Avatar
this is comin out nice man. can't wait to peep the finished pics. good work
chigga is offline
Old 07-05-2006, 04:53 PM
  #88
westler92
I bet if the offer was high enough, you'd do it again.....
Good work
Old 07-05-2006, 05:05 PM
  #89
SilverMX's Avatar
Awesome work Metal, I wonder how things may look with Blue LED's. I'm a little surprise you didn't for that since You have all those Blue Led's in your interior overhaul.
I may have to try this with blue for my max just to see.
SilverMX is offline
Old 07-05-2006, 06:27 PM
  #90
Maxima.Org's Official Lurker
2 MaXiMuS 4's Avatar
sooo...its way past tonight.
obligatory F5.
2 MaXiMuS 4 is offline
Old 07-05-2006, 06:29 PM
  #91
BewstAdd1ct's Avatar
Originally Posted by Metal Maxima
Just a different way of doing this. Problem with your suggested circut breaker would be that when and if it does see high current I would have to reset the switch everytime it blew. Additionally, it would require that the entire circut be reworked if I did something. The VR just cuts everything off at the pass.
nah, you just use a self resetting ckt breaker. you set the dimmer to full dim, and bring it back up... no big deal.
also from what i understand, thermal runaway is usually under higher current/diode ckts, yea?
BewstAdd1ct is offline
Old 07-05-2006, 07:12 PM
  #92
This question has already been addressed and the faults therein. Thanks for playing!
Higher current is anything higher than the nominal values epcified from the manufacturer.
You certainley seem to know your stuff, I am looking forward to your version of this.
Old 07-05-2006, 08:04 PM
  #93
STEP XII - NEEDLE LEDs
Last but certainley not least is the needle LEDs. As you can see we will be using a 4-LED array with no resistor. We will not be needing one since the circut is regulated at 12V. I did this in white as I was out of blue LEDs, but I still have yet another trick up my sleeve! Simply make a PCB square, solder the LEDs in place, and go! I also enlarged the size of the hole for the OME needle to allow alot more of the LED to blow up the needle.
Old 07-05-2006, 08:07 PM
  #94
My car will be in the shop as the alternator is dead, FTMFL. It is to be hoped I get the car back tommorow so I can get the needles done and get her rolling!
Old 07-05-2006, 08:08 PM
  #95
Suspension Yoda
djfrestyl's Avatar
Gawd those are bright.
Dan, in the "comfort" thread in the Brakes/Susp forum, I posted I've got an Otto FSTB if you're interested. Good condition, you can have it for a couple bucks.
djfrestyl is offline
Old 07-05-2006, 08:11 PM
  #96
Yes, yes, yes. Consider it sold! Oh, I will be hitting you up soon about when we are going to be doing my suspension. Probably in the next few weeks.
Old 07-05-2006, 08:12 PM
  #97
Suspension Yoda
djfrestyl's Avatar
NP lemme know whenever.
Old 07-08-2006, 02:32 PM
  #98
SUCCESS!!!!!
Everything is back in, I am going to take some picture tonight (to do it justice). I really should have done the needle-mount LEDs in blue, perhaps I will take care of this at a later date, I want to see what it looks like at night.
Oh, and I only have a single project left for THE overhaul, so, suffice to say, I am quite excited!!!
Special thanks go to Barc for checking his cluster to provide me the reference values for the gauges...I lost the paper I wrote them down on.
Old 07-08-2006, 06:57 PM
  #99
STEP XIII - ENJOY!
The last step will involve tapping power leads. Simply tap off of an OEM positive lead and ground the two wires as previously described. These pictures suck total *****, I'm using my fiancee's camera. I'll have more pictures up tommorow. It's bright. OFFENSIVLEY BRIGHT. Puts and Accord to shame bright. SO, if you're looking for an INSANELY bright cluster, follow these steps! Good luck!
Old 07-08-2006, 09:54 PM
  #100
thatcarguy350's Avatar
Does it hurt to look at? That's INSANE! Those aren't guages anymore. They're spotlights!
thatcarguy350 is offline
Old 07-08-2006, 09:59 PM
  #101
Nightmare = Reality
Maxim(a)SerjVQ's Avatar
i think i might want to do that in purple with green needles. . .
Maxim(a)SerjVQ is offline
Old 07-08-2006, 10:09 PM
  #102
SilverMX's Avatar
When I do this I'm definetly using softer lights i think. I may try a blue with red needle. Granted the dimmer should still work with this, right Metal?
Awesome job though, cheers Metal.
SilverMX is offline
Old 07-08-2006, 10:16 PM
  #103
still brewin'
Yayomax's Avatar
I just have one question. You said that soldering was the easy part?????? I'm scared!!
Yayomax is offline
Old 07-09-2006, 10:15 AM
  #104
i see no needles....lol
Dan that is exactly how bright I want mine to be. GREAT JOB!!
Now if I could just get the ***** to do it for my 4th gen...
Old 07-09-2006, 02:07 PM
  #105
frankd121's Avatar
wow, that's insanely bright! A+ for effort.
frankd121 is offline
Old 07-09-2006, 07:17 PM
  #106
Barc's Avatar
Glad I could be of assistance. And more than glad it is all back together! Let me know if I can help out any more.
Barc is offline
Old 07-11-2006, 03:49 AM
  #107
Mauja He Mauja
ZIPPIN's Avatar
hot d@mnnnnnnnnnnnnnnn
ZIPPIN is offline
Old 07-11-2006, 04:40 AM
  #108
I R The Law
The Law's Avatar
wow.....that looks so nice
The Law is offline
Old 07-11-2006, 05:27 AM
  #109
EdgeX's Avatar
Hey I recognize that cluster!! lol The reason you do not see any needles 2 Maximus 4, is because Dan is using for the test fit my old cluster that was a complete **** up which includes needles I colored blue thinking it would still diffuse the light but it didnt. When metal puts his cluster back in (the SE Cluster) it will no doubt be more spectacular. Great job Dan!
EdgeX is offline
Old 07-11-2006, 05:33 AM
  #110
ahhh, I see. I thought he was done with it and thats how it was...
Old 07-12-2006, 12:01 AM
  #111
still brewin'
Yayomax's Avatar
[/color][/b]
Now it seems, the next order of business would be the clock! Besides that...
Yayomax is offline
Old 07-12-2006, 05:18 AM
  #112
Suspension Yoda
djfrestyl's Avatar
Also, that "money shot" is missing something on the screen.
Old 07-12-2006, 09:50 AM
  #113
D Love's Avatar
I've never looked into my cluster, or how the dimmer **** is set up, but if it's just a potentiometer, or if you could replace it with one, then you *should* be able to get it to work with this. At least I would think that you should be able to.
D Love is offline
Old 07-12-2006, 10:09 AM
  #114
D Love's Avatar
SUPPLIES
I purchased the majority of these items from mouser.com. All of these items can be found there A LOT cheaper than what you’d find at Radio Shack. I will update the list with part numbers later on, as to make it easier to find them on the site.
FYI, a couple of other large distributors are digikey.com (my favorite) and newark.com
D Love is offline
Old 07-12-2006, 01:15 PM
  #115
thrrrive's Avatar
This project is definitely not for the "light" hearted (LOL). It looks great I am a little concerned about how bright it is. I am going to look back in the thread to see if someone mentioned if you are still able to dim them.
thrrrive is offline
Old 07-12-2006, 01:41 PM
  #116
MyownNismo's Avatar
Dan did you get an email from the guy to see if he can make the boards. That could make this alot easier for other people.
Old 07-12-2006, 01:54 PM
  #117
secSEblue2k2's Avatar
holy krikey batman, that looks friggin sexy!
hope you make some progress on mass producing these or getting boards made, i'd buy some.
secSEblue2k2 is offline
Old 07-20-2006, 08:41 AM
  #118
soo...any pics with the SE cluster and a closeup too?
Old 07-20-2006, 12:53 PM
  #119
Max2000SE's Avatar
Thanks. Now stay the fukc out of my thread.
Max2000SE is offline
Old 07-20-2006, 11:47 PM
  #120
† ErV †
well you made the dome light obsolete now
Quick Reply: HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
