engine bay wash
Old 02-22-2006, 08:42 AM
JaKillz2's Avatar
engine bay wash
Has anyone ever seen or used the "engine grime cleaner" option at those do-it-yourself washes? Mine could definately use a wash and I've always been hesitant b/c I don't want to fry any electronics.
JaKillz2 is offline
Old 02-22-2006, 08:58 AM
Puppetmaster's Avatar
http://forums.maxima.org/showpost.ph...49&postcount=9
Puppetmaster is offline
Play with my balls
Deckdout2's Avatar
I've used a degreaser on my engine, and this is probably the same thing. Take plastic grocery bags and cover up your intake if you have one, and harnesses up front. just wrap and tie the handles. O and for anyone else that has DDEs, cover up that ignitor. Mine blew out cause water got in it.
Deckdout2 is offline
Old 02-22-2006, 08:59 AM
Play with my balls
Deckdout2's Avatar
Originally Posted by Puppetmaster
You beat my post.
Old 02-22-2006, 09:09 AM
Edward Lee's Avatar
I wouldn't do it at the car wash for several reasons.
1st - Your engine will be hot and spraying it with cold water is not a good thing. You will leave hard water drops all over the place that as hard as hell to get off.
2nd - The spray to rinse it is sort of high pressure and can get into places where it is not wanted.
That being said, get your self some simple green and do it at the house when your engine is totally cold. Spray it on, use a toothbrush to get anything that looks thick and wash it off with your garden hose. I wouldn't worry about the electrical wires as they are pretty well protected. Cover the intake if you have one. Then be ready with some towels to dry the enging. Don't start or drive the engine with the water on it. You will get calcium/hard water deposits all over the engine and the plastic. It can be ugly.
GOOD LUCK.
Edward Lee is offline
Old 02-22-2006, 09:11 AM
Originally Posted by Deckdout2
You beat my post.
So sue me...
Old 02-22-2006, 09:25 AM
RR5
RR5's Avatar
Oh come on people. I worked at a dealership and we would spray the hell out of running engines with a power degreaser, then hit it with the high pressure rinse. For follow up, you can spray a little armorall under the hood. Makes everything SHINY!
Just rev the engine once you are done rinsing. As always, be careful not to get degreaser on your paint or else.
RR5 is offline
Old 02-22-2006, 09:30 AM
JaKillz2's Avatar
how would you avoid that at a wash ha the thing automatically starts sprayin it would definately get on the car.
JaKillz2 is offline
Old 02-22-2006, 09:38 AM
teamsinister's Avatar
Mine could use a wash
teamsinister is offline
Old 02-22-2006, 01:02 PM
boondoxmax's Avatar
Bingo. My boy used to do that for a Honda dealer and they just spray the hell out of those engines with the engine running and never covered the intake.
boondoxmax is offline
Old 02-22-2006, 01:25 PM
NewLoveI30's Avatar
He means if you have an AM WAI or pop charger where the filter is exposed and therefore would get wet.
And on just sprayin down the engine. I've done in on many cars without a problem... Except one with a distributer. If you ge those wet, your car will run a bit lumpy for a while
NewLoveI30 is offline
Old 02-22-2006, 02:34 PM
JaKillz2's Avatar
how do you avoid getting this on paint if your at the wash or something? it sprays a ton and would be like.. un-avoidable
JaKillz2 is offline
Old 02-22-2006, 03:06 PM
NewLoveI30's Avatar
I dont even use degreaser. Soap and water work just fine. Either that or WD-40 works well too for the tough areas.
Old 02-22-2006, 03:08 PM
The Definitive AE Master
Larrio's Avatar
if you guys are worried about hard water deposits after the water dries, just use a filter like Mr. Clean car wash system which will get rid of that problem.
Larrio is offline
Old 02-22-2006, 06:22 PM
IMBOUTTOBUSTSOMEGHOSTS
sloppymax's Avatar
for precaution, i always use plastic bags over the alternator, battery and cone filter. i use it on a warm engine and cover the paint in surrounding areas with old towels. i just use engine brite degreaser and it seems to do the trick.
sloppymax is offline
Old 02-22-2006, 06:26 PM
Edward Lee's Avatar
TOXIC and bad for the environment. Just use simple green.
Old 02-22-2006, 06:29 PM
sloppymax's Avatar
i will stop when they outlaw it.
Old 02-22-2006, 06:37 PM
Tennisjon2002's Avatar
I found the engine brite to work better than simple green. Simple green is good to use on small tuff spots though. I think it is b/c engine brite is a foam and really spreads out over the whole engine bay. Another trick is after you are done spray foaming tire cleaner into the bay and it will brighten all the plastic and rubber parts
Tennisjon2002 is offline
Old 02-22-2006, 07:06 PM
Edward Lee's Avatar
In the meantime, breath in deeply when you spray that stuff.
Old 02-22-2006, 07:10 PM
sloppymax's Avatar
you would not want me to die. then you would have nothing to complain about. i simply prefer to spray all the small children and domestic animals running about the neighborhood.
Old 02-22-2006, 07:17 PM
Be careful... there may just be a stormtrooper lurking about during your next car wash....
Old 02-22-2006, 08:03 PM
mclee45's Avatar
I never had any problems. I spray engine degreaser all over my engine compartment and use high pressure rinse at a car wash. I do it once a year and my engine compartment looks new. I just start the car and let the engine heat burn off excess water in the compartment. I dont cover anything either.
mclee45 is offline
Old 02-22-2006, 08:44 PM
Jaws's Avatar
I always use the high pressure wand at the car wash and in 20 years have never had a problem. I have never had to use de-greaser, just the normal "soap" setting on the machine. I keep the tip of the wand fairly far from anything that would be more sensitive to higher pressre. Look at it this way, in a heavy rain storm on when driving on the highway, the engine compartment is taking in a lot of water anyway.
Jaws is offline
Old 02-22-2006, 10:35 PM
dot dot dot ...
NmexMAX's Avatar
Watch out with the knock sensor valley...
Also, beware of the small children around sloppy, you want to get it evenly in both eyes.
NmexMAX is offline
Old 02-22-2006, 11:10 PM
00maxipad's Avatar
idk if i would man all those internals..
00maxipad is offline
Old 02-23-2006, 05:26 AM
Play with my balls
Deckdout2's Avatar
don't lie, you know senior citizens fall victim to your use of teh engine cleaner also.
Old 02-23-2006, 05:42 AM
I might have to get me some of that.... I hate some of the old people and cats in my neighborhood.....
Old 02-23-2006, 07:13 AM
Larrio's Avatar
i'm more worried about water collecting in the "V" portion of the block where the knock sensor sits
Larrio is offline
Old 02-23-2006, 10:03 AM
sloppymax's Avatar
thats why i setup an autocross on my street and sling the water out.
Old 02-23-2006, 10:33 AM
Larrio's Avatar
parking cones and all?
Larrio is offline
Old 02-23-2006, 12:08 PM
Need A Light?
steven88's Avatar
2k2 owners - do you wash it with the engine cover on or off? if off, do you get water onto the coilpacks injector harness? do these have to be covered up as well?
steven88 is offline
Old 02-23-2006, 12:13 PM
sloppymax's Avatar
i know you asked the 3.5 guys but i removed my ae cover and mine are completely open to the elements. i try not to focus the spray of the cleaner or the water but i do go over the coils with no issues. of course, i have only needed to clean mine about 3 times in 4 years.
i actually do not use parking cones but mutated midget children. they have no legs so they tend to stay put.
Old 02-23-2006, 12:15 PM
Need A Light?
steven88's Avatar
i know you asked the 3.5 guys but i removed my ae cover and my are completely open to the elements. i try not to focus the spray of the cleaner or the water but i do go over the coils with no issues. of course, i have only needed to clean mine about 3 times in 4 years.
nice...I'll just stick to your original setup by covering intake, battery, alternator....and i'll try not to focus my water on the coilpacks and injector harnesses...
steven88 is offline
Old 02-23-2006, 12:20 PM
MAXRB8's Avatar
How about covering the HID balasts on 5.5th gens?
MAXRB8 is offline
Old 02-23-2006, 12:25 PM
Need A Light?
steven88's Avatar
Isn't the ballast sitting like all the way down there? I dunno if you'd even spray water in that direction
steven88 is offline
Old 02-23-2006, 01:56 PM
GBAUER's Avatar
I'll settle it all: I have a 5.5 gen (ballests) with an InJen CAI (or whatever Irish wants to call it....) that I've modified to make into a pop charger configuration and I wash my bay weekly with no problems. Yes, I actually wax my engine cover (painted) and armor-all my hoses and anything else plastic to make it shine. I'm **** like that.
GBAUER is offline
Old 02-23-2006, 02:31 PM
Edward Lee's Avatar
Your engine bay looks atrocious. How can you live w/yourself.
Old 02-23-2006, 02:40 PM
I'm needing a caw
Jeff92se's Avatar
I've washed my engine numerous times in the carwash bay. When I select the engine wash feature, I don't use the high pressure. It comes out anyway. And I try to work from the outsides in. And don't use heavy spray on the block/exhaust manifolds. You should gently work you way around them. Then let it sit for a few min. Then use the rinse. You can use the high pressure in CERTAIN areas but try not to direct it any connectors/intake etc....Comes out great. Yes you do get some water in the block valley but it evaporates when you drive around. I don't like using all the degreaser in my driveway so I use the carwash
Jeff92se is offline
Old 02-23-2006, 02:56 PM
NJ Devils Fan's Avatar
Hmm, seems weird to me for some reason to shoot water into the engine bay, I don't know why. Next time it gets warm, I'm gonna have to do this.
NJ Devils Fan is offline
Old 02-23-2006, 03:41 PM
GBAUER's Avatar
I don't even take that much care. I just shoot the bay with the tire cleaner, pre-soak the rest of the car, put it on pressure wash, spray the carp out of it, and rinse it out. Never had a problem and I've done it around 100 times.
GBAUER is offline
Quick Reply: engine bay wash
