Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 03-25-2006, 08:07 PM   #1
Hotshot Headers on a 2K2 SE
When I Get My Hotshots Installed Will I have To Get My A/F ratio adjusted or will i be ok without the retune and if a retune is necessary how would i go about getting this done?
__________________
2K2 6 spd Glacier Pearl SE
jdjones4 is offline   Reply With Quote
Old 03-25-2006, 08:44 PM   #2
Owns a Maxima
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
You will only know for sure if you get it dynoed with AF readings. But then in saying that, most with headers have run rich and needed AF adjustment with some sort of piggyback to get peak power and "proper" gas mileage.
Puppetmaster is offline   Reply With Quote
Old 03-25-2006, 09:20 PM   #3
but will i still feel a nice performance increase without the tune
__________________
Old 03-25-2006, 09:37 PM   #4
The opposite of "Bling".
Derrick2k2SE's Avatar
You may or may not. Different users have had different results. I saw a big increase in power from dyno tuning with only a CAI, Y-pipe and B-pipe. When I tuned after installing the headers they still had to lean it out a lot even from the previous tune.
I would just count on having to install something like a S-AFC2 to tune with.
__________________
2K2 SE 6 speed w/leather, sunroof and Bose : HLSD tranny from 2004 car, Fidanza 15lb flywheel, 350Z clutch, Hotshot headers, Warpspeed B-pipe, PR CAI, Apexi S-AFC2, 17 degree timing advance, HP autoworks STS, PR solid motor mounts, PR shifter bushings, FSTB, RSB. Eibach springs with Ilumina 5-way adjustable struts. Over 120,000 miles. I turn my own wrenches.
Check out my Cardomain page http://www.cardomain.com/ride/2451788
Derrick2k2SE is offline   Reply With Quote
Old 03-25-2006, 09:39 PM   #5
Need A Light?
steven88's Avatar
Send a message via AIM to steven88
IMO, if u plan to keep the car for awhile...just fork out the $250 or so for a VAFCII....
90% of the people on here need af tuning....i doubt u will fall into the 10%....as a matter of fact...I don't think I've seen a perfect AFR max with headers...anybody care to say?
steven88 is offline   Reply With Quote
Old 03-25-2006, 10:48 PM   #6
Owns a Maxima
Quote:
Agreed... all the dynos of 5.5 Gens with headers I've seen have suggested AF tuning is required to lean em out.
Old 03-25-2006, 10:53 PM   #7
Need A Light?
steven88's Avatar
I just wanted to add onto my other post...
If u plan to keep the car for awhile, your going to be adding mods...well if u get the VAFCII, u will never have to worry about tunes....cuz its always there so u can tune...and if u wanna take it even further...get a WB02 sensor...then u will never have to worry about your car running bad, when mods are added...cuz you'll be tuning on the fly!
VAFCII + WB02 = teh MFW!!!
Old 03-26-2006, 07:07 AM   #8
Where do you get this VAFCII from?
THanks.
__________________
SHIFT_Quickly or You Lose
03 6spd Sunlit Sand Maxima---JWT | HH | SSIM | NWP Spacers | Moto UDP | 17 BTDC | Ground kit | VAFCII tuned | STS | FSTB | RSB | 249whp/242tq
97 NOS Concord Mist Maxima--Sold
93 White Maxima--Sold
MaximusMorpheus is offline   Reply With Quote
Old 03-26-2006, 07:18 AM   #9
Need A Light?
steven88's Avatar
EBAY...
it might be a little bit more than $250 shipped...but for sure, if you paid more than $270 shipped, you're not looking hard enough....
type in VAFC....not V-AFC or V-AFC II or whatever....I got more results like that when I was searching for mine
Old 03-26-2006, 05:10 PM   #10
what is a WB02 and what does it do? ;D
DUKEE is offline   Reply With Quote
Old 03-26-2006, 09:07 PM   #11
Actually WBo2. Wide Band Oxygen sensor. You can hook a gauge to it and see your Air Fuel Ratio as you drive. Too much fuel in the mix causes loss of power and poor milege. Too little cauces hot spots in the cillenders and can cause damage.
__________________
Old 03-27-2006, 08:27 PM   #12
whats the difference between the vafc and safc and what type of shop will install this type of thing and tune it for me?
__________________
Old 03-27-2006, 08:29 PM   #13
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
One starts with an S and the other with a V.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 03-27-2006, 08:32 PM   #14
Owns a Maxima
1. Google search "SAFC II" and/or "VAFC II" and you will find descriptions on both units.
2. Most "tuner" type shops will install it.
3. You will have to find a place with a dyno in order to get it tuned or in order to tune it yourself.
Old 03-28-2006, 12:18 PM   #15
i did some research and basically the only difference i can find is that with the VAFC i would be able to change when vias kicks in which i am not really worried about
__________________
Old 03-28-2006, 02:30 PM   #16
The Definitive AE Master
Larrio's Avatar
a fuel controller such as the s/v-afc would be beneficial regardless of headers. A stock car would be able to see to gains just from fine tuning the A/F
Larrio is offline   Reply With Quote
Old 03-28-2006, 02:45 PM   #17
Owns a Maxima
You can trigger the two 12x2 maps (hi vtec and low vtec) in the VAFC-II to be used side by side to essentially create a map that is 24x2. That is the main advantage of the VAFC-II over the SAFC-II. You will have more tunable points over the entire RPM range and that allows for more precise tuning and thus a flatter AF curve for the most power under the curve.
Btw, there hasn't been any good reason to change the VIAS switchover just yet. Just thought I'd throw that in there.
Old 03-28-2006, 04:19 PM   #18
NISMAX03's Avatar
I would get the car tuned with a SAFC or VAFC. I recently had my car tuned with a SAFC-II and picked up a bunch of HP. The car was running extremely rich after the Hotshot install.
NISMAX03 is offline   Reply With Quote
Old 03-29-2006, 09:28 AM   #19
if i decided to go with a y-pipe and catback instead of the hears would i still need a tune...i dont really wunna mess with the motor too much,just want more power
__________________
Old 03-29-2006, 09:32 AM   #20
Owns a Maxima
You probably wouldn't need it, but you may gain power from it. It all depends on the individual car (because the AFR is different for everyone) and your preferences.
Old 03-29-2006, 09:53 AM   #21
Toolie
knight_yyz's Avatar
If you get the vafc is it something that has to tweaked all the time? Or do you get tuned at a shop and hide it away?
__________________
6spd | HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
253.50 fwhp
249.75 lb/ft tq
knight_yyz is offline   Reply With Quote
Old 03-29-2006, 10:09 AM   #22
Owns a Maxima
Quote:
You only adjust your A/F on a dyno or during street tuning with a wide band O2. You don't touch it after that. Some people use like to use the tach on the AFC because it is typically more accurate than the one in the dash, so not everyone puts it out of site.
Old 03-29-2006, 10:16 AM   #23
Toolie
knight_yyz's Avatar
I'm thinking of adding the budget y+b pipe next week. Didn't realize that a piggyback would be recommended to go with that. I thought the onboard ECU would compensate
Old 03-29-2006, 10:36 AM   #24
Owns a Maxima
You have an 02-03, I hope you know that the most power you will gain from a y-pipe + b-pipe is about 12 whp give or take a little.
Like I posted above, you do not necessarily need a piggyback for a y-pipe set-up. You may be able to use the piggyback to squeeze more power out, IF your AF so allows, but it is not necessary. The only way to find out for sure is to get it on a dyno.
For example, MadMaxNH gained about 14 whp on his almost stock (intake+catback) 02-03 just from tuning with a SAFC-II because he found out via dyno that his AF was whack to begin with.
Old 03-29-2006, 10:40 AM   #25
Toolie
knight_yyz's Avatar
I was going to dyno next week before the y+b and then go back after to see the difference. If I go to a reputeable shop that knows whats going on will they be able to tell me that the AF mixture needs tweaking?
You say I'll only gain about 10-12 HP. Was hoping for more than that, does that mean I'll have to go with a complete exhaust system for huge gain? Headers, y+b, and catback?
__________________
253.50 fwhp
249.75 lb/ft tq
Old 03-29-2006, 10:48 AM   #26
Owns a Maxima
Regardless of how good they are and what they tell you, take a copy of the run files home with you (hopefully they're using a Dynojet 248) and post em here. We can give you more opinions.
Aftermarket headers for this car come with a y-pipe that is unique to the headers, ie. if you get headers, you must use the y-pipe that comes with it, and your Budget y-pipe will be useless.
Huge gains have only come from replacing the stock headers because the restrictions are due to the design of the manifolds/precats. Look around the dyno forum for 02-03 dynos with headers.
Cat-backs don't do squat for this car either. They'll get you about 5 whp, most of which you can get from replacing the b-pipe alone. The stock rear section is very free flowing.
Btw, cat-backs include the b-pipe and axle back, so if you get a cat-back, you don't need a b-pipe.
Old 03-29-2006, 10:58 AM   #27
Toolie
knight_yyz's Avatar
The place I was thinking of does have a dynojet but not sure about the model. I've been wanting to dyno for a while but i still have my snows on the car. Will be putting the summers back on on Friday so I'll make my appointment for next week.
I did notice that the cattman headers and y-pipe do have an odd configuration, there is a really strange bend almost at the point they meet up. Unfortunately headers isn't an option at this point in time. I was thinking of going with the cattman y, but at 400CDN shipped + install vs. 500 for budget y+b installed, I'm definately leaning toward the budget setup.
__________________
253.50 fwhp
249.75 lb/ft tq
