12V (Cigarette Lighter Holder) not working
Old 03-20-2006, 08:53 AM
ZeRo MaX's Avatar
So, I accidently dropped my keys and it mysteriously dropped right into my open 12V (Cigarette Lighter Holder) and made a big spark. Now it doesn't work anymore. Can this blow the fuse? I am not sure how to really fix this but I really need to get this done so I can listen to my i-pod, charge my cell phone... and all that good stuff. Hopefully I can fix this ASAP. Thanks!
ZeRo MaX is offline
Old 03-20-2006, 08:57 AM
Biggs_02's Avatar
fuse check the fuse.
Biggs_02 is offline
Old 03-20-2006, 11:33 AM
XyNoix-HIC's Avatar
yea pretty much, i've done that several times to my lights with a screw driver trying to pull the light bulbs out or what not, and The first time i was dumb enough to say oooo cool sparks and i did it again
XyNoix-HIC is offline
Old 03-20-2006, 11:49 AM
MxdOut97's Avatar
you def. blew the fuse. just pop in the spare fuse and your all set. its in the box under the steering wheel if you didnt know
MxdOut97 is offline
Old 03-20-2006, 12:57 PM
LA02MAX's Avatar
mine doesn't work either, but it's not a fuse...i don't really know what happened, but i think my stupid cell phone did it...i dropped my cell phone in the water a long time ago, and when i finally got a car charger, i plugged it in and it worked...for a couple minutes....after that it stopped working and i plugged it into the rear one just to see if it was the plug, itself....same thing happened...now both of them are broken, and i changed the fuse...i'm going to take them apart and see what's going on whenever i do my LED install....
LA02MAX is offline
Old 03-20-2006, 01:38 PM
partyd's Avatar
if is not a fuse check the black plug behind the cigarret ligthter or just clean the center contac ( unplug it first )
partyd is offline
Old 03-20-2006, 02:22 PM
ZeRo MaX's Avatar
Yeah it's not the fuse cause I just replaced it before I made this thread. I meant to say that it was not a fuse since I replaced it. What is the black plug behind the cigarette lighter? How do I get to it? Thanks!
ZeRo MaX is offline
Old 03-20-2006, 03:44 PM
SuperStasiu's Avatar
Take out the hole shifter console assembly to get to the back of the lighter plug. You sure you got the right fuse??
SuperStasiu is offline
Old 03-21-2006, 05:58 AM
5thgenmaxima's Avatar
Before pulling everything apart verify you even have power going to your fuse. Take a test light to your fuse. Connect the wire side of the test light to ground and touch the test light to both sides of the fuse. It should light up.
5thgenmaxima is offline
Old 03-21-2006, 12:47 PM
scheibler's Avatar
the plug for the cigerrate lighter shouldn't matter b/c it couldn't have become disconnected. I bet you just accidently switched the wrong fuse. If
scheibler is offline
Old 03-22-2006, 08:27 AM
ZeRo MaX's Avatar
I switched all (red) 10A fuses. Still no luck!
ZeRo MaX is offline
Old 02-09-2019, 10:07 AM
amat1140's Avatar
fuse INSIDE cigarette lighter jack
Checked service manual. There is a fuse INSIDE cigarette lighter jack! Front cigarette lighter jack stopped working while pumping tire, smelled something burnt. All fuses in fuse panel ok. Used test light on the outlet, worked only if touch return to chassis; doesn't work if touching return to metal ring of lighter jack. As far as I know, only genuine OEM replacement part fits. Found one in ebay, cost $56! Would be interested to know if anyone found a cheaper solution. perhaps replace the inside fuse?
amat1140 is offline
Old 02-09-2019, 10:18 AM
amat1140's Avatar
amat1140 is offline
Old 02-10-2019, 02:22 AM
fat_kid's Avatar
Only almost 13 years later but better late than never
fat_kid is offline
AxisKill
08-17-2005 09:52 AM
Daniel
18
01-11-2005 11:56 PM
MaximaGuy719
07-10-2003 02:02 PM
MAX89'
06-30-2003 06:07 AM
Quick Reply: 12V (Cigarette Lighter Holder) not working
