Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-22-2006, 06:46 PM   #1
LA02MAX's Avatar
Send a message via AIM to LA02MAX Send a message via MSN to LA02MAX
all the info. you need for the 6th gen front brake upgrade
Ok, so since this is something that's becoming ever more popular here on the .org, i decided to compile all of the information you need to upgrade the front brakes on your 5th gen to the 6th gen brakes with 12.6" rotors...
First check your wheel clearance to make sure you have enough room for the brakes to fit. Measure from the center of your wheel to the inside of it, and if you don't have at LEAST 7 5/8" these brakes will not fit on your car...they do fit the 5.5 gen 17" SE wheels like a glove, but they don't fit with the 5.0 gen SE 17s...
If you do have enough clearance, the next step is to purchase what you need for the upgrade. Here are the things you need to get your hands on:
-6th gen calipers (I bought mine from Dave B. for ~$60 each)
-6th gen 12.6" rotors (I bought mine from automax's GD; brembo blanks for ~$100 shipped)
-6th gen front brake pads (Also bought from automax's GD; PBR metal masters for ~$50 shipped)
-6th gen front brake shim kit (got mine from Dave B. i think for under $20)
-Brake fluid of your choice
These are DIRECT BOLT ON for ALL 5th gens (5.0 and 5.5 alike) but you can also opt to get Matt Blehm's re-location bracket on the 5.0 gen (but not the 5.5 gen) and use your stock calipers.
Installation for me would have gone smooth if i had a right and a left caliper, but i accidentally got 2 left ones! DOH! Make sure when installing the calipers that the bleed screw is on TOP. (shown in the picture below.)
For me, the pedal feel was GREATLY improved (although this may be becuse i was running on my stock brakes at 50k). The pedal feels firm, and even after beating the sh!t out of my car at MSR during maxus, i didn't get an ounce of brake fade with my ATE Super Blue Dot 4 fluid.
I bed the brakes in just after installation and so far no abnormal noises or vibrations. There is great feedback from the brakes and they don't seem to lock up under extreme braking like they did before.
On a performance point of view, I could not tell any difference in acceleration. These rotors did feel really heavy, but IIRC they are only 5 or 6 lbs. heavier than stock, which also felt really heavy, so it would be pretty hard to feel any adverse affects on acceleration.
As for the paint on my calipers, i used the G2 silver paint kit. I applied the paint only where you could see the caliper from the outside, and I applied 3 coats with much more paint to spare. The decals are just stick on (I put a couple coats of clear over it just to make sure they would stay) and i got them from www.xenonmods.com
Any other useful information is welcome, as i believe this is all i have. Good luck to anyone that attempts it, and in my eyes, it was a very worth while mod.
__________________
LTB, RSB, FSTB, H-techs and Illuminas, 6.5 gen wheels, 6th gen front brakes
PB: 14.338 @ 98.27 with a 2.300 60' stock.
LA02MAX is offline   Reply With Quote
Old 06-22-2006, 06:53 PM   #2
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Good summary of the info out there. I've added a link to your thread here:
http://forums.maxima.org/showthread.php?t=477415
Puppetmaster is offline   Reply With Quote
Old 07-06-2006, 12:41 AM   #3
How do I get in touch with Dave B.? And what is the shim kit for and where is it install?
hawnboy is offline   Reply With Quote
Old 07-06-2006, 06:08 AM   #4
Super Moderator
Quote:
1-888-254-6060 or PM DaveB.
Old 07-06-2006, 08:05 AM   #5
Very interesting mod, great writeup LA02MAX.
What is/are the diameter(s) of the stock 5.0 and 5.5 gen rotors? How much larger is the pad contact area on the 6th gen setup as compared to the 5th gen?
MaxKlinger is offline   Reply With Quote
Old 07-06-2006, 11:57 AM   #6
Send a message via AIM to footballplyrdan
great info, thanks!
footballplyrdan is offline   Reply With Quote
Old 07-06-2006, 08:46 PM   #7
Maxipimp
Swiyzee's Avatar
Send a message via AIM to Swiyzee Send a message via MSN to Swiyzee Send a message via Yahoo to Swiyzee
Dang it! now i know forsure i have to upgrade my stock 5.0 gen 17's thanks alot LA0
__________________
|Stillen Classic|KSport Pro|GAB|Cattman Y|Drilled\Slotted Rotors|Clifford Matrix 3.5RSX|Fog Rewire|Sidemarker Rewire|
Swiyzee is offline   Reply With Quote
Old 07-06-2006, 08:59 PM   #8
I had mine installed 2 weeks ago and the brake feel is much better.
ICULookN is offline   Reply With Quote
Old 07-12-2006, 12:20 PM   #9
Quote:
Thanks for the info!
Old 07-12-2006, 04:06 PM   #10
LA02MAX's Avatar
the shim kit includes the pad retainers, and the shims that go on the outside of each of the pads so that the caliper piston is not in direct contact with them...once you get all of them, they fit just like a puzzle, so you shouldn't have any problem.
I'm not sure about the 5.0 gen, because their rotors are smaller than the 5.5 gens, but the 5.5 gens are something like 11.68" IIRC, so you gain about an inch in diameter....another thing i'll have to go and measure is the markings of the pads on the rotors and see how much more contact they're making with the 6th gen brakes.
__________________
Old 07-12-2006, 04:23 PM   #11
sciff5's Avatar
Send a message via AIM to sciff5
Pedal feel has improved... but its still NOTHING like my moms G35c. I moved that car a couple times in the last week and was shocked by how much nicer the brakes on that car feel than mine. And she doesnt have the brembo brakes or anything like that just the plain jane, (what looks like single piston calipers) brakes. I am kinda pissed... I wanna know how to get my pedal to feel like that. So to me there was an improvement in feel a little bit but I think thats only cause of the SS lines. Other than that the 6th gen brakes dont make for great pedal feel but are a whole lot better than the stock braking system when it comes to fade resistance.
__________________
2002 Infiniti I35 Sport Package
Progress RSB, Otto FSTB, Michellin Pilot Sports A/S, Eibach Springs, Illumina Shocks, Fx35 Brakes Rotors/Calipers, Custom SFCs
1989 Mazda Rx7 GTU
Ls1/T56 W/ Ported TB and Full Exhaust
11.67 at 120mph 3rd time out
My Car Domain Page
http://www.cardomain.com/ride/2340299
sciff5 is offline   Reply With Quote
Old 09-07-2006, 12:11 AM   #12
Beech Man Whore Slapper
SPEEDY6's Avatar
How about your rear rotors, did you keep the stock size? Or did you upgrade to the 6th gen caliper and rotor as well?
__________________
14.24 @ 94.01MPH (GLD @ 4/9/05)
60' 2.261 / Best - 2.167
2002 Max (6 Speed / HLSD)
2003 Murano(SL/AWD/Nav/DVD TV)
" Was I really going that fast officer ? "
SPEEDY6 is offline   Reply With Quote
Old 09-07-2006, 12:16 AM   #13
Send a message via AIM to FriscoMaxima
Quote:
is that even possible?
FriscoMaxima is offline   Reply With Quote
Old 09-07-2006, 05:13 AM   #14
Got Projectors?
MetaOrbit's Avatar
Send a message via AIM to MetaOrbit
Quote:
Not really possible. Only bolt-on REAR upgrade is Matt Blehm's kit.
I'd like to add that on a 2k2, you're going to need at least 1 7/8" between the outer face of the [stock] rotor and the inside of the spokes of your wheel to have caliper clearance against the spokes.
Additionally, I can confirm that 6th gen rotors and calipers fit behind I35 Sport (8 spoke) 17" wheels.
__________________
:: John ::
"Teach a man to fish..."
MetaOrbit is offline   Reply With Quote
Old 09-07-2006, 05:23 AM   #15
Criminal Minds
NisMoN00B's Avatar
Send a message via AIM to NisMoN00B Send a message via Yahoo to NisMoN00B
Quote:
[rant] What irks me about your comments is that ALMOST every modification you make is compare it to BMWs, G35s, and various other cars. Comparing such findings on other cars where the sum of their parts are designed to work for that car on how it handles, brake, accelerate, and etcetera is somewhat unfair. IF you're so bent out of shape that whatever modification you make does not compare to another, why not get THAT car?[/rant]
As far as the write-up goes, good job, I can use this in deciding between A34 or Z32 brake upgrade.
NisMoN00B is offline   Reply With Quote
Old 11-15-2006, 06:08 PM   #16
Will these fit behind my stock 6 spoke I35 rims?
nycspudz03 is offline   Reply With Quote
Old 11-15-2006, 06:28 PM   #17
sciff5's Avatar
Quote:
I believe they have around the same clearence as the stock 5.5 gen Maxima rims, which I am pretty sure fit with the 6th gen brakes.
__________________
1989 Mazda Rx7 GTU
My Car Domain Page
Old 11-15-2006, 06:45 PM   #18
Send a message via AIM to AnDyMaN
why wont it fit for the rear? bolt in diff location?
AnDyMaN is offline   Reply With Quote
Old 11-15-2006, 07:05 PM   #19
retired moderator
irish44j's Avatar
Quote:
no ebrake....different size rotors.....different bolt locations.
The only known rear brake upgrade is the Blehm kit using rear z32 calipers, and it is $$$
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 11-15-2006, 07:26 PM   #20
Burn Dust. Eat my rubber.
SgtSchulze's Avatar
Good info. I'm doing this mod in the spring. Are there two different 6th gen calipers? One coated black and one not?? I remember reading that someone got the black ones.
My brakes are warped as we speak. I tried the IRotors and they warped. Hopefully, upgrading to bigger rotors will solve it once and for all.
__________________
Go: FSTB, GAB w/ K&N, Tein H-Techs, Tokico Illuminas (3F/4R), Slotted/Drilled Irotors, 6th Gen BBK, Frankencar B-Pipe, Cattman Rear Section, Blehmco Hypergrounding, NWP Spacers
Show: AE Sills & Pedals, 350Z Dead Pedal, 350Z Horn Mod, 18x8 Axis Spiders w/ Nitto 555's (FOR SALE), G2 Painted Calipers, Rewired Fogs, Alpine 9835, Alpine Amps, Rainbow SLC's, Infinity Basslink, KnuKonceptz Wires, Blacked Out HID's
SgtSchulze is offline   Reply With Quote
Old 11-15-2006, 09:11 PM   #21
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
That must blow monkey shiits
Quote:
Did you get a chance to weigh those (A34 rotors) beasts?
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 11-15-2006, 09:31 PM   #22
Uber-epically-terrific!!!
GBAUER's Avatar
I did mine a while back and can tell you that you WILL feel the weight. 6 lbs isn't much, but when it's whirring around in your wheel well, you'll notice it. It'll take away a couple of whp and torque. I made up for it by getting new rims so now I'm at basically a wash in rotational mass.
Sig has old 5.5 rims, but new 6th gen brakes.
GBAUER is offline   Reply With Quote
Old 11-15-2006, 09:41 PM   #23
Certified Hooptie
NmexMAX's Avatar
Quote:
Originally Posted by GBAUER
6 lbs isn't much
Sprung vs unsprung, it IS a lot of weight actually.
So they weight 21 lbs?
I did the same, 14.3lb 17" wheels FTW.
Old 11-16-2006, 07:06 AM   #24
This upgrade will fit the 7-spoke 5.5gen GLE wheels too!
It's a really easy, simple, straight forward parts swap. A decent afternoons worth of work and well worth the effort!
As noted, make sure you get a left and a right caliper - they are different! And have the parts guy mark the box for you, as there isn't any indication, other than the part number as to which one is the left and which is the right.
The OEM pads don't come with a shim kit, as stated previously, so make sure you get one of those. This shim kit comes with a couple of different sets of shims...not sure why. All the shims will fit the pads.
JohnWEngle is offline   Reply With Quote
Old 11-16-2006, 07:12 AM   #25
Send a message via AIM to Teufelhunden
good job man, its the cheapest brake upgrade ive seen, might add this to future mods.
__________________
:cleared headlights:clear sides:chrome gauge rings:20% tint:leather E-brake boot:luminics yellow fog bulbs:custom lower grill:H-techs:Tokico HP: ebay fstb:Berk intake w/apexi:Megan Racing exhaust:
Teufelhunden is offline   Reply With Quote
Old 11-16-2006, 08:26 AM   #26
anyone know if the 17' 7 spoke altima se rims will fit?
If anything, spacers should make it fit...
kbjy11 is offline   Reply With Quote
Old 11-16-2006, 09:21 AM   #27
Hey guys, I am new to the MAxima World but not new to cars. I have been researching this mod for a while, but just want to set the record straight. For a 5.5 gen you need the Gen 6 rotor and caliper. But what about the caliper braket(that hold the caliper to the spindle)? I was planning just to use the braket made by Blehm, but i guess that's only for the Gen 5 and I have a 5.5. Do i have my ducks in a row or am I all meesed up?
TIA,
Walter
WaltzA33 is offline   Reply With Quote
Old 11-16-2006, 09:49 AM   #28
Willing to learn
oldngivout's Avatar
02-04 Altima SE 17" wheels will fit the 6th Gen Max front brakes. These actually have six spokes.
05-06 Altima SE 17" with 5 spokes will not fit.
oldngivout is offline   Reply With Quote
Old 11-16-2006, 10:18 AM   #29
sciff5's Avatar
Quote:
TIA,
Walter
If you have a 5.5 gen, then the 6th gen calipers will bolt in perfectly to the stock 5.5 gen brackets without modification. They are a direct replacement.. Kinda makes you wonder why the 6th gen brakes werent on the 5.5 gen to begin with.
__________________
1989 Mazda Rx7 GTU
My Car Domain Page
Old 11-16-2006, 10:22 AM   #30
LA02MAX's Avatar
On all 5th gens (5.0 and 5.5 alike) the 6th gen calipers and rotors will bolt up with no problems. The only time you need a braket is if you decide to keep your original 5th gen calipers and use the 6th gen rotors. In this case you will not need the 6th gen calipers, but a bracket is only available for the 5.0 gen right now, not the 5.5
__________________
Old 11-16-2006, 10:26 AM   #31
LA02MAX's Avatar
my car felt the same after I installed my brakes...either it's all in your head or it's because you have a auto
__________________
Old 11-16-2006, 04:42 PM   #32
So if I do this upgrade I'll have to buy a full size 5.5 gen wheel for my spare. I believe the donut spare is 16" so it doesn't sound like it will fit. Has anyone verified whether or not the spare fits? I would hate to get a flat and be stuck with no spare.
__________________
'02 Maxima GLE
Dust N Bones is offline   Reply With Quote
Old 11-16-2006, 10:51 PM   #33
LA02MAX's Avatar
Quote:
well if you ever got a flat on the front, you would have to put the donut on the rear and put the rear tire on the front...if you want to go to a full sized spare, you will have to either fab something up to make the trunk floor even (the full size tire sticks up about 1 1/2") or deal with the floor being uneven...
__________________
Old 06-12-2007, 03:03 PM   #34
Send a message via AIM to Gle03Max
Hey guys I was researching this mod and found this thread. I just got one quick question. If the brackets are the same then what is the difference in the calipers?
__________________
*2003 Nissan Maxima SE 6 Speed*
|HLSD|Greddy Evo 2|Berk Intake|FSTB|8k Fogs|8k Headlights|White LEDs|Tint|Diamond Plate Floor Mats|Zex Wet Kit|Clear Sidemarkers|Zex Bottle Warmer|Zex Remote Bottle Opener|Fidanze Flywheel|Spec Stage 3 Clutch|Toyo Proxes 4|ES Motor Mounts|
http://www.cardomain.com/ride/2655734
Gle03Max is offline   Reply With Quote
Old 06-12-2007, 04:14 PM   #35
Certified Hooptie
NmexMAX's Avatar
Quote:
Size. . . . . . .
Credit: irish44j
__________________
Old 06-12-2007, 05:21 PM   #36
Thanks.
From the pictures it appears that where that pad actually hits the rotor they are pretty close between the two. Did anyone ever do any measurements?
__________________
Old 06-12-2007, 05:27 PM   #37
Certified Hooptie
NmexMAX's Avatar
What exactly are you asking?
Is your end plan is to use the A34 rotors w/ A33B calipers, forget about it. Measurements don't add up.
I also forgot to mention that the picture is a reflection of 00-01 hardware. I'm sorry I didn't mention it earlier, but I just now.
But, if you had a 00-01 then yes, you could use the stock calipers and A34 rotors, which, in this case is a good observation on your part. But i see you have an 03, so no dice there.
But, the answer to your original question still remains, they are still a little smaller (02/3 vs 04+ calipers).
Old 06-12-2007, 05:30 PM   #38
No, I was planning on putting all 6th gen parts ( calipers, rotors, hardware, and pads). I just dont see that big of a difference in where the pad actually meets the rotor from 5.5 Gen to 6th Gen.
__________________
Old 06-12-2007, 06:19 PM   #39
Certified Hooptie
NmexMAX's Avatar
You mean contact surface area? Once you have the parts side by side, you'll see the difference. I had the same thought until I bought what I thought were A33B pads, and was trying to fit them on the A34 rotor and caliper assembly. Couldn't figure it out for the life of me. Trying to fit those pansy stock pads in the new hardware is very frustrating. Until I snapped and compared one of my old pads with the 'new' one and saw that it was identical. So I go to AutoZone the next day and exchange them. Very large difference believe me.
The stopping power is quite noticeable as well.
Old 06-12-2007, 07:13 PM   #40
Alrite, thanks for the info! I know what I will be doing soon
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
