A Weird Turn Signal Issue...
I have a very weird issue with my right turn signal. If I engage my right signal at any time after it has not been engaged within the past (approx) 2 minutes, my climate control (auto) and stereo (stock bose) both get very bright for a fraction of a second. I only notice this with the right signal, not the left, when it is nighttime, and that is the only time that it is dark enough to see it.
At first I thought I was seeing things out of the corner of my eye or the reflection of my turn signal reflecting off of something outside of the car, but last night I caught it - twice, once while directly looking at the consoles.
The first time I saw it out of the corner of my eye, so I turned the brightness **** to zero (all internal lights off aside from the light showing which gear I'm in and the clock) and when I engaged the turn signal while driving (moving, but not accelerating) I looked at the consoles and both lit up temporarily as if they were receiving a power surge of some kind.
I have no CEL, and recently had my battery voltage checked and verified as correct by the dealership.
Any ideas as to what this could be, or if I should just ignore it, let me know.
I think I may have the same problem, but mine affects the HID's, they flicker (brighter) when I use the left turn signal, and I have regrounded everything. I am beginning to think it may be the actual signal stalk shorting out somewhere, I have a replacement comming in, I'll let you know
Definitely sounds like a grounding issue. Have you done any electrical work in the car lately, i.e stereo, gauges, bulbs, etc? Even simply tugging on a wiring harness can cut a wire and cause all kinds of issues. I had a wierd electrical issue like that in my old Trans AM. Took me 3 days to find it.
I have seen a lot of weird electrical issues pop up on this forum, is this a fluke? or did all gen Maximas succumb to electrical idiosyncrasies?
I've seen a problem that I think I have with my DRLs, they work fine until I turn on the low beams and then try to use the high beams - the passenger side hi-beam doesn't light. The high beam bulb is a single filament so I guess it's not the bulb. I read some threads that indicate it may be the stalk or a relay, any ideas where the relay is ? I've only had the car about a month.
Thanks, didn't mean to try and hijack this thread.
I have a similar problem with my turn signal. (2000 max)
Everytime I use the signal (left or right), the moment the signal switch goes off, ALL of my Interior (dash, clock etc) and Exterior (headlight, tailights etc) flashes for a split second (its like i'm flashes someone with my headlights). The strange thing is that it only happens in "AUTO" headlight mode. Its fine when I use the "MANUAL" mode.
I'm baffled to what the problem is. I went to my regular dealership before and they couldn't figure it out. I'm probably going to head to another dealership to see if they can find a remedy.
I have not done ANY electrical work to this car, and it has been 100% dealer maintained. I was thinking about purchasing a grounding kit of some kind, but have been too plain lazy to figure out what the end cost would be to me, and then find out if I have that much money.
The bulb does not blink faster on one side, and it is not a consistent issue so even if I took it to the dealership, I *probably* wouldn't be able to reproduce it. Dafertalizer- let me know what happens with your bulb (even though I have 2k headlights)
thanks everybody, more comments or suggestions are still welcomed.
I am going to see tonight if they do it with the headlights turned on instead of auto, see if that makes a difference, if it does, this would lead me to belive even more that its the switch (stalk from steering wheel)
Mine will be here soon, but it's comming from Canada and things usually take a little bit to come from there.
I'll keep you posted.
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
HerpDerp1919
09-29-2015 02:02 PM
DC_Juggernaut
09-28-2015 04:07 PM
