'00 SE - idle drops too low, sometimes kills engine
Any common causes? O2 sensors were replaced recently from 'service engine soon', but idle problem appeared before that. This commonly happens when foot released from gas on slow down, before turns, etc. Idle drops to 200 or lower, sometimes sputters and shuts engine. Odom just turned 70K, and always on premium gas. Is there a MAF or other sensor problem?
MAF
before i replaced mine, I wouldn put my car into neutral while driving and the cars RPMs would dip so low that sometimes it would stall while driving down the road. Replace the MAF first.
When I got my car at 72k if I was going in at any speed over 3 grand or so and pushed in the clutch it would just drop down to 0. Even a quick rev would make it drop.
The dealer replaced the maf and all was well.
DF
DF
The new part isn't that expensive 104.00 list. The only problem is that it is an updated mass and there is a reprograming that needs done to the ECM. This will most likely cost you an hours labor at the dealer, unless you can grab a tech outside the shop who would probably do it for 20 cash. Anyways good luck.
Originally Posted by 9DTALON
BTW. If anyone needs one I can send you one for 75.00 plus tax. Shipped. New in box. part # 22680-2Y001
The Frye
09-02-2021 11:03 AM
