Polo/others with ES Front LCA bushings, step in...
retired moderator
Was under the car today, and noticed something odd....on the lower control arm, the bushing on both sides had worked its way out partly, and was actually farther back, around the front of the bush pin link...WTF?? I'm not sure why this happened (on both left and right sides)...the control arm bolt is tight (holding on the Lower tie bar also).
keep in mind the metal tube in the middle hasn't moved, just the bushing itself, as you can see here.
1. The only way I can think of to hold it in there is using a thin washer - but that might mess up the caster of the wheel a bit.
2. to get the bushings into the LCA, IIRC I used a bit of lithium grease. COuld this somehow cause the problem? As you can see, there is no more grease on the bushing since it's come out most of the way.
3. The front bushing (far left of pic) is still in place, so there's no metal-to-metal rubbing or anything.
Has any of you had this problem, or have any thoughts as to its cause/solution?
in this pic, the red thing is the control arm (painted because it was rusty, red was handy). The lighter red thing on the far left is the lower tie bar. The bolts are the bush pin bolts..
it should look like THIS (I pushed this one back in and used a ghetto shim to secure it temporarily until I can find the right size washers
retired moderator
Originally Posted by soonerfan
i was playing with a washer earlier about that size...its on your coffee table
Originally Posted by irish44j
jason, btw send me your home email again (seem to have lost it) and I'll send you that sig pic you wanted.
I'm gonna hit you up this week for my caliper bolt, some of your 50 gallons of brake fluid, and some of your black caliper paint.
Kthxbye.
Josh, repair that immediately. I lost a front washer a while back and had all sorts of trouble. Yes there's supposed to be washers on both front and back to keep it from shifting.
Thank goodness you caught it during inspection. I wasn't so lucky.
http://forums.maxima.org/showthread.php?t=351814
retired moderator
thanks for the link, never heard of that happening before, some craziness. The 5th gens have a bolt with a wide bottom lip incorporated (no washer at all) so it's VERY strong up front, even without the LTB...
retired moderator
Originally Posted by rbrown81
Josh, that will teach you to buy used bushings!
New grade8 hardware is now installed, so I'm all good now.
I didn't buy them used....they came DIRECTLY from Energy Suspension....I might have just left the washers in the box and not noticed them.
edit: difficult enough for you to pinpoint what noticable, if any, difference you felt with just these put on over OEM?
retired moderator
Originally Posted by PoLo
i should get off my *** and actually put them on my car, right?
Josh
When Tilley was doing my bushings he damaged one of the components on the suspension. He told me that they always break whenever he takes off the LCA. We managed to do a quick fix with a weld. I forget what the part was... Maybe you know the part I am refering to... ?
retired moderator
Josh
Dang Josh that thing could have costed you ALOT in damages if the control arm slid all the way off the transverse link.
On another note, I've done a few Maxima control arms and I've never damaged one while removing it.... must be installer error.
retired moderator
in any case, it's all fixed now and good to go, so no worries - live and learn...it's a good thing I'm under my damn car so much to notice things like this!!!
Josh
they look IDENTICAL and i'm VERY VERY intersted in this. i took off my endlinks a few weeks ago as i was trying to locate a noise in my suspension and so removing the endlinks would kill that idea. that nite i drove around w/out them and it was the most SLOPPY driving imaginable. it was disgusting. i can only imagine what stiffer endlinks would do.
http://forums.maxima.org/showthread.php?t=473375
