Overheating!
Overheating!
Hi,
My 2000 SE temp gauge was at High this morning while driving. When I come to a stop and idle it immediately goes back down to normal. My thermostat and 1 fan is only like 1 year old in this car, but the car's fans always seem to run at full blast and sound loud from outside the car. Any ideas as to the problem and/or where to start troubleshooting?
Though it is 1-yr old, it could still be your stat not opening properly, next time this happens, before the temp drops, touch the upper rad hose (one on the passenger side, going from engine to rad) and if the temp is showing high and the rad hose is not hot then it could be your stat not opening or water pump that went bust...
Originally Posted by JamesBahn
Check to make sure you still have belt around your water pump. I just had the same situation with my Land Cruiser
it may be a clogged radiator. my 2000 was doing the same thing and i replaced the thermostat which didnt fix the problem. finally realized that the radiator was completely clogged (I assume it had never been flushed). so the thermostat was opening but the fluid was staying in the engine block because it couldnt flow through the radiator. found one online for around $100
How many miles on the car ? I noticed that most Maximas with bad water pumps are due to neglecting to do coolant flushes. I personally do a coolant flush on my car every year or bout 30K miles.
Look under the car right by the AC compressor, if you see any traces of coolant there- you need a new water pump.
Dont let it overheat, or you will need a new engine- its cheaper to put a new one in that repair the old one.
I'm with Soonerfan on this one. Same thing happened with my 2000 SE at 150,000 kms even with regular coolant flushes and all maintenance done regularly. Dealership tried different things but eventually replaced the rad to fix it.
Usually when I replace a rad, I would look at replacing the hoses if they are close to the need of it, and would replace stat regardless how old the original one is...
As far as the crack in the rad goes, where was it and have you observed any coolant loss prior to this? Any coolant marks on the ground?
OK, so it is likely a busted rad and I also think stat was too... Judging by the ECU reflashing, seems that the dealer is working on it... Hope they don't overcharge you for this experience!
Dont be overly alarmed by that smoke. When you replace rad, hoses, and stat, there is always some coolant or water left around and on the engine that when engine warms up evaporates shortly after. Simply open the hood, let the car run and look for sources of steam and hopefully it is just that...
Another thing is that I hope when the car overheated that the pistons or the heads did not warp. Just something for you to be aware of in the future should you have any problems with compression or leaking head gaskets...
RWCreative
09-21-2015 11:01 AM
97_GXE
20
09-17-2015 08:12 PM
97_GXE
09-15-2015 06:47 AM
