Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 02-18-2009, 06:15 AM   #41
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Quote:
Originally Posted by wyche89 View Post
ONE THING EVERYONE SHOULD KNOW ABOUT THIS INSTALL:
Be careful where you put your O2 sensors. Because they get REAL hot and start to burn through things... like wires... not that I would know from experience or anything...
Puppetmaster, you don't have a problem with your O2 sensors burning/melting anything under there?
Not that I know of, but it's been a while since I've checked.
Puppetmaster is offline   Reply With Quote
Old 02-26-2009, 09:42 PM   #42
Ok, I am throwing a P0138 code in my '04 (I know... this is the 5th Gen forum, but I found this write-up... thanks puppetmaster!)... I had the headers installed one day, and the sim installed 4 days later (after the car was throwing the P0138 code). I never had the ECU reset (tried the pedal thing and it didn't seem to work... and i've done it countless times before, so I know it's not me lol)... could this be the issue? I am 99% positive the installation was correct.. soldered, taped, etc.
How would I go about resetting the ECU? Just leave the battery unplugged overnight?
__________________
Oolatec is offline   Reply With Quote
Old 02-26-2009, 10:33 PM   #43
Send a message via AIM to wyche89
i never reset my ECU and the O2 sensor codes were gone 4 me
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Custom 3" Magnaflow Cat-back Exhaust
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
"I feel the need... the need for speed!"
wyche89 is offline   Reply With Quote
Old 02-26-2009, 10:39 PM   #44
Hmmm... hope it's not a bad sim.
__________________
Old 02-27-2009, 05:49 AM   #45
Super Moderator
The pedal procedure is the best way, but if not, unplugging the battery for more than 24 hours will also clear the DTCs, according to the FSM. It is also possible that you got a bad O2 sim. If you got it from www.o2sim.com, they have great customer service and will ship you one immediately usually.
Old 02-27-2009, 10:14 AM   #46
I actually bought 2 from them via the group deal... do the dual channel ones have a light on them?
__________________
Old 02-27-2009, 06:07 PM   #47
Quote:
you mean the dual output? yeah, they have a little green light that has a slow blink
__________________
2003 6 speed TE
Old 02-27-2009, 10:32 PM   #48
Yeah... the sim is working fine... the investigation continues!
__________________
Old 03-09-2009, 11:29 AM   #49
Send a message via AIM to PlanoSER
I need some help guys. I have the Cattmann headers and can't get rid of these codes:
P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)
P0051 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 1)
P0057 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 1)
I have a dual output o2sim hooked up to both the rear o2 sensor plug wires and the green light flashes, I assume that means that part is working correctly.
I tried some resistors w/o any luck (10W/10ohm) I tried w/ one or even w/ 2 in series for each but still get the codes.
Today I found my old rear o2 sensors and plugged them in, reset ecu, and still get these codes..
While my old o2 sensors were spliced into the oem plug, I referenced a post from The Wizard that showed the o2 sensor's 4 wire color layout being top black wire as signal, bottom grey as ground, White @ 3o clock as heater wire, and White @ 9o clock as 12V power.
I am stuck and need to get this taken care of before end of month so I can get my car inspected. If anybody has any advice or suggestions it would be much appreciated.
__________________
'02 Maxima SE 6MT : Place Racing CAI / Cattman Headers / 2.5" OD Cutout / NWP Spacers / BlockPlate / UDP / ES MM / Exedy OEM Clutch / 6Gen 6MT Trans / 6Gen Brakes / Tokico Illumina / Progress Springs / Progress RSB / 18" SSR Type C /
13.9 @ 101.7mph -- 8/8/08 Texas Motorplex Ennis -- 2800 DA, Mods = I/H/P
PlanoSER is offline   Reply With Quote
Old 03-09-2009, 05:33 PM   #50
I went out w/ a Craftsman DMM & took some readings on the lines, let me know what you guys think:
[Blue Harness] --> Measured Resistance @ 4.2-4.3 Ohms
Red/Yellow (Power) = 12.7 Volts
Pink/Black (Heater) = 2.52 Volts
White (Signal) = was fluctuating between 0.3Volts - 1.3Volts
[Green Harness] --> Measured Resistance @ 4.1 Ohms
Red/Blue (Heater) = 12.5 Volts
White (Signal) = was fluctuating between 0.2Volts - 1.3Volts
I know I will need to find out what range should be within, I'll try to check out the FSM. If anybody has any input or ideas causing these figures I would really appreciate any feedback. The weird figure that stands out to me is the Pink/Black Voltage reading of 2.52Volts which is much lower than it's counterpart (Red/Blue) on the other harness.
Let me know if you have any ideas. I didn't want to do it, but if I don't get any replies I will be forced to make a brand new topic for help with this!! :P
Also for what it's worth I have the dual output o2 sim spliced into the wires before the harnesses, and then I have the rear o2 sensors plugged into the harnesses and ziptied up around the intake manifold.
__________________
Old 03-10-2009, 06:33 AM   #51
Super Moderator
The good news is that since the catalyst efficiency codes aren't showing up, the sim seems like it is working so it could be an issue with your sensors.
Old 03-24-2009, 08:32 PM   #52
Nations 1st 6th Gen Turbo
chernmax's Avatar
Send a message via Yahoo to chernmax
Anyone put this on a 6th Gen yet?
This may be what I need to finally get rid of my SES light
__________________
Visit my Web Site at: http://www.cardomain.com/ride/668322 Stop Global Whining!!!
chernmax is offline   Reply With Quote
Old 04-08-2009, 04:50 PM   #53
Quote:
Originally Posted by Puppetmaster View Post
Sent you a PM but I'll also post it here for others' benefit...
Looks like the picture from Pugman is correct, based on the position of the O2 sensors, but double check the colors based on the second diagram, which is from the TSB. Reason being I've seen O2 sensors have their positions switched around for whatever reason, either by the owner or dealer, and so the "middle two" aren't always the secondaries.
The colors indicated in the TSB diagram refer to the color of the wire shroud under the heat wrap. You can sort of see the red of Bank 2 Sensor 2 in the photo. The other one should be white.
Hope this helps.
Let me know if you have more questions...
Sorry for being slow, but which two connectors on a 2001 would be equivalent to the two you used in the write-up? The secondaries?
Armon is offline   Reply With Quote
Old 04-08-2009, 05:12 PM   #54
I got 2 code today : P0138 & P0158 (O2 oxygen sensor circuit high voltage (bank1&2, sensor2)
Also my led on the sim is blinking fast!! Any idea for help??
__________________
Altima SE-R 05' 6spd / 14.272 @ 99.15 mph STOCK!
ampli.monchar.com / Now modding! ------>
Axxtion STS 55mm / Cattman B-Pipe + Headers / 2° Timing Advance
NWP IM Spacers + VIAS Plate / RL F&R Endlinks + MMI, FSTB, Y-Pipe
Redline Tuning Hood Lift / Fujita F5 CAI / Eibach ProKit + KYB GR-2
12'' 300w sub + amp / Custom Cams / Custom Rear Window Spoiler
SS Brake Lines / UR UDP / ECU + tunning & dyno / some more...
Ampli is offline   Reply With Quote
Old 04-20-2009, 09:10 AM   #55
Send a message via AIM to CautiousDriver
heater circuit
great write up did mine not too long ago and now also getting codes p0135,p0141,p0325 most seem as a heater circuit problem... thought sim would clear all that up ?it's 99 max i got would anyone know if more things are needed to clear this up? like some heater resistor i heard about ?
__________________
drive it like you own it.
CautiousDriver is offline   Reply With Quote
Old 04-27-2009, 10:23 PM   #56
Really Long story but I want intell anyway!
At this point my brain and eyes both hurt from hours on the .ORG and I cant think right anymore. I had the catalyst inefficiency bank 2 code along several other codes when I first got my Max.
Story goes like this, I cleaned the MAF once to got the car running better but 50 miles down the road, crapy running... again. Once I got home, I got on what else but the .ORG, and everything I've checked so far pointed to the MAF. I took it to a mechanic and he pulled the codes, I had three. A knock sensor malfunction, the cat inefficiency and IACV. The IACV turned our to be a vacumn leak and the knock was just a fluke. He fixed the leak, cleared the codes and took it around the block, no codes.
He told me that if the SEL came back on that the Cat. may have a problem and have me a number to a guy who can look at it. Well, not but 20 miles down the road and half way home, I get the dreaded light and crappy running. I let it sit for about a week but I got to thinking about the MAF so, I cleaned it again and took off the battery for about an hour. No light, ran great! Took it up the block several times and even restarted it to see if the computer would pull the code. Nothing happened, though I have a feeling it will.
My questions are:
1). Can a MAF cause a BANK 2 Inefficiency? and which bank is bank two, front or back?
2). Which bank is necessary for fuel mixture control?
3). Which Sensor (color coding is okay, I'll have a working brain tomorrow) is for the cats and which ones do I need to replace with the simulator for this code if it rears its head after I put in a new MAF?
4). What's the difference between Primary and Secondary in a bank.
5). what about a resistor to fool the ecu's need for heat on the sensors so I could get rid of the sensor completely?
My car apparently is Cali spec... great stuff California! (not really)
"Help me please Maxima.org, you're my only hope" (turns to droid to turn it off).
BTW. My Dad wants to know about simulators too b/c he has O2 codes on his F150, 170k+ does that ya know!
__________________
"I reject your reality and substitute my own." - Adam Savage
copilot1991 is offline   Reply With Quote
Old 04-28-2009, 07:42 AM   #57
i just ordered (1) dual output 02 sim. Is this all i will need? Or do i need to order (2) since im trying to take care of both cats. I have the OBX headers installed and running the P0430 code.
Phantom-V is offline   Reply With Quote
Old 05-07-2009, 10:00 AM   #58
Send a message via AIM to TheOnlyDRAGooN
Both my rear (secondary) o2 sensors are bad on my 02 max. Wanting to know if I can run this technique to get rid of the codes and CEL? anyone have pix or information for me that would be awesome.
__________________
Member.of.[Z3Ro-UNiT]
95' Honda Accord Ex @170hp - RIP
94' Honda Prelude Si-VTEC - RIP
02' Mercury Cougar V6 - RIP
And now?... VQ35...
TheOnlyDRAGooN is offline   Reply With Quote
Old 07-01-2009, 09:40 PM   #59
OKay, i just installed my dual output o2sim that i recieved today from o2simulator.com
after the installation,(with the help of puppetmaster's write up) i turned on my car and the green LED was blinking slowly so i figured it was working. i let car run for a bit and the green LED stopped blinking. Is this suppose to happen? I turned off my car for a bit and turned it back on and its no longer blinking. I checked for my connections and its exactly done the way puppetmaster has it in his write up.
any advice as to why the light is no longer on?
mendezrj03max is offline   Reply With Quote
Old 07-02-2009, 04:27 PM   #60
Send a message via AIM to NismoCefiro
If done right, it should always blink at a steady consistent pace. I have mine installed for 4-5 months now and it blinks on queue at its set interval.
__________________
2000 Infiniti I30 ::VQ30DE-K:: | 01 AE 5 Spd w/ LSD Conversion | FrankenCar Intake w/ Apexi Filter | Cattman Full Header | O2 Sims | TEIN S-Tech | Tokico Blues | Alutec FSTB | Stillen RSTB | Brembo Sports Slotted Rotors [Carbon/Iron] | Goodridge SS Lines | 12% All Around 5% Sunroof 3M | 8K 50W Digital Ballast HID | 2x Infinity Kappa Perfect 12 VQ SVC @ 2 Ohms | JBL BP600.1 |
NismoCefiro is offline   Reply With Quote
Old 07-03-2009, 07:58 PM   #61
Quote:
thats weird because mine is no longer blinking. I did the wiring again to see if made a mistake and it still wont turn on. I reseted my ecu to see if my ses light stayed off and it went right back on. I think i have a bad sim.
Old 07-04-2009, 02:48 AM   #62
How soon did it come back on? SES should not come back on. Mine is on because of resistor issues. It takes 30 - 50 miles once reset for it to come back on as catalyst completes and this is if you cut your O2 sensors out. If you keep the O2's and just replace outputs, SES should not come on. The OHMs for my resistor is off. My code is only for heater and not O2's or catalyst. Been meaning to fix it, but I already passed my emissions... Hope you did not fry your O2 sim.
__________________
Old 07-04-2009, 01:26 PM   #63
Well i left my car running for about ten minutes, and then i drove it for ten miles, and my ses light came on. I left my o2's on, I didn't cut them out.
I tried another write up shown on this site, http://www.turbomopar.com/neon/o2sim/index.html, but my sim never turned on again and i reseted my ecu prior to doing this. once i installed it like this, my ses light came back on again. i guess i got a bad sim.
any help. What about the heater wires? Does the sim do anything to prevent a heater code?
Old 07-04-2009, 01:42 PM   #64
Sims do nothing for the heater. Heater is a separate wire out of the 4 wires. One wire is power, one wire output (where o2 sim should be plugged in), one wire to heat the sensor (heater) and ground. Heater resist current to ECM so you will need a resistor or keep your O2 plugged in. If you got SES in 10 miles, something went wrong.
__________________
Old 07-04-2009, 01:56 PM   #65
Well i just have to wait untill my new sim arives so i can install it again the way puppetmaster did in his write up.
so once i have it installed, will it still throw a code for heater? im still a bit confused lol.
Old 07-04-2009, 02:30 PM   #66
BTW, will i need a heater resistor?
Old 07-04-2009, 06:05 PM   #67
If you do not cut your O2's out and your sensors are good, you will not need resistor. If you cut your O2 out or have a bad O2, you will want one.
__________________
Old 07-04-2009, 07:33 PM   #68
Now it makes much sense!
Thanks man i apreciate your help. Now i just gotta wait for my new sim.
ill keep u posted once i get it installed to see if it works fine.
Old 07-10-2009, 08:22 PM   #69
Okay, i just got home from work and my new sim is here.
im gonna install it right away and im gonna see if it works this time.
Wish me luck!
Old 07-28-2009, 10:48 AM   #70
question regarding this o2 simulator install..does the o2 sensor need to be removed that your are using the simulator for?
also are the wire colors diff from the 5th to 5.5 gen?
phatboislim is offline   Reply With Quote
Old 07-29-2009, 10:37 AM   #71
Well i installed the sim in its according to this write up but and I also installed two heater resistors, one for each sensor and I cut out the sensor. It worked fine for a week but then my sim went out again.
So this set up did not work for me. The reason I cut off the sensors off I because I broke them Both when I was installing the headers and hat is why I went with this set up.
Now I was reading that u can weld the sensors after ur cat but that's a problem for me because I'm running straight pipes all da way.
Ink if the wiring is he same as the 5.5
Old 07-29-2009, 07:45 PM   #72
BTW, sorry for the misspelled words. Im still not use to using my blackeberry storm lol
Old 07-29-2009, 08:06 PM   #73
what size resistor did you use for the heater wire?
__________________
SuperStasiu is offline   Reply With Quote
Old 07-29-2009, 11:16 PM   #74
Quote:
I used (2) 10 Ohm 10 Watt resisters in series for each o2's heater circuit with success.
Unklejoe is offline   Reply With Quote
Old 07-29-2009, 11:25 PM   #75
Quote:
2 resistors for each o2 sensor? since i hate electrical work what do you mean by "in series"?
__________________
Old 07-30-2009, 07:19 AM   #76
Well the heater resistors I got from 02simulator.com were 20watt 20ohm. That's the one they provided me
Old 07-30-2009, 09:07 AM   #77
THIS IS COMPLICATED LOL
Old 07-30-2009, 11:38 AM   #78
Yes it is lol
Old 07-30-2009, 08:07 PM   #79
Okay, i have a question. Since im runing Headers, with a test pipe, with a aftermarket resinator, and a magnaflow muffler, U think if i put back the Catalyctic converter, and weld the o2sensors behind the Catalyctic converter, would fix the SES light? Also, will the sound be affected by putting back the Catalyctic converter?
Old 07-31-2009, 06:22 AM   #80
What is the code on the SES light. It may be related to something else.
Sammy Z is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
