question about re-wire
Ok, so awhile ago I rewired my fogs using a writeup from a cardomain page. It said to attach the wire to the air conditioning wire that way I could turn them on whenever I wanted, regardless of whether the parking lights were on. So I did and it worked great. The other night I notices that my fogs still turn off when I put my high beams on. Is there a way to re-wire so that my fogs will stay on even with the highs and I can still turn them on and off whenever I please?
Yes, you have to bypass the relay. Off hand, I don't know which wire it is...but if you have access to a service manual, you can check the wiring diagram. When I had my '95, I did the same thing you are trying to attempt.
Originally Posted by NisMoN00B
I don't know about laws in NY but it's illegal to have your fogs and high beams on at the same time. At least, down here it is.
it's illegal to have more than 4 white lights running on the front of your car, but for those of us who have only have 2 headlights going when the highs are on (as opposed to the 02/03 which would have 4 headlights going with the highs) running the fogs should be ok-but I could be off of the laws, it's been a long time since I took driver's ed.
I think running the fogs/driving lights with the high beams on should be encouraged because they give a little more light to the sides of the road which could help you see animals etc entering the road sooner.
Yeah, to further explain my previous post, I had installed aftermarket fogs on my '95 to turn on/off via a seperate switch. I had bypassed the relay of the high beams so that I can keep the fogs on at all times if I wanted to. But, when inspection time came, I had re-wired them to cut off with the high beams. And, by no means, when I had them hard wired to stay on whenever I wanted, I had never ran them when I had the high beams on. Like, someone said before, this is illegal (eventhough I had them wired that way, I never ran them that way).
it could be illegal I never looked into the law books or anything though. I just thought it would help visibility a bit. Since your high beams focus more on distance and the side of the road, if I still had my fogs centered infront of me it would help a bit. Oh well I guess.
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
