GRINDING! Front right wheel!
Been getting this grinding noise only in the front right side. I first thought it was wheel bearings. Brake pads are fairly new about 60% pad left on freshly cut rotors about 2 months ago. Noise still continues as I accelerate and brake. But get this, the noise only happens in the rain. I was thinking ( but hoping its not) the front right CV axle boot may be torn and getting water in, just my thought but was wondering if anyone has had any similar problems like this where a grinding noise only happens in the rain? I am actually going to try to get this on the rack at my cuzns shop ( Wildmax01 ) to see if it may be the CV boot. I have an extended security plus warranty on my 01 AE but I know the stealership is gonna give me shiat because I am lowered on S.techs and KYB GR2's. Any input I would greatly appreciate!
Originally Posted by frankd121
to check if its the wheel bearing - jack up your car and try to move the wheel back and forth, if it moves around then its the wheel bearing.
hmmm i have this problem as well but i noticed when i was rotating my tires that the front right wheel moved around even though lugnuts were securely tight...... how bad of a problem is wheel bearings and how much does that usually run...(sorry to jump in on this thread but i have the same problem)
but with me its BAD when i turn to the right or switch lanes to the right and it becomes more quiet when i turn left or switch lanes to the left
Originally Posted by BLUEMAX01SE
...But get this, the noise only happens in the rain. I was thinking ( but hoping its not) the front right CV axle boot may be torn and getting water in, just my thought but was wondering if anyone has had any similar problems like this where a grinding noise only happens in the rain?
Here's my previous post on the subject.
http://forums.maxima.org/showthread.php?t=468175
Other than my alternator crappin out, I've had no funky grinding noise coming from the wheel/axle area since the regreasing. So I'm almost in great shape. Hope this helps.
Thanks 808MAX, I am actually going to get this up on the rack tomorrow morning! Hopefully this is all it needs, just to be regreased! I will let you guys know as soon as I find out the problemo! Thanks again 808MAX!
Well, actually just turned out to be the axle nut. Front right wheel had very little play when on the rack. Moved a little front to left and back and forth. Tightened up the axle nut ( by the cotter pin ) and problem solved. No more play or grinding noise! I'm glad it wasn't something major!
Vadim, I hear ya bro! I actually had this problem before too at about 50k miles. I'm not sure what may cause the axle nut to become loose. I have a set of 18 in chrome rims that I switch on and off for spring and winter, I was thinking maybe that can cause it to come loose from changing the wheels so often. But its weird cause it has only happen to the front right passenger wheel. ???????
switching out wheels should not cause it to come loose. THe only time i take of my wheel is when i do oil changes every 5k miles and tire rotation, which i haven't done in a long time. I am starting to think that it's a factory defect.
Vadim, that could be too! I am not sure what causes an axle nut to become loose on the same wheel twice! I was wondering if i should just start a new thread to get some opinions of the other members to see if they may have an idea of what causes an axle nut to become loose! ( I'm sure me being lowered on S.Techs/KYB GR2's doesn't help it either ) Weird!
Originally Posted by 808MAX-SPEC
Loose axle nut huh? Glad you solved your problem. I wonder what other problems could cause grinding that sound like a worn wheel bearing?
BassAddictJ
08-04-2015 11:38 AM
