3rd gear grind
A lot of the 6 speed trannys have the 3rd gear grind. Mine is one of them. If I shift into 3rd fast at a high RPM it grinds. It goes in OK but it sounds bad. A lot of them were replaced under warranty. At 97k that's not an option for me though. I'm keeping my eyes open for a used 03 6 speed w HLSD.
I haven't heard anything about the 5 speeds having problems though. The 5 speeds are much smoother shifting. My 95 had almost 200k and shifted great.
BTW JaKillz2, did you figure out why the car wasn't running right the other day?
or can you actually "feel" the grind on your shift **** when u go into 3rd?
Originally Posted by OOmaxSE
Could be that your synchros are going bad. Considering the part is under a couple bucks, sounds like they could easily get booted. I've heard that it will only get worse if not fixed...
Originally Posted by steven88
so when you go into 3rd, its smooth? just only a loud grind?
or can you actually "feel" the grind on your shift **** when u go into 3rd?...
Originally Posted by vsamoylov
just get a 6 speed from a 6th gen
I just put on headers, S-AFC, Fidanza lightweight flywheel and a stage 3 clutch within the last few months. It may be a while till I can justify spending that kind of money on the car again. If I were single, or looking to be single again, I would have done it.
ya but mines a 2k. It does it like every and its not really random it happens cause i have the stick forced to straight up in the 3rd gear slot instead of the upleftup from second and its just like a split second like you push against the gears and then its gone. And you can definately feel it through the ****
6th gen 6spd tranny is better i believe...
don't quote me...but i think it has triple cone syncros for 1-2-3...versus double cone syncros on the 5.5 gens (smoother shifts)...and the most important...the 4.1 final drive
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
