Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-08-2006, 05:50 PM   #1
SHIFT_om nom nom nom
Metal Maxima's Avatar
HOW-TO: The Penultimate Climate Control LED mod!!!
Good luck!
(1) Take your climate control out. If I need to explain to you how this is done, STOP READING.
(2) The climate control can be dissasembled by removing all of the screws you see. There will be six in total. Then just pry the clips off.
(3) Pull the circutboard out VERY CAREFULLY. Take your time with this step. You run the risk of permanently ruining your CC if you mess this up. As you pull, you will see the buttons press in. Pull them out as you go along. Disconnect the slider wires from the board.
(4) With the board exposed, all you need to do is cut off the old LEDs, and solder new ones on for the buttons. Just cut the LEDs to match the SAME TOTAL HEIGHT (bulb + leads). 5mm LEDs will fit with NO ISSUES.
(5) Now, pull the plastic light diffuser out. Cut the first square off. You will know what I mean when you see it. You will then need to notch the left and right side to allow for the Superflux LEDs to fit. Put a small drop of glue to attach the LED to the acrylic.
(6) Cut leads for the LEDs into the acrylic. You will be wiring (+) to (-), so cut and wire accordingly. I did an array of 4, then 2, then 2.
(7) For the switch, cut the head off of a 5mm LED and stick it in. Glue it in.
(8) Cut off the acrylic diffuser for the knob, and use a router to cut out the protective cover.
(9) Bend the LED leads and wire it. Don't forget a resistor.
(10) Put the diffusers back in and test. The buttons SHOULD NOT BE EFFECTED BY THE LEDS!!! Put electrical tape all around the diffusers or wire it such that no leads are exposed.
Put everything back together and wire it up. ENJOY!
Metal Maxima is offline   Reply With Quote
Old 05-08-2006, 06:04 PM   #2
retired moderator
irish44j's Avatar
you always seem to figure out an easy way to do things *after* I do them the hard way!
irish44j is offline   Reply With Quote
Old 05-08-2006, 06:14 PM   #3
Josh...this was SO not easy, dude. I would not recommend this to ANYONE whom has even a modicum of sanity.
Old 05-08-2006, 06:34 PM   #4
Mauja He Mauja
ZIPPIN's Avatar
A little scary. But it can be done as long as one has knowledge of how leds/resistors work..Great how-2's...
__________________
ZIPPIN is offline   Reply With Quote
Old 05-08-2006, 06:37 PM   #5
Wants the EVO X
MyownNismo's Avatar
Hey metal have you ever thought of using SMD's Surface mount Diodes.
Notice Actual size on left side.
http://www.ledtronics.com/ds/smd-0603/
__________________
Custom intake w/Apex-i filter, Cattman headers & Cat-back, 350Z RAYS wheels 18X8.5 33 offset w/ Falken Azenis 615's, 2001 AE AT w/ Stage II VB, ADV Timing 17 degrees, Stillen 2 piston BBK W/ Coleman Racing 2pc Rotors(front), Racing Brake Rotors w/Hawk HPS pads (rear), Stillen Bodykit, VIS CF Invader Hood, Smoked 2k2 Headlights, Progress Springs, Tokico illumina's, Stillen RSB, FSTB.
MyownNismo is offline   Reply With Quote
Old 05-08-2006, 06:54 PM   #6
Send a message via AIM to Matt_01SE_20th
why did you go through all that trouble? i did the same thing using standard mounts and equipment. But i have one question, what year is your car? i didnt have anything that looked like that optics piece, and i didnt have LEDs to begin with. the face looks the same, but the internals look COMPLETELY different. if this is a 5.5 gen, ill be more than happy to add the 5.0 gen how to on this, cause it is TOTALLY DIFFERENT
Matt_01SE_20th is offline   Reply With Quote
Old 05-08-2006, 07:01 PM   #7
Quote:
It's a 5th gen. Pics of your cluster?
Old 05-08-2006, 07:09 PM   #8
makavelisk's Avatar
Send a message via AIM to makavelisk
Damn that looks sexy.....
makavelisk is offline   Reply With Quote
Old 05-08-2006, 07:17 PM   #9
retired moderator
irish44j's Avatar
Quote:
I know....just messing with you I went the other route, where the LEDs are actually inserted INSIDE the clear plastic grid by drilling holes for them and then securing them with silicone....what a pain!! This way at least looks a LITTLE safer. With the drilling, one small slip and you get a ruined plastic grid piece
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
Old 05-08-2006, 07:32 PM   #10
ill go take a picture
How do you post pics again? Sorry, its been awhile
Old 05-08-2006, 07:33 PM   #11
Just a pic of the finished product, for those whom have not yet seen it:
Old 05-08-2006, 07:43 PM   #12
Send a message via AIM to XyNoix-HIC
DAMNIT metal you have done it again!
is it the same if you don't have the CC and jus the regular AC?
XyNoix-HIC is offline   Reply With Quote
Old 05-08-2006, 08:00 PM   #13
http://memimage.cardomain.net/member...881_1_full.jpg
give that a shot
P.S. im an idiot and thought the second post was a continuation of the first. WOOPS. Irish has an auto CC metal has a manual, i still did it differently than irish though. I didnt drill anything. ill take it apart and get a pic in the next few days
Old 05-08-2006, 08:03 PM   #14
Correct me if Im wrong, but that looks like the "regular" CC and not the ACC.
Looks really good though Metal. What kind of LED's you use? They look REALLY bright. Id like to do this, but maybe not quite so bright. Also have to look at the set-up behind the ACC screen.
NewLoveI30 is offline   Reply With Quote
Old 05-08-2006, 08:26 PM   #15
IRISH, how did you get the red to go down the bottom(shift boot area)? Ive been trying to think of a way to get the bulb below to convert to an LED (not too hard mind you), but if you dont mind giving up your trade secret id like to know. the resistor in series without cutting the wire is my trouble
Old 05-08-2006, 08:32 PM   #16
retired moderator
irish44j's Avatar
same way I did the other part....there are 4 led's inserted "into" the clear plastic grid shining downward (the light bulb is gone, but the wiring for it is what lights up the led's now)....
__________________
Old 05-08-2006, 08:34 PM   #17
Quote:
where are the resistors?
and also, that optics piece looks different than mine, is that something you made?
__________________
I cant remember what happened last night, all I can remember is a song that goes like this.
2001 Maxima SE 20th anniversary edition
May '03 (49438mi) - Dec '08 (156884mi)
You will be missed.
Old 05-08-2006, 08:39 PM   #18
retired moderator
irish44j's Avatar
no need for resistors if you use the correct amount of LEDs to use up the power
But if I did have to use them, I would have simply put them in-line behind the fascia someplace. Truthfully, I did it so long ago that I don't really remember. I'm not nearly the LED pro that Metal is....I just dabble and experiment occasionally. I blow up as many LEDs and fuses as I use!
__________________
Old 05-08-2006, 08:53 PM   #19
12V @ 0.7 per LED = 18
i dont need that many
or is that a 5 volt circuit?
P.S. it is still recomended that you use a resistor.
Old 05-08-2006, 09:08 PM   #20
retired moderator
irish44j's Avatar
I used different LEDs with different power usage.....in your case, you'd need a resistor
__________________
Old 05-08-2006, 09:37 PM   #21
Good job Dan. Looks very good.
03maxima1 is offline   Reply With Quote
Old 05-08-2006, 09:53 PM   #22
you make it look so simple
danger300z is offline   Reply With Quote
Old 05-10-2006, 02:51 PM   #23
Send a message via AIM to Nomad
Sorry for posting in this thread
MetalMax since you 5th gen cluster guru can you tell me if 2k1's stock gauge faces are swapable? I mean If I can use donor SE cluster in order to replace SE faces over my stock ones. I'd get the whole cluster but don't want to deal with reprogramming miles and stuff. BTW do you know if 2000 cluster carrys the same faces as 2k1?
Thanks. BTW where's pics of brighten 5.5 cluster located.
Nomad is offline   Reply With Quote
Old 05-10-2006, 08:02 PM   #24
So how do i take the climate control out??????
LOLL J/k Nice job im trying this tommorow
SuperStasiu is offline   Reply With Quote
Old 05-11-2006, 10:52 AM   #25
Metal, how much willl you charge me to do this but with red led's?
ICULookN is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
